Old 01-04-2015, 03:28 PM   #616
Josh-n-ya's Avatar
Trader Rating: 72 (100%+)
Well sold my Rev8 a few months ago and regretted it ever since. So I got another one ordered. Live and learn I guess. New carpet track coming soon. Any suggestions on tire combo on new track? As stated below me, I may be dumb but I'm not stupid! I know what car to go back to at least.
Josh-n-ya is offline   Reply With Quote
Old 01-04-2015, 03:33 PM   #617
gazza's Avatar
What class are you going to run? For 17.5 on new carpet, I'd start with blue fronts & green rears
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC˛ Racing, Hobbywing North America
gazza is offline   Reply With Quote
Old 01-04-2015, 04:06 PM   #618
TOADYY's Avatar
Send a message via AIM to TOADYY
Where will the track be located at in NorCal@
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 01-04-2015, 04:37 PM   #619
wingracer's Avatar
Trader Rating: 22 (100%+)
Blues all around to start with some green rears and double blue fronts to try if needed.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-04-2015, 07:23 PM   #620
Josh-n-ya's Avatar
17.5 and not at Norcal. Stockton fairgrounds. Never heard of these blue green tires before. interesting!
Old 01-04-2015, 07:30 PM   #621
TOADYY's Avatar
Happy to hear the rug will be returning to Stockton. I just might have to make a trip up there since I have family in the area. Let us know what the schedule will be.
Old 01-04-2015, 10:31 PM   #622
Josh-n-ya's Avatar
First scheduled race is Feb 7th. Tire sauce to be determined yet. Have a feeling its going to be pretty good turn out. Lots of pan car guys been wanting a rug for the last few years. I know I have. I don't even want to run sedan. Ive been thinking on what to sell so I can get a WGT again too. I will just wait and see how this PANS out.
Old 01-07-2015, 05:35 PM   #623
Josh-n-ya's Avatar
Does anyone know if Bruce is on Holiday Vacation? Hope I don't have to wait too long for my kit.
Old 01-18-2015, 05:14 AM   #624
celt's Avatar
Default Wow...
Unfair advantage this chassis is.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 01-23-2015, 11:57 AM   #625
Josh-n-ya's Avatar
Originally Posted by Josh Cyrul View Post
Here's the pics I said I would post...
Anyone know where to get Aluminum standard thread screws? Maybe a set?
Old 01-23-2015, 12:04 PM   #626
Josh-n-ya's Avatar
wingracer - CAD files could be arranged..... lol...
Kave - My set-up here at the Champs in Mod was similar:
.018" Front Springs
Yellow Kyosho 15k grease on the kingpins
.5mm behind the lower arm (widen the front - no axle shims)
.5 camber
4 degrees castor
40mm Ulti - JH front tires
3.4mm ride height
35wt Losi in HB Shock
AE Blue center spring - top plate has additional .5mm spacer under standard pivot ball
Roll center lowered to only .5mm shim (no 1.5mm cone washer)
.022" Side springs
Green Spooge in the tubes
171.5mm rear width
41mm Ulti - XS rear tires
3.6mm ride height
Protoform AMR-12 body mounted centered in the front wheels
D4 3.5 with timing on the motor @ 20 degrees - 25/94
I'll work on posting pics and set-up sheets here and on my FB ASAP.
The 15k Kyosho was something I always ran on my cars and I switched to it at the race for the first time on the SM car. If you hit a kingpin hard/fast the Green Spooge tends to sheer and not give much "hard bump" dampening. The Kyosho is a little lighter but still gives good dampening in this situation. For bumpier tracks like this, it seemed to help out a bit but in most cases, the Green Spooge works really well.
Any other questions, let me know. I'll try to be more active on here.
Do you have a part number and where to find the HB shock?
Old 01-23-2015, 12:06 PM   #627
TOADYY's Avatar
This is the upgrade, but it is currently out of stock.
http://www.reflexracing.net/Team-Pri...et_p_2232.html
Old 01-23-2015, 12:09 PM   #628
gazza's Avatar
Good luck finding an HB shock! Save yourself the trouble and get a Team Prime shock. Also, for aluminum fasteners, just go to the fastener express site and get what you need
Old 01-23-2015, 02:07 PM   #629
LonnyJ1950's Avatar
Aluminum screws
http://www.fastener-express.com/alum...s-washers.aspx
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-25-2015, 10:32 AM   #630
What is the appeal to a HB or prime shock over the stock silva shock?
JoelV is offline   Reply With Quote
