Old 11-18-2013, 05:54 AM   #121
R Dodge's Avatar
I ran the stock pod. Joel or I will post my setup sometime a little later today. He knows it by heart because he built it, whereas I have to measure some stuff. Lol
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy★
R Dodge is offline   Reply With Quote
Old 11-18-2013, 11:34 AM   #122
Robbie's car is built how we've always run team cars. There's a window it seems where every speedmerchant 12th is within. I may when I have time write out a setup sheet with that.
Jaco lilac
Stock old school front end
1*camber 4* caster
.020 spring
Green spooge on kingpin
Pack inline
35wt ae shock oil
Ae blue center spring
2* pod droop
.020 side springs 2 turns down from up
Green spooge in tubes
blue rear tire
AMR body centered in front wheel wells.
JoelV is offline   Reply With Quote
Old 11-18-2013, 05:47 PM   #123
R Dodge's Avatar
I promise, once I get all of my own electronics and a little time to actually sit down and put time into them, it will be much more camera worthy.
Thanks for posting the setup Joel!
Old 11-18-2013, 06:03 PM   #124
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
I need to get one!
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 11-26-2013, 09:15 AM   #125
Ive had a 3 race days on the Rev8 so far, and it continues to get better each time I run it. I started out with the car inline, but felt more comfortable with the transverse battery configuration at my club track.
This past weekend, I incorporated some of the ideas from Robbie's setup posted above(albeit still keeping the car transverse) and I moved to the #5025 aluminum front knuckles... which allowed me to shim the front springs more to my liking. With the stock plastic steering knuckles I ended up with a fair amount of front spring preload, even without any shims. Allowing the front end a little more downtravel really helped keep the car calm/settled in sections of track that weren't the smoothest... and also gave the car a bit more mid-corner steering. I also liked the feeling of Red Spooge in the tubes with a bit less side spring preload(1.5 turn vs 2) rather than the Green....
Our track layout has been in place for about 5-6 weeks now, so the fastest laps and overall runs in each class are pretty well established. While we didn't have a big turnout for 12th this past weekend, I did end up resetting the track record for 17.5 by ~8 seconds, putting down the only 41 lap run to date on this layout. The car was very solid, developed a lot of natural steering, but wasn't twitchy or too aggressive.
Bruce asked me to post a pic of the transverse setup and I figured I would share my setup, in case anyone is looking for a place to start for a non-inline configuration:
-James Lundberg
Edit: I made a mistake above... the side springs are at 1.5 turns down. They are just barely touching the pod plate.
JamesL_71 is offline   Reply With Quote
Old 11-26-2013, 10:06 AM   #126
NutDriver's Avatar
Trader Rating: 14 (100%+)
Anyone had any luck recently with getting in touch with the SpeedMerchant folks?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-26-2013, 09:15 PM   #127
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Glad to hear the rev8 is working for you James
Joel or Bruce, always get an answer from one or the other
support@teamspeedmerchant.com
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-27-2013, 06:42 AM   #128
NutDriver's Avatar
Thanks, RedBull. Will try them again.
USVTA member #111
Old 11-27-2013, 10:35 AM   #129
NutDriver's Avatar
Bruce got right back to me. Thanks again, RedBull.
USVTA member #111
Old 11-27-2013, 02:17 PM   #130
tim fry's Avatar
My Rev8 with cell across and Xenon front end
tim fry is offline   Reply With Quote
Old 12-01-2013, 10:36 PM   #131
avs
avs's Avatar
-James Lundberg
thanks for the report, but does anyone know the purpose of that hole on the left end of the top plate? it was clearly designed into it as there is additional material surrounding it. just curious, I can't think of a reason for it.
Tony Shimko
avs is offline   Reply With Quote
Old 12-02-2013, 12:23 AM   #132
Paul Lomas's Avatar
Its so you can access the tweak screw that side.
Paul Lomas is offline   Reply With Quote
Old 12-02-2013, 06:28 AM   #133
avs
avs's Avatar
DOH! now its obvious, once you pointed it out. thanks.
Tony Shimko
Old 12-11-2013, 06:19 AM   #134
Herminator's Avatar
Send a message via ICQ to Herminator
Hi guys, I'm looking at getting a Rev8 to replace my sloppy X12.
I race with Mr Lomas (when he has a car that works....) here in the UK.
I'm currently in the US though, and thought it would be good to pick up what I need whilst over here.
I can use an xray rear axle but it seems I need everything else, ie. a virtually complete kit, with old school front end and team tamale rear pod. Most bits seem available as seperate parts, although the tamale pod wasn't in stock last time I looked.
I've tried emailing SM a few times now over the last couple of weeks, to clarify what I need and what is available to order, but I haven't received any replies
Can anyone give me a definitive list or help with contacting them?
Herminator is offline   Reply With Quote
Old 12-12-2013, 03:22 AM   #135
rosko's Avatar
Any idea when i can get a new school front end for my 12 r5.2
rosko is offline   Reply With Quote
