Old 05-31-2014, 02:09 PM   #1066
New alloy chassis released for D06
Lycan is offline   Reply With Quote
Old 05-31-2014, 05:05 PM   #1067
Richards Racing's Avatar
I know some makes are bringing them out on the car, after 42 years in the A/C industry metal takes so much force before it stays bent, had a guy at the Australian NSW Titles last week in a serpent clipped a piece of concrete which was a part of the track and it has been rippled the chassis, and he told me it was not a hard hit.
Yes I know a hit on the carbon fibre if hard enough will split the chassis. I would advise anyone too carry a standard one in the box just in case it happens during a race. The guy did say the metal one did give some better consistency.
Noel
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 05-31-2014, 05:19 PM   #1068
Do you run upper deck on asphalt?
BigCheezy is offline   Reply With Quote
Old 05-31-2014, 07:25 PM   #1069
Fredp1's Avatar
Originally Posted by Richards Racing View Post
I come from just north of Sydney Australia and race Friday nights at Castlehill in Sydney the surface is painted concrete low grip and some bumps attached is a youtube shot of the track. I run what we call sportsman which is 21.5 blinky.
http://www.youtube.com/watch?v=XYU94C1_xHc
Can anyone give me some hints on setup for this surface.
I will say I have built several makes Tamiya - HPI/Hot Bodies and Photon EX and I would say the D06 would have to be the best in build as to very little shimming when I have been use to a lot off shimming.
Noel
Hi Noel,
I'm looking at getting the boys a new car. The D06 is on the short list.
Just seeing if you managed to get a setup to work on the surface at castle hill?
How would you compare the d06 to the old car?
Fred
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 06-01-2014, 12:38 AM   #1070
Definitely.
Old 06-01-2014, 02:03 AM   #1071
MikeO's Avatar
Originally Posted by JayL View Post
You are welcome for me pitting next to you
Poorboy Raceway & Hobbies - Mo Speed!
MikeO is offline   Reply With Quote
Old 06-01-2014, 08:33 PM   #1072
theproffesor's Avatar
Trader Rating: 45 (100%+)
I was wondering if someone could tell me the difference in the 05 and 06 chassis. I have an 05 and want th aluminum. If its only the battery mount holes that are different then im in..
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 06-01-2014, 10:23 PM   #1073
Team VBC Racing's Avatar
The metal chassis will not work with the D05 or the Ghost cars. There are a lot of differences between the cars(bulkheads, motor mounts,)
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 06-02-2014, 12:24 AM   #1074
Originally Posted by Fredp1 View Post
Hi Noel,
Fred
The car is a great the build is great have got it going. it's about .2 behind Graham Steve and Greg which is because off me learning not to over drive it.
I still like my EX but Highly recommend the D06 to anyone who is looking for a new car.
Noel
Old 06-02-2014, 01:51 AM   #1075
midse's Avatar
Default D05 D06 Aluminium chassis and general D06 fan
Bezerk RC - https://www.facebook.com/BezerkRc
Any road chassis $80 Australian. Plus freight. Any weave/thickness carbon or spec aluminium.
I just used a Bezerk 2.2 (or thereabouts) stiff weave carbon chassis and standard thickness 45deg. weave top deck yesterday at Adrenalin-Arena/SERCCC here in Meolbourne - host of the Asian On Road Champ round in July. Promoted by none other than Scotty Ernst.
I did a PB- TQ and won using my blinky- I'd only also just put the car on a crash diet on Saturday and dropped the weight from about 1415g down to 1358g - The Bezerk "stiff" chassis was about 10g ligther than standard from memory. The top deck is similar shape to a D05 near the front bulkheads so in an attempt of reducing flex too. That's what I wanted for our track. The spur pulley edges on the topdeck need about 3-4 light chamfer passes on the bottom with a file just to take the edge off. Deliberately ordered that way for extra material and stiffness. If left unfiled the carbon/pulley only just touch and would take a lap or two to clean themselves up.
With the modded chassis and top deck the car had some slight initial flex but went really stiff/solid. It made the car very consistent and precise and I'd had only 4 hours sleep! My results and times reflected how much of an improvement it drove. The original standard chassis has been raced since new in August. 2-3 times a week since January!
I actually saw a prototype VBC team aluminium chassis at the track on friday night. I heard it hooked up and was great.
Bezerk R/C already has files to convert your wildfire into a d06 layout by moving the motor/spur mounts forward (using a vbc/xray/yoko rear belt) and new shock towers if you'd like. The owner of http://www.rabhobbies.com.au/estore/...cturers_id=515 actually still runs a very competitive D05-D06 hybrid as does another club member. They both say the car is excellent and technically a D06 aside from different shaped bulkheads and centre post.
I heard a Bezerk forward d05 chassis was sent to the owners of VBC and used in development of the D06.
FYI - I wouldn't recommend an aluminium chassis on anything but a high grip track - It will obviously require modification to your setup. I recommend trying a stiff weave carbon chassis. I can post my setup if anyone is interested.
PS my first real car was a 13 T4 but I bought my D06 from a local racer in November 2013 and raced it in 21.5 blinky - I immediately found it better to drive,setup and aesthetically that I sold the Xray. The D06 is just as tough as Xray and comes with some great features. I especially liked the larger range of gearing that can be fitted for blinky classes and the ease of belt adjustment. That sucked on the Xray. Come to think of it, 3 screw mounted solid alloy floating servo mount, double front joints included, thicker/stronger towers etc. are all great features over other brands let alone the affordability.
I placed 3rd in the state titles a few months ago (2nd went to a D06 too) driving has improved since then. With all the racing I have only just changed chassis, rebuilt diff and new bearings. I've kept all the parts as spares as they are still usable.
Great car
midse is offline   Reply With Quote
Old 06-02-2014, 06:50 PM   #1076
Gridworks Racing's Avatar
We have added Randy Caster's 2014 Reedy Open Modified Setup to our Website. Click the image below to check it out:
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 06-02-2014, 08:14 PM   #1077
Trader Rating: 23 (100%+)
Send a message via AIM to Max K
what do the Gridworks sway bar links look like?
RC America - Xray - Trinity - Revtech - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 06-03-2014, 02:04 AM   #1078
Randy Caster's Avatar
Found a couple pics of my car using the Gridworks RC links.
Old 06-03-2014, 02:05 AM   #1079
Apparently when posting from an iPad you can only post one picture at a time.
Old 06-03-2014, 03:24 AM   #1080
Trader Rating: 54 (100%+)
are those washers glued onto the steering knuckle?
Jamison R is offline   Reply With Quote
SEO by vBSEO 3.5.0
