Like Tree1Likes
Old 06-30-2014, 10:52 PM   #91
kman16jr's Avatar
Trader Rating: 53 (100%+)
ok i cant wait to get this car,just need to get a basic setup for 13.5,17.5,and more than likely 4.5 for the big track. Probably want to run 64 pitch gears but will run 48 if i have too.
Kevin Welfley
AE rc8b3-AE rc8b3e-AE b64d-AE b6d-AE b6
Sponsors:|DDHrc|Team Trinity|Jconcepts|Rc Adiction Products|NitroPro Fuel|M2c racing|Ultimate racing engines|Highest servos|Bellgate Distibutors|
kman16jr is offline   Reply With Quote
Old 07-01-2014, 10:20 AM   #92
I would look for an T4 set-up as a starting point.
Goal Achieved....Not Dead Last.
mooby64 is online now   Reply With Quote
Old 08-01-2014, 08:00 PM   #93
12scale's Avatar
My son had his first run of the TC10 last night at our club race in Mod and the car performed well, qualified 2nd and then he won all the 3 finals. The car kept getting better through out the night with a couple of changes. Very happy with it so far and I'm sure with a bit more playing around we should get it going even better.
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 08-01-2014, 08:35 PM   #94
Good to hear that he is happy with the car. There seems to be only a few people here that run this chassis
Old 11-22-2014, 02:15 PM   #95
Send a message via Yahoo to nomaak
would someone mind posting the part numbers for the lower bulkheads,fr/rr suspension mounts, and 1.3/1.2 swaybars with holders from the TC10 manual? thanks a bunch!
nomaak is offline   Reply With Quote
Old 11-22-2014, 04:42 PM   #96
From TC10 manual.
LOWER BULKHEAD - T01007 (Front/Rear same part)
REAR ARM MOUNT D3.0 - T01006
ALUMINUM SUSPENSION ARM MOUNT L/R - T01009 (Front rear same part)
SWAY BAR HOLDER SET - T01090
FRONT SWAY BAR 1.3 - T01065
REAR SWAY BAR 1.2 - T01069
SWAY BAR BALL STUD - T01072
4.9mm Ball End-Short – T09104
M3x8 Screw – T01095
mx461 is offline   Reply With Quote
Old 11-23-2014, 05:57 AM   #97
Thank you
Old 11-23-2014, 06:02 AM   #98
I'll be getting with my hobbyshop to order parts asap. Perhaps a less leaky gear diff. What do you guys recommend?
Old 11-23-2014, 06:14 AM   #99
Spec-R diff for the T4.
Old 11-25-2014, 07:34 AM   #100
Sooooo pumped make my first laps with this car tomorrow!!!! Gonna break everything in with a mod first then rebuild for 17.5 blinky
Old 11-25-2014, 08:21 AM   #101
Where are you running at? I may be at Ho B-Max running my TC10's - VTA and USGT.
Old 11-25-2014, 09:50 AM   #102
Ho-B max as well! I'm going down tomorrow soon as the road course is put back together
Old 11-26-2014, 12:56 PM   #103
@ mx461 what are your spur gear sizes? All I have are 96 ànd 108
Old 11-26-2014, 03:35 PM   #104
I am running 96 spur on both. I had to dremel the aluminum center motor mount (Team C Part # T01022) for pinion clearance.
VTA = 96 Spur and 49 – 51 pinion
USGT = 96 Spur and 48 – 50 pinion
How was testing today? I couldn't maker it. It's hard to make practice days with a 2 hour drive.
Old 11-26-2014, 06:29 PM   #105
Default Gearing
The gearing that I've found to work well for 17.5 on my TC10 is 64p 92t for the spur gear and 45-52 on pinion gears with no dremeling required. So far the car is awesome. I put the 2 deg rear toe block on and shimmed my shocks off of the tower 4mm for the front shock and 2mm on the front arms. The rear shocks are shimmed 2mm on the rear tower and rear arms. I saw some of the X-ray guys doing this at the worlds race so I tried it and worked really well. Gives you more corner speed. Other than that I used the stock setup. Waiting to use 2.5 springs f/r should make it better.
Kris James is offline   Reply With Quote
