Like Tree9Likes
Old 09-26-2014, 09:04 AM   #511
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by JoelV View Post
Roadkill is gonna be insane.
Oh, It is!
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-26-2014, 09:45 AM   #512
BardSmith's Avatar
Trader Rating: 61 (98%+)
Originally Posted by RedBullFiXX View Post
Where is the rear pod brace
It looks more NEATO with no holes... Tamale
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 09-26-2014, 11:10 AM   #513
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Nice
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 09-26-2014, 12:16 PM   #514
If those are pod plates you got from me, email me your address and I will get a correct set out to you asap
team_tamale is offline   Reply With Quote
Old 09-26-2014, 10:53 PM   #515
Cool
Rev8 noir
itchin to get to vegas
Old 09-27-2014, 10:29 AM   #516
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Rev8 noir
Hey Dave man it look sweeeeeeeet
your servo sitting flat and mine sitting an angle there's difference does to the steering?
what's your gearing for 13.5?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 09-27-2014, 09:25 PM   #517
I've never run an angled servo with a SpeedMerchant
Works awesome flat with the links angled back
Old 09-29-2014, 10:26 AM   #518
They're here.
Old 09-30-2014, 09:48 AM   #519
My build is coming along nicely. Ordered some Lunsford "accessories" for the front end camber and steering turnbuckles. Just because I have the ability to bend things that should not ever bend, mind you. I hope to have it running this weekend and get a real setup started.
Old 09-30-2014, 07:17 PM   #520
avs
avs's Avatar
Originally Posted by srad1 View Post
Hi Guys,
Just wanted to post some setup info from testing this weekend, my car was pretty choice, super easy to drive.
Front:
.19 springs
.5 deg camber
4 deg caster
3.2mm ride height
Rear:
.20 rear springs
Green Lube in the tubes
Blue center shock spring
3.4 mm ride height
Protoform AMR-12
Reedy 3.5T 25/94
Tires were Pro-One, Blue F/ Blue R
thx,
Steve Radecky
the past few weeks I have tried a .018 front spring with .020 rears, the rest pretty much the same as above but 1.0 degree front camber and 17.5. I liked the way it felt, very controlled. but I am losing time in corners where the car seems to dig in and lose speed. I like how the car behaves except that I am losing time. I noted Josh Cyrul's setup and others are also running 18 fronts. the grip is pretty high at times, the carpet is a few years old and has a lot of stuff built in it.
I get around faster with a 20 or 21 front. is there a driving style/skill that i need to develop to use the softer front? are you using exponential and a slower turn in to drive it thru the corner? these 1/12 cars get thru the corner so quickly it is difficult to imagine steering more slowly and still making the corner.
Tony Shimko
avs is offline   Reply With Quote
Old 09-30-2014, 09:37 PM   #521
PutAwayWet's Avatar
Josh has a driving style, and you know he knows a TON about setup. So, you can bet his car suits his particular preferences. Don't be put off your own conclusions. Nothing you're describing sounds off the reservation; fast setups with 0.20 or 0.21 front springs are not uncommon.
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 10-01-2014, 04:15 AM   #522
avs
avs's Avatar
Thanks, I guess my fastest just isn't fast enough, my lap times are always off about .5 sec from the front runners. I was trying a different path to get past this flat spot.
Tony Shimko
Old 10-07-2014, 08:16 PM   #523
occ
Trader Rating: 15 (100%+)
Just received my Rev 8. Cant wait to build it!
Anyone know what servos fit perfectly.
I see there are two different mounting options.
occ is offline   Reply With Quote
Old 10-07-2014, 08:53 PM   #524
Futaba 9650 bolts right in
Old 10-09-2014, 09:07 AM   #525
Anyone have the rundown of what happened to the SM cars in Florida? I watched Josh's last quali and his main and looked like the car just stopped and was picked up in the main unless I missed a big impact on the Live RC feed.
