Old 08-16-2014, 12:38 PM   #1336
Potoczak's Avatar
Trader Rating: 107 (100%+)
Originally Posted by frk View Post
Hi guys
a question to all owners of the D06. I have a HB TCXX, now I'd like to buy a vbc. Someone tells me that a Xray is better because "turns more round". What about the ability of steering? I read that to get more steering you must cut a small plastic part of steering blocks...Your impressions of how the model turns?
Thank you
The d06 has ALOT of steering. I've always had to dial it out.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 08-16-2014, 01:31 PM   #1337
Photocycler's Avatar
Trader Rating: 33 (100%+)
Question on the ghost vs. D06
If u ran my d06 first with a vta body and decided to get a ghost..Any chance the body holes would line up?
[evan b]
Timezone I & II | RoseCityScaleRacing | Premier RC Raceway
Photocycler is offline   Reply With Quote
Old 08-16-2014, 02:02 PM   #1338
theproffesor's Avatar
Trader Rating: 45 (100%+)
The front line up fine, but the rear are 10mm forward. I had to re-drill the holes. Its fine. They are far enough forward that the holes dont touch.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-17-2014, 04:48 PM   #1339
Hey guys, I will be placing my order this week for the VBC car. I have been reading the threads and looking on the fb pages and was just wondering whatpeople are liking more. I saw that there are new hubs coming out, and I also saw that people are doing the "active toe" in the rear. who all has done that and what have they noticed in the handling. Does this make it so you dont have to buy additional rear blocks?Looking forward to the build, will post pics when its done! thanks guys
WEEZY is offline   Reply With Quote
Old 08-17-2014, 11:27 PM   #1340
Korey Harbke's Avatar
I only tried the variable rear toe for a single battery pack. I didn't care for it at the time, so I removed it from my car. I need to do a more extensive test session sometime in the near future.
It still doesn't replace toe blocks, as you need them to change the overall width of the car as well.
Hope that helps!
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 08-18-2014, 12:26 PM   #1341
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
My D06 is in the for sale section if anyone's interested.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-18-2014, 02:58 PM   #1342
Just received my vbc and what car to build exellent quality.
___________________________
TC6.2
VBC D06 MM FLETA PRO MM FLETA ZX 4.5
HITEC SPEKTRUM SAVOX
onroad racer is offline   Reply With Quote
Old 08-18-2014, 05:22 PM   #1343
Bar
Hope that helps!
-Korey
do you know if VBC has anything to do with Roche as the driveshafts and shocks look very similar?
Luke Burr
Bar is offline   Reply With Quote
Old 08-19-2014, 07:24 PM   #1344
After the first outing with the Dynamics 06 all I can say is wow. Right out of the gate it was a great handling car. Carries way more corner speed than my Ghost does. Definately going to have to get used to it. Car responds to small changes in set-up very well. Just need a couple more track days to get it dailed in. I have one issue though; while I really like the look and functionality of the 06 front bulkheads and swaybar mount over the 05, I dont like how there is virtually no way to brace the front bumoer brace against them. If you use the plastic bumper brace in the 05 kit, there was about 1mm of space, then a solid platform to transfer front impact load to the chassis. The 06 lacks this. Is there any mod or parts to brace the front bumper to the hulkheads?
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 08-21-2014, 12:07 AM   #1345
what spur and pinion is a good starting point for 17.5 blinky
jon may is offline   Reply With Quote
Old 08-21-2014, 01:02 AM   #1346
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
What motor you running and how big is your track?
Dan is offline   Reply With Quote
Old 08-21-2014, 01:51 PM   #1347
is a big in door carpet track I will be using a reds vx 17.5
Old 08-23-2014, 09:03 AM   #1348
whityboy's Avatar
well we tested last week with active toe in and i think it is really a good option to try.
the car was superfast and stable and were able to win the national in the stock 10.5 class. we used a raceberry flex chassis with extra hole's that make it easy to use this. using this makes the car in stock also faster on the strait with only 1 toe inn and when active go to 2. only difficult part in this mod is redrill the frontarms. if someone liks to try schoot me a pm and i explane every step
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 08-23-2014, 09:22 AM   #1349
ZZracing's Avatar
Send a message via Skype™ to ZZracing
Stainless steel Screw Set For Vbc WILDFIRED06(98):http://www.rzhobby.com/stainless-ste...698-p-663.html
ZZracing Titanium screws /Hobby Wing /Savox /Nvaracing / Star racing/Novarossi/Sanwa/Castle/Xcore/Yeah Racing/Tianhao UFO/Q-World/Venom/Orion/Sky Rc
Email:zzracing@126.com zzracing@foxmail.com
www.rzhobby.com www.zzracing.net
ZZracing is offline   Reply With Quote
Old 08-26-2014, 01:41 PM   #1350
mcdomdom's Avatar
Hi guys,
I've a question about the P05 suspension block for the wildfire D06.
Is the P05 block wider or narrower than the P00?
Ansteht question depends on the latest setup sheets i saw.
The most of them drives the car very narrow in the rear, what is the reason for that and what effect did it have?
Thanks for your help and greetings from Germany
Dominik
VBC Wildfire D06, LRP SPX Zero, Thunder Power 13,5T, Reedy batteries!!!
mcdomdom is offline   Reply With Quote
SEO by vBSEO 3.5.0
