Like Tree9Likes
Old 03-21-2016, 06:40 PM   #946
Originally Posted by Conrad View Post
I was actually asking about assembly Sir the double e-clips is just a pain in the ass. How about using grubs screws and filing a flat on the kingpin?
When I ran an old Skool front end on my cars, that's exactly what I did.....grind a small flat on a plain 1/8" kingpin and use a grub screw thru the steering block to hold it in place ......because it makes spring changes and even just routine cleaning and upkeep so much easier. I too found the e-clips to be just too awkward and fussy to deal with.
vafactor is offline   Reply With Quote
Old 03-21-2016, 06:44 PM   #947
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Are we all talking about this front end, which includes a grub screw ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-21-2016, 07:51 PM   #948
The AE old school front end used 2 e clips to hold the steering block in place on the kingpin.
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 03-22-2016, 09:03 PM   #949
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Maiden voyage with the Rev 8 last weekend after parking a CRC. Impressed with the chassis, quality & response to adjustments.
A big thanks to RedBullFiXX for the set-up help while trackside!
Looking forward to more quality time on the rug.
madjack is offline   Reply With Quote
Old 03-26-2016, 03:26 PM   #950
Conrad's Avatar
Nah, the old skool, two e-clip front end. I was thinking about the grub screw mod more for using springs of a different length (SM v AE) and having just enough pre-load on the spring rather than way too much and it would allow for a small amount of droop on the front. It's for GT12 not 1/12th but where better to find out info than from the SM guys
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 04-03-2016, 05:18 PM   #951
Trader Rating: 42 (100%+)
Originally Posted by Drew Manzella View Post
Only part I have ever broken on mine is a side link. Once.
I've ground up a couple spur gears however.
Things I would keep in my box if I were prone to breaking shit:
  • Pair of upper arms
  • Pair of lower arms
  • Pair of side links
  • Pair of steering turnbuckles (complete with ball cups)
  • Pair of steering ball studs
  • 4 or more axle/hub bearings (they go bad - tons of side loading on them - but this is true on any 12th scale)
Granted I carry bearings, spur gears and now a pair of side links but nothing else listed above. I have however replaced the following:
  • Stock turnbuckles with titanium (steering and camber)
  • Stock inner (servo) ballcups with Associated
  • Servo ballstuds with Associated 3mm
  • Stock steering block ball studs with CRC 13615 aluminum pivot balls
  • Stock axles with Associated
So the stock takeoffs are in my box.
As for option stuff - I have all the Associated center/front springs as well as a complete set of RSD front/side/center springs but to be honest I have never felt the need to change the springs from what the car came with originally.
I run CRC spur gears because I like the 16 smaller balls over the 12 larger balls. I run TKO diff rings.
Drew,
How'd you get the associated front axles to work?
Bent my front end today getting used to the new CRC carpet.
The Speedmerchant has splined axles, did you just drill the knuckle out?
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is online now   Reply With Quote
Old 04-03-2016, 07:01 PM   #952
Trader Rating: 26 (100%+)
You can just smooth out the axles on the dremel and put them in. I have lunsford axels on one of my cars.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 04-04-2016, 04:30 AM   #953
Thanks for the info Steve!
Aaron Moore
Old 04-15-2016, 03:16 PM   #954
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
McFactory Motorsports aluminum chassis and pod plate for the Rev.8 Pro.
Check out the McFactory thread for more info.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 05-02-2016, 08:39 AM   #955
Anyone know of a tweak brace with provisions for an O-Ring lateral battery mount system for the Rev-8?
Aaron Moore
Old 05-02-2016, 07:05 PM   #956
Haven't seen an o-ring conversion, tape is best, and lightest for 1/12 scale
Lipo's can move those o-rings pretty easily
Old 05-17-2016, 09:01 PM   #957
Thumbs up
News from SpeedMerchant
Bruce is working with Mike from McFactory on Rev8 Aluminum chassis
SpeedMerchant are taking pre-orders now !
SICKNESS ! ! !
JayBee likes this.
Old 06-06-2016, 05:03 PM   #958
McFactory Type "L" SpeedMerchant conversion:
Old 07-02-2016, 01:05 PM   #959
Ran the new McFactory chassis yesterday at practice. Car is dialed.
You need this on high grip CRC carpet!!!
Got the new reactive front end parts coming next!
JayBee likes this.
Aaron Moore
Old 07-03-2016, 09:48 AM   #960
madjack's Avatar
Thumbs up
Looking forward to running it in anger
JayBee likes this.
