Old 04-15-2014, 02:44 PM   #916
Samwise's Avatar
Originally Posted by LloydLoar View Post
We held the Mile High Indoor Champs here at 5280 Raceway in Denver, Colorado this past weekend. I raced the VBC D06 in mod sedan, qualifying 8th and finishing 9th in the A-main. I am no sedan guru, but with some setup help from Dave Ehrlich and Keven Hebert, I got the car working pretty well (I just need to work on driving it!) Most of my changes were focused on making the car feel more 'direct' with more on-power steering, and I think we succeeded with those items. This was also the first big race using the new Gravity RC spec tires, which proved to be a great tire choice!
Changes from my usual setups include the following:
- Front diff with 2.5 million cst
- 0.5 mm shims under the front blocks, 1 mm under the rear blocks.
- 3 degrees of rear toe instead of 3.5 degrees
- 2 mm ackermann shim instead of 3 mm
Full setup sheet here:
http://chrishillier.com/wp/wp-conten...il_13_2014.pdf
Thank you for posting!
I'm going to try a similar setup here in Seattle at our last indoor race of the season (Saturday). I have not tried a front gear diff yet, nor different front and rear shims under the blocks (I've been running 0.5 mm under all around).
Maclan Racing | Seattle RC Racers | Galaxy Hobby | Dark Knight Racing Apparel
www.maclan-racing.com
www.seattlercracers.com
Samwise is offline   Reply With Quote
Old 04-15-2014, 02:50 PM   #917
Trader Rating: 15 (100%+)
No worries. I should also note that I am using 'cut' steering blocks with full travel (dual-rate) on my radio, which is 150 with KO Propo. No steering expo.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 04-15-2014, 05:53 PM   #918
where are you guys cutting the knuckles?
I have more than enough steering with the stock throw. in fact, I have better times when I don't steer all the way steer too much and the rear hooks/breaks loose sometimes. And we have a bunch of 180s too.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 04-15-2014, 05:56 PM   #919
Potoczak's Avatar
Trader Rating: 107 (100%+)
I have more than enough steering with the stock throw. in fact, I have better times when I don't steer all the way steer too much and the rear breaks loose sometimes. And we have a bunch of 180s too.
I know alot of guys that are cutting off the little nub that sticks off the steering knuckle. It's always good to have extra steering if you need it.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-16-2014, 01:43 PM   #920
Really wish VBC would package a spare screw/hardware kit for this car!
DavidNERODease is offline   Reply With Quote
Old 04-16-2014, 02:15 PM   #921
Gridworks Racing's Avatar
We're already working on it.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 04-16-2014, 06:51 PM   #922
Potoczak's Avatar
One really nice thing about the VBC tc kits it they give you alot of extra screws and shims.
Pete Potoczak
Old 04-16-2014, 08:45 PM   #923
Akhor's Avatar
I new to the vbc chassis and the stock setup sheet said that the drop is 9mm to the pin.
Can someone explain what pin and how to measure this?
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 04-16-2014, 08:48 PM   #924
Akhor's Avatar
I'm thinking you are supposed to take the wheels off then set the chassis on a flat surface. From there measure 9m to the centre of the wheel nut pin.
--Blaine--
VBC D07, VBC D08
Old 04-16-2014, 08:53 PM   #925
Potoczak's Avatar
When they are talking about the pin they are talking about the outer hing pin that holds the rear hubs and front castor blocks onto the arms.
For measuring I normally take and put the chassis on a flat surface then take a digital caliper and measure from the flat surface to the middle of the hing pin.
But there are many other ways for measuring droop. I'm sure someone else will chim in also.
Pete Potoczak
Old 04-16-2014, 11:57 PM   #926
Originally Posted by edhchoe View Post
My E30 block measured -3.5.
But my E15 block measures -1.0
Swop your rear uprights left to right and right to left.
HannK is offline   Reply With Quote
Old 04-17-2014, 12:47 AM   #927
What I do is set the car on 12mm blocks (Or whatever height) with the wheels removed and use a machinists ruler to measure up the center of the outer hinge pin. I then deduct the height of the blocks and am left with the droop # in mm.
Old 04-17-2014, 03:12 AM   #928
Alot of the setups call for drilling a 1.1mm hole I the shock cap. Does anyone have a picture they can post of that. Don't want to have to do it twice...lol
BigCheezy is offline   Reply With Quote
Old 04-17-2014, 11:13 AM   #929
Akhor's Avatar
Thanks, that makes perfect sense.
--Blaine--
VBC D07, VBC D08
Old 04-17-2014, 11:36 AM   #930
We just sand off the nubs on the back side of the steering block, so you can get more throw. We then run full-throw (ie, full dual-rate/travel), as it really helps out with mod sedan and getting the car to turn.
If it makes the car feel edgy, adjust the setup accordingly rather than removing travel/dual-rate. This is why Max K's setup is so soft.
If you look around at various setup sheets and watch some of the pro setup videos on youtube, you will find various mentions of doing the same thing (full travel, adjust setup accordingly, etc.) To each their own, but I have found that this has really helped!
SEO by vBSEO 3.5.0
