Like Tree4Likes
Old 12-13-2013, 02:15 PM   #16
Talking
Might as well be TamiYokMiTopARXray 411 ....lol...
bertrandsv87 is offline   Reply With Quote
Old 12-13-2013, 06:17 PM   #17
Originally Posted by lewis110 View Post
Anybody have a chance to run this yet?
Mine should be in my hands Monday... Good or bad, it is just another horse in the race.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 12-17-2013, 07:00 PM   #18
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hi guys! Got my kit yesterday. Going to built it this week and try it Sunday...
I am looking forward to it!
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 12-17-2013, 07:22 PM   #19
Picking mine up tomorrow and planning on building it over the X-mas week. Any build tips/ issues will be helpful.
Old 12-19-2013, 07:35 PM   #20
Joe Kimble's Avatar
So far it's nice and smooth. Tolerances are pretty tight.
Two things to do carefully though:
- When putting the spur together with the pulleys, there is a little orange shim you put at the end of the shaft that holds everything together. If you find that shim too thick replace it with a thinner one. Be careful that the inner AND outside diameter of your new shim is the same than the stock orange one. You should assembling that pulley/spur section before without the belts first and make sure it's perfectly free.
- Be careful to use the 44mm CVDs in front and the 43mm CVDs in rear.
Serpent America
Sweep USA
RCShox
Old 12-19-2013, 08:49 PM   #21
Started my build tonight and found the issue w/the spur adapter right away. Just took the shim down with a little sand paper.
I also found that there is very little room for pinion selection. I found, with a little grinding of the front motor mount, that I can get a range of about 9 or 10 teeth. I'm going to run USGT/21.5 with a 96t spur, so I have between 43t and 52t.
Thanks for the update.
Old 12-20-2013, 09:15 PM   #22
Joe Kimble's Avatar
Serpent America
Sweep USA
RCShox
Old 12-20-2013, 09:29 PM   #23
internal gears are 38/20 making it 1.90. I need ratios from 4.10 to as low as 2.80, depending the track.
Old 12-20-2013, 11:11 PM   #24
Anyone know where these kits maybe available?
daveb is offline   Reply With Quote
Old 12-21-2013, 09:21 AM   #25
My local shop ordered mine from HRP Distributors. They are the sole importers of Team C. And from what I have seen Xray suspension parts (arms, knuckles, C-hubs....) will drop right into this chassis.
Old 12-21-2013, 03:08 PM   #26
Joe Kimble's Avatar
The manual says 38/22. Haven't actually counted...
Serpent America
Sweep USA
RCShox
Old 12-21-2013, 08:21 PM   #27
Joe Kimble's Avatar
Hi! I just counted and you are right it's 38/20 which gives an internal ratio of 1.9. I'm going to start with 96/42 spur/pinion for 17.5 blinky and take it from there.
My apologies for the false info, we will have to inform TeamC of the typo so they can fix it for the next batch.
I have a question though. Did you get any stickers in your kit? I had none.
Serpent America
Sweep USA
RCShox
Old 12-21-2013, 08:22 PM   #28
Joe Kimble's Avatar
Serpent America
Sweep USA
RCShox
Old 12-21-2013, 08:24 PM   #29
Joe Kimble's Avatar
Serpent America
Sweep USA
RCShox
Old 12-21-2013, 08:29 PM   #30
Joe Kimble's Avatar
Don't mind the angle of the steering rod, I'm going to shim between the servo horn and the ball to reduce that angle.
I feel that's the reason why I had to increase my right EPA compared to my left to obtain an equal steering throw left and right...
Serpent America
Sweep USA
RCShox
