Like Tree9Likes
Old 08-05-2014, 07:42 AM   #421
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Originally Posted by RedBullFiXX View Post
SpeedMerchant Sweeps the 2014 R.O.A.R. Asphalt Nationals
Nice work guys
Now if Bruce would just respond to emails we would be good!
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 08-05-2014, 07:50 AM   #422
Send a message via ICQ to JiuHaWong
Any ETA on the Rev8 Pro's with the new front end?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 08-05-2014, 08:51 AM   #423
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
I believe Bruce is cutting RoadKills this week
But soon
Be patient
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-10-2014, 04:23 PM   #424
The Xenon Racing kingpin will fit the new school front end. Dimensions are the same, the Xenon one is titanium nitride coated.
http://xenon.ocnk.net/product/461
avink007 is offline   Reply With Quote
Old 08-11-2014, 06:33 PM   #425
Trader Rating: 26 (100%+)
Hey Guys,
I havent run asphalt 12th scale since I was a kid running 6-cell way back in the day. The Rev 8 was awesome on the asphalt. Set-up really isnt that different from carpet:
Front:
Speedmerchant .18 springs
Green lube on the kingpins
1 degree of camber(could have been 1.5, but was trying to keep the tire wear flat
4 degrees of caster
4mm of ride height
Ulti Hard front tires (Started at 42.5)
Rear:
35 weight oil in the shock
Flat rear pod, no droop
.20 rear springs
Green Lube in the tubes
Blue center shock spring
Ulti Medium Rear tires (Started at 43.5)
4mm ride height
Protoform AMR-12 body
Car was super easy to drive. I could have went the whole weekend on 1 set of rear tires, went through 3 sets of fronts. The Ulti tires are the hot ticket.
Trinity D4, geared 80/51.
Steve Boice
Sponsored by: Speedmerchant, Trinity/Revtech, Destiny, Protoform, Hobbywing USA, KO Propo, Ulti, Xenon, TQ Wire
Hyperform racing--In memory of Lino
Bigdaddyswank is offline   Reply With Quote
Old 08-11-2014, 06:43 PM   #426
EDWARD2003's Avatar
Where in the world can you get Ulti-tires from? I'm living in the country where ulti tires are made from and it's impossible to find them.
EDWARD2003 is offline   Reply With Quote
Old 08-11-2014, 06:52 PM   #427
http://www.shop.kopropoamerica.com/i...roduct/special
From Ko Propo USA!
Steve Boice
Old 08-11-2014, 07:19 PM   #428
EDWARD2003's Avatar
Found them, had to do some digging.
http://www.creationmodel-shop.com/SH...4011/list.html
Boice - What tires did you use exactly? Are they the same ?
Old 08-12-2014, 01:05 PM   #429
tim fry's Avatar
shop.cpdracing.co.uk/
Try here too
tim fry is offline   Reply With Quote
Old 08-13-2014, 06:39 PM   #430
SpeedMerchant's Avatar
Hi Guys,
They're up...
http://www.teamspeedmerchant.com/news.html
I'll fill'em as quick as I can.
Take care.-Bruce
SpeedMerchant is offline   Reply With Quote
Old 08-16-2014, 06:24 AM   #431
celt's Avatar
Default shock bottom cap
hey guys,
Posting from the RoadKill10 forum...
I might have accidentally jumped a thread on my plastic shock bottom cap. Matter of time before it blows oil.
Anyone have a recommendation on an aluminum or stock source replacement?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-16-2014, 11:00 AM   #432
Originally Posted by celt View Post
hey guys,
Muddslide have dampers and spares, check it out
http://muddslidemotorsports.com/irs.html
Old 08-16-2014, 11:23 AM   #433
Hi Stan,
The new cars (Rev.8, WGT4, RK10) come with the Silva HPS2 Shock.
Here are the parts...
http://www.muddslidemotorsports.com/silvaconcepts.html
Take care.-Bruce
Old 08-16-2014, 12:44 PM   #434
celt's Avatar
Originally Posted by SpeedMerchant View Post
Hi Stan,
Take care.-Bruce
Poifect!
Just what I needed...
Stan Garvin
Old 08-19-2014, 07:32 PM   #435
Sickness
