Old 12-27-2014, 09:22 AM   #121
Evo 13's Avatar
Originally Posted by dan_vector View Post
I like it a lot!! I gotta get my 747-e back out there...
Thanks Dan, Check your email.
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Mugen MBX7T ECO (Truggy)
SMC, Max Amps, LRP, Poseidon Motors, Cordova Research Motors, Xceed.
Evo 13 is offline   Reply With Quote
Old 12-27-2014, 09:23 AM   #122
Evo 13's Avatar
Originally Posted by ViperZ View Post
^^^ Like
Hey Viper,
You know how we do!
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 12-30-2014, 04:13 AM   #123
Found a kit. Had to remake the rear shock brace due to shorter dampers. The rest was kind of spot on.
The body is for a 220mm conversion but was parfect for this project. The chassie is 230mm wide at the rear end
puttekula is offline   Reply With Quote
Old 12-30-2014, 04:27 AM   #124
Originally Posted by Yuppe View Post
Nice, where did you get the floating body mount? I probably need one more.
What brand body is that and how wide mm is it 220 ore 230?
I been using Blitz P908 1/10 230mm GP body.
Yes its going to be a monster, first summer i have play whit mine. Started out 3cell and Tekin Rx8 gen2 and Pro 2 5100kw. Mid summer i got Pro 2 5900kw and whit that puni engine i was almost down to 1:8 nitro track lap times.
Late summer i got Lrp 4700kw long can. Only used Lrpix8 on it. Gen2 died bit before i got it(: But on those few test runs close to minus degree it was enough. I Might use tekin Pro4 4600 ore Prohd 4300 next summer, the weight and can length fits better balance 3 cell battery and its probably more than enough to park those 1:8 nitro track cars.
I will post a link when I get home. Is that LRP esc better than the Rx8? Thought those Tekin was bullet proof. Im going for 4s in my setup. Not sure about motor, but those Tekin Pro4 looks sweet. Any pics of your rig?
Old 12-30-2014, 06:38 AM   #125
Lrp Ix8 is probably the most shitty esc ever sold, only one i had to try the 4700kv.
Gen2 is probably the best esc use. Low weight compare to many other esc brands. Trying to wait, Gen2 have been on marked a while now. Was hoping Tekin make a Gen3 in some sexy alu housing bit dust proof would be cool soon!
Rx8 only big fault is housing soak dust, you get corrosion on the components.
I been using Viper VTX8 alot on the car, very smooth esc. Vtx8 113g no wires Gen2 76.5g.
Been drooling a bit on Orion Vortex R8.1 Pro 2-4S 180A but its so heavy 146g.
Yuppe is offline   Reply With Quote
Old 12-30-2014, 06:42 AM   #126
Evo 13's Avatar
Puttekula,
The car looks like a champion!
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 12-30-2014, 07:11 AM   #127
Thx Evo. Like ur Porsche too....
Old 12-30-2014, 07:32 AM   #128
puttekula
4 cell and Pro4 ore hd might be perfect if use not so heavy 4 cell pack.
I probably try that to, when i get bored of 3 cell But for now on a track 3 cell is more than enough for me and hopefully enough to get better lap times than 1:8 Track. If not then i really hurry get 4 cell
Old 12-30-2014, 07:42 AM   #129
I have Hyperion 3300mah 4s 45c packs. They are by a margin heavier than
2s 7200mah. Smaller in size but a little bit higher.
We have a small thread about this concept over here in Sweden. Something for you Yuppe to fill
in with?
http://rsb.se/arena/showthread.php?9...-den-att-bygga
Old 12-30-2014, 08:35 AM   #130
Heres the shop with the conversion kit in stock. Bodies as well...
http://www.tcmodels.net/index.php?pa...mart&Itemid=71
What kit do you have? Using the long rear shocks?
Old 12-30-2014, 08:58 AM   #131
Evo 13's Avatar
Hey, do you know the width of those 1892 vids 220mm rear foams from that site?
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 12-30-2014, 09:58 AM   #132
Im not shure, but I have read somewhere that they are about 40mm wide. 5mm less than the tires I use.
Old 12-30-2014, 10:15 AM   #133
Evo 13's Avatar
I think we use the same wide foams:
Serpent Cobra GTE
2 x Serpent 747e
Xray X1
Old 12-30-2014, 10:45 AM   #134
ViperZ's Avatar
Nice collection of tires
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 01-24-2015, 01:22 AM   #135
hello,
can you tell me what shore you used ,front and rear wheels gt ?
thanks
cc801 is offline   Reply With Quote
