Like Tree9Likes
Old 02-19-2016, 04:31 AM   #931
Originally Posted by mnracer View Post
Anyone know where I can buy a tomale pod to fit my rev 8???? I want a better rear ride height adjustment than the typical inserts that pinch the axle bearings!!!! There is nothing on the tomale site.
If you can't get a new pod try the Xenon inserts. They fit a lot better than the typical Associated/CRC ones that most people use. They don't pinch or bind the bearings.
http://xenon.ocnk.net/product/414
avink007 is offline   Reply With Quote
Old 02-19-2016, 01:17 PM   #932
Trader Rating: 26 (100%+)
I have a Tamale pod that was used once at the Snowbirds two years ago. Im not going to use it, so PM if your interested.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 02-19-2016, 01:51 PM   #933
bertottius's Avatar
Trader Rating: 19 (100%+)
Wasn't there a guy on here somewhere that was making TOP style pods for the REV8?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 02-24-2016, 07:59 AM   #934
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
I am looking for ride height spacers and caster spacers for the old school FE.. What are you guys using for this?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 02-26-2016, 08:56 AM   #935
Ride height shims CRC 4262
Caster and camber... I was using tape stuck to the bottom of the arms.
Old 02-27-2016, 12:33 PM   #936
Trader Rating: 42 (100%+)
Hey guys ordered my first Speedmerchant Rev8 Pro. What's good spares and tuning parts to have for this car?
What Spurs fit the IRS axles best? Coming from XRay, tired of sloppy front ends.
Thanks!
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 02-27-2016, 01:17 PM   #937
TOADYY's Avatar
Send a message via AIM to TOADYY
Thanks!
The same spurs you use for your x-ray will work.
TOADYY is offline   Reply With Quote
Old 02-27-2016, 03:02 PM   #938
Thanks!
Replace the stock upper turnbuckles on the front end, they bend easily. The stock ones are 3x19mm.
Other spare parts to get would be sidelinks, plastic front end parts aren't a bad idea to have spares of. The front end is pretty bulletproof though.
Xenon, RW, PRS or Xray spur gears all fit fine.
Old 02-27-2016, 04:22 PM   #939
Thanks Adam and Toadyy.
Adam it's been a minute since I seen you last at the Ho-B-Max- I see you haven't lost any speed hope to see you guys there again soon.
Aaron Moore
Old 02-28-2016, 02:37 PM   #940
Drew Manzella's Avatar
Trader Rating: 27 (100%+)
Only part I have ever broken on mine is a side link. Once.
I've ground up a couple spur gears however.
Things I would keep in my box if I were prone to breaking shit:
  • Pair of upper arms
  • Pair of lower arms
  • Pair of side links
  • Pair of steering turnbuckles (complete with ball cups)
  • Pair of steering ball studs
  • 4 or more axle/hub bearings (they go bad - tons of side loading on them - but this is true on any 12th scale)
Granted I carry bearings, spur gears and now a pair of side links but nothing else listed above. I have however replaced the following:
  • Stock turnbuckles with titanium (steering and camber)
  • Stock inner (servo) ballcups with Associated
  • Servo ballstuds with Associated 3mm
  • Stock steering block ball studs with CRC 13615 aluminum pivot balls
  • Stock axles with Associated
So the stock takeoffs are in my box.
As for option stuff - I have all the Associated center/front springs as well as a complete set of RSD front/side/center springs but to be honest I have never felt the need to change the springs from what the car came with originally.
I run CRC spur gears because I like the 16 smaller balls over the 12 larger balls. I run TKO diff rings.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Old 03-04-2016, 10:43 AM   #941
Thanks Drew!!!
Aaron Moore
Old 03-18-2016, 03:16 PM   #942
Conrad's Avatar
New to the old skool front end, any tips or advice for front spring changes?
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 03-18-2016, 03:36 PM   #943
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Use SpeedMerchant springs .018" or .020", Polish king pins, or use Zenon hard coated pins
4* caster
.5* camber
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 03-21-2016, 02:33 PM   #944
Conrad's Avatar
I was actually asking about assembly Sir the double e-clips is just a pain in the ass. How about using grubs screws and filing a flat on the kingpin?
Old 03-21-2016, 05:56 PM   #945
I'm sure there are other options out there
A flat spot on the kingpin would help, but e-clips are pretty easy
