Old 03-30-2014, 10:23 AM   #256
Originally Posted by JoelV View Post
I'm going to steal James' tools or cars in Denver.
JamesL_71 is offline   Reply With Quote
Old 03-30-2014, 10:24 AM   #257
LonnyJ1950's Avatar
Droop is completely controlled by the length of the shock. Max droop (what you measure) occurs at max extension. Sag is controlled by spring preload.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 03-30-2014, 10:44 AM   #258
avs
avs's Avatar
Tony Shimko
avs is offline   Reply With Quote
Old 03-30-2014, 10:51 AM   #259
You watch Bruce prepare a car. There will never be a measurement of droop or sag.
JoelV is offline   Reply With Quote
Old 03-30-2014, 02:21 PM   #260
avs
avs's Avatar
I get that one can develop an eye for these settings, but one first needs to calibrate their eyes to something. thus the need to communicate settings with numerical values.
Tony Shimko
Old 03-30-2014, 02:29 PM   #261
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks guys for the discussion...I've always been confused by this.
Lonny and avs...thanks, this explains alot for me.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-04-2014, 08:16 AM   #262
Herminator's Avatar
Send a message via ICQ to Herminator
Any shimming guides for the new school front end?
Herminator is offline   Reply With Quote
Old 04-04-2014, 04:04 PM   #263
avs
avs's Avatar
maybe someone can correct if I am mistaken, but I don't see a place (or need) for a shim just yet. the alloy steering block is fixed on the kingpin with a setscrew. the droop can be controlled by where the block is fixed on the kingpin. out of the box, the spring produces no droop, it will need to sack a little before there is any droop to deal with.
if you were using the old oldskool steering block and the kingpin with e-clips that locate the block, then shimming out droop (or refreshing the springs) could be needed.
edit: Ha! it just hit me that you may have been asking for guidance on how much droop, not how to set droop. for now (or until i put in a shorter spring or longer kingpin), the basic assembly has enough preload to have no droop. it did seem a little stiff steering so maybe the springs need to wear in a little?
Tony Shimko
Old 04-04-2014, 07:41 PM   #264
Bingo... This is exactly how I am adjusting preload/droop on the New Skool front end. Im only running an eclip on the bottom of the kingpin, under the spring, as well. This makes relubing the kingpin a snap.
Old 04-07-2014, 06:38 PM   #265
I just wanted to drop a note in here to let you Rev8 owners know that I have a limited run of 12th scale only rear pod plates for the Rev8. These have ride height adjusters that are lowered 3mm from the standard pod plates. This results in a slight reduction in weight and lower CG. See the attached pic. Those interested can contact me at teamtamale@tx.rr.com for availabilty and price.
team_tamale is offline   Reply With Quote
Old 04-14-2014, 09:27 AM   #266
Congratulations to Josh Cyrul for TQing and winning at the mile high race with his new Rev 8's!
avink007 is offline   Reply With Quote
Old 04-14-2014, 10:13 AM   #267
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey Guy's Congrats on your victories at the Mile high race.
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 04-14-2014, 12:36 PM   #268
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Josh
TQ & Wins in
WGT
17.5
13.5
Mod
& Mod Sedan
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-14-2014, 02:06 PM   #269
JayBee's Avatar
Damn!! Josh must've put on a clinic!! Congrats!!!
Has this been done b4?
Old 04-15-2014, 04:59 AM   #270
Jerry P's Avatar
Trader Rating: 44 (100%+)
Congrats to Josh and the Speedmerchant crew.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
