Old 05-20-2014, 04:47 PM   #1036
Hi, I noticed when measuring the rear toe that mine has 2.5 degrees on the left side and 3.5 degrees on the right. It is a new kit and standard spec.
Has any one had the same problem and how do you fix it?
Cheers
jont is offline   Reply With Quote
Old 05-20-2014, 06:33 PM   #1037
Cheers
Hi, the Hinge Pin holders have the slightest amount of movement in them. Loosen the C0 ones off one side at a time and pull them out from the chassis with your hand while doing it up. This will set both of the inner ones to the same position. Now recheck toe, if still out the E30 block needs to be centered.
Lycan is offline   Reply With Quote
Old 05-21-2014, 02:26 PM   #1038
Cheers, got the toe even, now how do you measure the rear droop, the rear hub design gets in the way
Old 05-21-2014, 02:45 PM   #1039
Gridworks Racing's Avatar
Here is something from a previous page to address your question.
Originally Posted by Gridworks Racing View Post
What I do is set the car on 12mm blocks (Or whatever height) with the wheels removed and use a machinist ruler to measure up the center of the outer hinge pin. I then deduct the height of the blocks and am left with the droop # in mm.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 05-21-2014, 03:41 PM   #1040
Do Vbc make the red Spacer in that picture? They look nice. Wonder what the whole car would look like with them on. Hmmmm
Old 05-21-2014, 04:11 PM   #1041
theproffesor's Avatar
Trader Rating: 45 (100%+)
So how do I get my hands on those lightweight axle sets?
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-22-2014, 03:06 AM   #1042
Gents I need a little advise
If I use a standard 10mm Hudy droop block and measure droop under the pin on the front arm I can set it to the normal 5-6 for indoor carpet
What would you be setting the rear to under the hoop if I wanted the standard 4-5 droop?
I hope that makes sense lol
008-Racer is offline   Reply With Quote
Old 05-22-2014, 12:46 PM   #1043
At 5mm ride height, I believe most run the droop at 1mm when measured under the loop.
Old 05-24-2014, 10:15 AM   #1044
The VBC cars did well in round 1 of the 2014 Reedy International Touring Car Race of Champions with three cars in the top 10.
Gridworks Racing team driver Randy Caster drove his car to the top qualifying position posting a solid 5 minute run!
It is currently drizzling, so round 2 qualifying may be delayed a bit.
Old 05-24-2014, 11:33 AM   #1045
Potoczak's Avatar
Trader Rating: 107 (100%+)
Great job randy. Keep it up.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-25-2014, 12:22 AM   #1046
Do the D05 shock towers fit the D06?
Thinking of going back to older style (longer) shocks.
Old 05-25-2014, 12:40 AM   #1047
whityboy's Avatar
you only need towers that are 1 mm higher to use longer springs like yokomo and ride. i had the chance to test some from a teamdriver from a protoype car and really liked them. I asked bernd from raceberry to make me some. problem is that he has so much work the only will be ready in 6 weeks. you can also modify your schocks to use long springs
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 05-25-2014, 12:45 AM   #1048
Hi Whityboy,
Yeah mate, I've already done the mod but cant get under 5mm ride height in the rear. Would be keen on a set of those shock towers
Possible to post on here when they become available?
If they end up being thinner too might reduce cars weight and reduce COG?
I've always felt the current towers, although super strong and look awesome, are too thick/heavy.
Cheers
Old 05-25-2014, 01:36 AM   #1049
whityboy's Avatar
I had to order 6 sets, 2 for me 2 for someone i know. so maby i can send you one. Or everybody that is interessted can contact him so he can make more, don't know te price yet and don't know when thy are ready.
Old 05-25-2014, 03:57 PM   #1050
Yes please, definitely keen.
Cheers
SEO by vBSEO 3.5.0
