Old 09-28-2014, 04:59 AM   #1441
slakr's Avatar
Trader Rating: 25 (100%+)
Need a little taller rear body post for my USGT body... any ideas???
XRAY XB2, XB2T ~ TLR 22-4 2.0 ~ Mugen MBX7TR Eco ~ JQ THE eCar WE, THE Car WE
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 09-28-2014, 05:43 AM   #1442
theproffesor's Avatar
Trader Rating: 45 (100%+)
Hot bodies will work. But the holes are smaller and youll have to remove some material at the bottom to clear the camber link.
Option 2: get a custom tower with body post holes 5mm higher from bezerk rc on face book.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-29-2014, 06:45 AM   #1443
academygaz's Avatar
My Dynamics before its first run last Friday. Very rusty driver meant I didn't learn much other than boosted 17.5 is a lot of fun
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 10-01-2014, 10:05 AM   #1444
Running the D06 in USVTA and have come up with a decent starting set-up for med-high grip carpet. I also did a swaybar mod to make sway tweek easier. I cut the sway bars back 10mm front and rear, and used ARC parts to finish it off. The rear uses Medium legnth ball studs and long in the front. The links on the sway bars are ARC sway links.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 10-01-2014, 12:13 PM   #1445
ATLASCOPCO's Avatar
Done the same on my xray
It's a great modification
ATLASCOPCO is offline   Reply With Quote
Old 10-01-2014, 12:53 PM   #1446
patorz31's Avatar
I am doing this to my DO6 but using Durango parts. Easier to get get here.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-03-2014, 11:32 PM   #1447
Akhor's Avatar
Just wondering if anyone has an idea about the following issue.
When my vehicle comes out of a corner and you get back on the gas, the rear end snaps around.
I increases my rear shock oil from 350 to 500 and that made a huge improvement...
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 10-03-2014, 11:50 PM   #1448
erchn's Avatar
Standing up the rear shocks or a stiffer rear bar may be a better alternative. Good luck. :-)
erchn is offline   Reply With Quote
Old 10-04-2014, 12:00 AM   #1449
Photocycler's Avatar
Trader Rating: 33 (100%+)
I was also chasing a similar issue, turned out I needed to tighten my belt. Make sure both belts are equally tight and it should fix the issue
Photocycler is offline   Reply With Quote
Old 10-04-2014, 02:05 AM   #1450
Fredp1's Avatar
Really need some details on the setup of the car and track surface.
With our cars running 21.5 turn motors, we found on a very low grip track, too much weight gets transferred to the front of the Car on entry of the corner, under brakes. Decreasing droop on the rear helped. Screw in the droop screws 1/2turn and see if that helps.
Also the diff oil weight is important. On my track, had to run 700cst. On heigher grip track 1000-3000 is needed. The lower the diff oil cst, the softer the power is applied on corner exit.
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 10-04-2014, 02:58 AM   #1451
ATLASCOPCO's Avatar
To much punch
Try adjusting your speedo settings
This may help ��
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 10-04-2014, 07:59 AM   #1452
Akhor's Avatar
Thanks for the ideas! I'll give them a try.
If anyone is interested, I've made a gearing chart for easy reference.
VBC Gearing Chart
--Blaine--
VBC D07, VBC D08
Old 10-04-2014, 12:44 PM   #1453
patorz31's Avatar
OK I just installed the aluminum chassis. So what do I have to do different with setup compared to the graphite? Is there a good baseline setup for the aluminum chassis?
Old 10-04-2014, 01:24 PM   #1454
The alumninum is stiffer so it wont flex as much as the graphite. So youll need to soften the suspension up some. How you do that is up to you.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 10-05-2014, 02:05 AM   #1455
ATLASCOPCO's Avatar
Has anyone had an issue with the chassis breaking at the front around the bumper area
I can't seem to see any kind of bumper brace??
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
SEO by vBSEO 3.5.0
