Like Tree9Likes
Old 01-25-2015, 11:11 AM   #631
RBLove's Avatar
Trader Rating: 72 (100%+)
Stock shock leaks oil worse than an old car.
RBLove is offline   Reply With Quote
Old 01-25-2015, 12:32 PM   #632
LonnyJ1950's Avatar
When HB shock became impossible to find, I switched to Silva shocks and never had a problem with leaks. My Serpent shocks however need rebuilding after nearly every heat.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-25-2015, 12:58 PM   #633
DesertRat's Avatar
You could get a CRC shock and a little brake cleaner takes the anodizing off.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 01-25-2015, 03:53 PM   #634
The stock shock is fine.
I've heard the complaint of the rubber o ring vs the silicone one in the HB. You can use the same o ring as the HB one in the silva shock you just need to add some shims to get the right pinch on it to seal it properly as its slightly smaller than the stock rubber one.
JoelV is offline   Reply With Quote
Old 01-25-2015, 08:41 PM   #635
Josh-n-ya's Avatar
Trader Rating: 74 (100%+)
Finally finished the build. I was missing the center spring and a few shims. The ball studs that hold the tubes were to short. Other than that I cant wait to run it.
Josh-n-ya is offline   Reply With Quote
Old 02-09-2015, 07:33 AM   #636
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
TQ & Win at the Roar Region race Hosted by TQRC
13.5 SS
Rev8 was just awesome to drive on this twisty little circuit
Will post setup this week
+ YouTube Video
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 02-09-2015, 09:36 AM   #637
DesertRat's Avatar
Makes me wish I had made the drive out, even with work on Monday.
Old 02-13-2015, 09:48 AM   #638
Josh-n-ya's Avatar
Anyone know what servo will mount up in front of battery on inline position? My 9650 will only mount on opposite side with hole provided. Thx
Old 02-13-2015, 11:34 AM   #639
RBLove's Avatar
Quite a few of us use shoe goo to keep our servos in place. . No need for mounts and it holds. I have always done it this way.
Interested to hear people's thoughts on inline vs. transverse. Do you find that transverse provides more steering, but inline is faster in the corner? Do you run one over the other based on grip level?
Old 02-13-2015, 11:36 AM   #640
The cars are drilled the same on both sides to accept a s9650.
Old 02-13-2015, 11:52 AM   #641
Trader Rating: 85 (99%+)
Rob,
In low grip you want to run the car transverse. In high grip you want to run the car inline.
Sponsors
Awesomatix USA, Roche USA, LRP USA, EA MOTORSPORTS, Ko Propo, TQ wire, GENESIS RC, Serpent USA
tony block is offline   Reply With Quote
Old 02-13-2015, 02:17 PM   #642
Trader Rating: 11 (92%+)
Ive tried inline vs transverse several times. I've found that the car transfers more weight while cornering in transverse. Currently my 17.5 car is transverse and 13.5 is inline. Both cars are setup identically except tires and they drive very similar. I raced the regionals at tq last weekend and it was easier to switch between cars than I thought.
Congrats to Dave, well deserved win
Dillon Hoffman
Dillon71 is offline   Reply With Quote
Old 02-13-2015, 03:15 PM   #643
Josh-n-ya's Avatar
Actually it's not. Not on this new chassis. Even this new chassis I have with a recent purchase does not have any holes drilled so I can rotate the center shock mount. Tried to flip servo and holes don't even line up plus they are offset. I'm beginning to think I got a defect.
Old 02-13-2015, 03:19 PM   #644
Josh-n-ya's Avatar
I had a rev 8 not to long ago that had holes drilled to move center shock and different shock top plates. This new kit did not include those. Like the car but this sucks.
Old 02-13-2015, 03:19 PM   #645
The holes are differnet on my cars aswell. The left fit my rsx12 and futaba on the right.
Dillon Hoffman
