*NEW* WILDFIRE D06 Touring Car from VBC RACING
#1277
#1279
No Saver. I run the yokomo alum servo arm, no issues.
#1281
Looking for a motor fan for the VBC, currently have a ORCA ESC and motor, will this fan work
http://www.tqrcracing.com/shop/produ....asp?p_id=2334
#1282
#1283
http://gridworksracing.com/shop/r1-w...an-8-4v-r1033/
#1284
Check out these fans from gridworks.
#1285
http://www.teameamotorsports.com/ind...product_id=100
#1286
Ok guys, thanks for your help. We are nearing the end as the car is now done but I have one question...
WIth the ORCA 17.5 it seems the motor shaft is sticking so far out its hitting the belt. Do I just need to use a bunch of spacers to space the motor back or what other option?
#1287
I've spaced my motor out for 2 reasons.
1 - so I don't have to run my pinion "upside down" and so that I can get to the grub screw from the bottom of the chassis.
2 - rather than add ballast, pushing the motor out a couple of mm has helped with the L-R weight distribution of the car. The lipos I have are a tad on the heavy side.
