New Shock Shaft Design?
I was wondering if this has been tried or thought of before:
Putting a hex at the very top of the shaft to speed up and simplify building them.
I personaly hate screwing on the cups and dread rebuilds because of this.
Even with a tap screw, its still a pain since everything is coated in oil making it even more difficult to get a hold of the shaft. And if you make a mistake, you scratch the shaft. I even tried those Tamiya non scratch pliers. They suck, save your money.
I included a picture to illustrate what I mean.
So whats up?, Animaniacs Style:
"Good Idea, Bad Idea?"
i think losi have done this on the jrxs shocks
Yokomo had a similar design on their shocks when they released the YZ870C Dogfighter (1989).
The piston end of the shaft was threaded, so the piston was held in place by a small nut. Better still, the other end of the shock shaft (the spring retainer end) had no thread - the alloy spring retainer simply pushed on and was held in place by a grub screw going through the side of the spring retainer.
With this design the shocks were always exactly the same length
scooby...It's a great idea, but manufacturing cost would be much higher. Would be a great aftermarket product from a manufacture
Integy makes a nice set of shock shaft pliers number INTC22353 I have these and they work really well... there around 20.00
Originally Posted by Jon Kerr
Gee, I wonder who could do that kind of machining.
are you thinking who i'm thinking of?
P Dub:
Definitely an aftermarket part. I know manufacturers wouldn't want to do it for free. But hey, I would gladly pay extra for these. I know many people would.
I can't see how manufacturing these things would be THAT much more involved. After all, putting a hex at the end of it would pretty much make it a precision screw!
i can only see 1 extra step.
instead of threading the outside of the shaft..simply drill a hole (doing this instead of the thread on outside of the shaft) and then thread that hole......then include a screw with the kit.
i don't see how drilling a hole can be expensive
The area where the hex part meets the round shaft would become a stress riser and the shaft would snap there is the shaft is hardened or bend there if it is not.
It is a great idea but the shock shaft is so highly stressed in crashes that this would not be a practical thing to do.
adrian...sign on aol
