Old 03-18-2014, 02:45 AM   #856
I've just noticed the same thing, the E30 and c0 blocks on the rear give over 4deg Rear Toe. The e25 block gives 3.5deg and E20 gives 3 deg. Weird.
Lycan is offline   Reply With Quote
Old 03-18-2014, 10:35 AM   #857
Default Durable
I have yet to damage a single part on my D06 and performance is excellent. My only comlaint is that some of the holes in the arms for the droop screws are a little too large. I had to CA one hole before I put the droop screw in, otherwise the droop screw would compress into the arm.
DavidNERODease is offline   Reply With Quote
Old 03-18-2014, 07:20 PM   #858
butrflynlambie's Avatar
looking for a parts list of the differences between the d05 and d06. is there one around?
butrflynlambie is offline   Reply With Quote
Old 03-18-2014, 09:44 PM   #859
Gridworks Racing's Avatar
Click below for a parts compatibility list.
I just whipped this up, so please do not consider this all inclusive.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 03-19-2014, 11:47 AM   #860
Samwise's Avatar
I've had a similar experience. I've yet to break a single part! The car is very durable!
I didn't have any trouble with the arms, but one of the composite spool cups included were not molded well, causing the front suspension to bind. Luckily, I had purchased spares, which work great (and are very durable even in mod sedan!).
My only complaint is the quality of some of the screws. I've stripped out a couple, and one or two where defective out of the box. Not really a big deal though.
Unrelated:
This coming race weekend in Seattle, I'm going to try using longer springs. I have a bunch of Xray T3 and HPI Pro 4 springs on hand, so I'm going to give those a try. They are supposed to be more linear than short springs in general.
I installed the Xray 2.6 front and 2.4 rear springs from my old Xray T3'12. They just barely fit for ride height (5mm front and 5.5mm rear), but they do fit! I'm curious to see what happens! I also have the thin top deck installed now for more mechanical grip
Stay Dialed Everyone!
Peace,
Sam
Maclan Racing | Seattle RC Racers | Galaxy Hobby | Dark Knight Racing Apparel
www.maclan-racing.com
www.seattlercracers.com
Samwise is offline   Reply With Quote
Old 03-19-2014, 06:10 PM   #861
edhchoe's Avatar
Trader Rating: 41 (100%+)
Another racer and I at the track had the top set screw become loose on the steering knuckle. A ball joint attaches there and the upper tierod goes on that ball joint.
edhchoe is offline   Reply With Quote
Old 03-19-2014, 06:15 PM   #862
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by davenz View Post
I have just fitted the E20 block and it measures at 3 degrees.
That can happen on any car since they are threaded into plastic parts.
IIGQ4U is offline   Reply With Quote
Old 03-19-2014, 06:46 PM   #863
he's probably referring to the ball instead of the actual set screw. The set screw will not come loose. The ball on mine came loose too. I just used a longer set screw so you can go all the way into the knuckle to grab as much plastic as it can. I do this for the bottom screw too. Then lock tightened the ball to the set screw. Basically made it one piece like the other cars.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 03-19-2014, 06:49 PM   #864
IIGQ4U's Avatar
Originally Posted by inpuressa View Post
he's probably referring to the ball instead of the actual set screw. The set screw will not come loose. The ball on mine came loose too. I just used a longer set screw so you can go all the way into the knuckle, and lock tightened the ball to the set screw. Basically made it one piece like the other cars.
Ahhh! You are correct, a longer set screw will take care of it. What you said is how my car is now, 0 issues.
Old 03-19-2014, 07:17 PM   #865
edhchoe's Avatar
The set screw came loose after the hole got lightly stripped. It must have happened during crashes but my son crashes a lot more with his t4 and his car didn't suffer any similar damages. I cannot recall how the designs differ without the cars in front of me..
Old 03-19-2014, 07:22 PM   #866
It happened to me also. You tend to apply too much torque to the 3mm wrench to tighten the ball to the set screw, and pull the set screw out. I never had an issue with the one piece ones from my previous cars, so I just locked the two parts together. The bottom shock ball is like that too, so watch out.
TLR 22 3.0
Apex RC Proshop
Old 03-19-2014, 08:32 PM   #867
edhchoe's Avatar
So D07 should come with ball studs instead, on the steering knuckles.
Old 03-20-2014, 03:34 AM   #868
Korey Harbke's Avatar
Unrelated:
Peace,
Sam
This is one of the things I have yet to try, but after reading your post Sam, I figured I should give it a go. Dave Ehrlich has been running longer springs for a while and seems to really like it. We threw some on my car on a test day recently and I found the car just smoother and easier to drive.
For myself, I trimmed EXACTLY 2mm off the shock bottoms so I can lower the spring perch. This allows me to use longer springs with ease. The only potential problem I see doing it this way is 2mm is a lot. It doesn't leave a ton of material for the threads to bite into, so I'll report back if anything weird happens. I'm going with the trusty Yokomo Pink/Blue combo that has worked so well on other cars in the past. So far I've mainly just stuck with the kit TBB Orange Fronts and Red Rears that come in the kit.
Other Team Drivers have reported that using VBC Racing A-03-VBC-0086 Aluminium spring retainers and A-03-VBC-0066 Shock bottom connectors are also a way to do it. From what I understand, the older style aluminum retainers let the spring sit a little lower. Unfortunately, the diameter of the older shock bottoms is different than the TBB shocks from the D06. That is why the A-03-0066 shock bottoms are needed. They also still need to be trimmed, but I don't think quite as much (1.5mm instead of 2mm).
-Korey
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-20-2014, 11:10 PM   #869
thanks for the compatibility list. I was interested to see if there was an upgrade list to convert from do5 to do6.
Old 03-20-2014, 11:23 PM   #870
Your best option if you want a D06 would be to purchase one. There are a number of differences between the two cars. The parts differences alone probably exceed the cost of a new D06.
SEO by vBSEO 3.5.0
