Like Tree9Likes
Old 11-04-2014, 07:02 PM   #541
Trader Rating: 1 (67%+)
Send a message via AIM to racer034life
I have a few questions. 1) I emailed Bruce about an update for my Rev6 to the Rev 8. I haven't gotten a email back or anything. Are they still making the conversion kit or no? 2) what center springs are you all using, I.e what company Crc,A.E, or other also new to SM cars what spares should I keep in my pit bag?
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 11-04-2014, 07:52 PM   #542
gazza's Avatar
Answer 1-not sure if the conversions are still available. Answer 2- currently running an Associated blue center spring, but I carry springs from Windtunnel in 8#(assoc silver) to 12# just in case. Definate spares would be titanium turnbuckles(18mm lunsford for the upper part of the front susp.) to front axles( I put lunsford axles in) to side links, though I still have the CF links, not sure about the molded ones since I don't have them on either car yet
Kyle Majikas E-Town posse, Pro One R/C, TQ wire, SpeedMerchant, MC˛ Racing, Hobbywing North America
gazza is offline   Reply With Quote
Old 11-04-2014, 08:22 PM   #543
Trader Rating: 11 (92%+)
17.5 and 13.5 rev8's are race ready
[IMG][/IMG]
Dillon Hoffman
Dillon71 is offline   Reply With Quote
Old 11-04-2014, 08:33 PM   #544
I've had really good customer service with speedmerchant (emails ect) so I'm sure you'll get a reply soon.
I've only ran associated springs
Rev8 is my first 1/12, a lot of people told me that 1/12's in general are brittle - easy to break. I've sent mine hard into the boards at full speed and the worst was a bent axle. It's been said the stock tierods are weak so replaced mine Lunsford from the start.
Dillon Hoffman
Old 11-05-2014, 02:48 PM   #545
Ok so thank you very much. I will email bruce again to see about the conversion. Also whats a good baseline set-up?
Old 11-05-2014, 05:12 PM   #546
I started with Daves iic setup, from there I went up to 20k in the side tubes and 35 in the center shock.
http://www.petitrc.com/reglages/spee...ger_Vegas2013/
Dillon Hoffman
Old 11-05-2014, 05:34 PM   #547
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Josh's setup from the Mile High Indoor Champs is likely the best place to start, it's on the SM website.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 11-05-2014, 05:47 PM   #548
http://teamspeedmerchant.com/graphic...v8MHIC2014.pdf
front .2mm higher than rear, is that a typo?
Dillon Hoffman
Old 11-05-2014, 06:09 PM   #549
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Setups
http://www.petitrc.com/reglages/spee...chantRev8.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 11-05-2014, 06:55 PM   #550
avs
avs's Avatar
it seems like an interesting balance of more camber, soft front spring and stiff rear spring? Jeff Fink pointed that out to me.
I tend to always run a little rake like 0.2mm less in front. but with that setup, maybe a little less weight on the front end balances out the other settings?
Tony Shimko
avs is offline   Reply With Quote
Old 11-05-2014, 08:14 PM   #551
It's perhaps worth noting that he ran the same setup in stock/13.5/mod so the camber could partly have been needed in mod even if not needed in 17.5.
That being said, I've been running the same setup with a little forward rake of about .2-.4mm and .75-1deg of camber and I have been VERY happy with it.
Old 11-07-2014, 07:58 PM   #552
Ok so I can't get w straight answers on the conversion kit....? What's up a brother needs a a conversion kit
Old 11-07-2014, 08:38 PM   #553
TOADYY's Avatar
Send a message via AIM to TOADYY
I think you might be better off buying a new complete kit since a lot has changed since Rev 6.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 11-08-2014, 07:45 AM   #554
From a 6 to an 8 is quite the change.
New carbon
Offset diff hub.
Front end
Longer side links.
New pod plates.
Essentially the only thing you'd be reusing is hardware, shock, pivot balls, rear axle, springs. If you add it all up its more worth it to just get a kit. There were rev 7 conversions but once we ran out of that style 4 bolt top pod plates and the front ends finally came in it really is more value to just get a new kit there as well.
JoelV is offline   Reply With Quote
Old 11-10-2014, 04:09 PM   #555
Trader Rating: 55 (100%+)
Ready for Sunday
Jamison R is offline   Reply With Quote
