Old 03-04-2014, 09:54 PM   #826
Gridworks Racing's Avatar
Originally Posted by FastHound View Post
Is your shop website down?
No, the site is not down.
I did move to a dedicated server today, but the site was down for less than a minute.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 03-04-2014, 09:57 PM   #827
I spoke too soon. I'm on it.
__________________________________________________ __________________
Old 03-05-2014, 06:31 AM   #828
midse's Avatar
Originally Posted by Leadfinger2011 View Post
What Up All!
I know that xRay spurs will fit this car, what other manufacturers spurs will fit and where are you getting them? I'm looking for the mid 90s
Any input is appreciated!!
Kevin
HPI/PANARACER
XRAY
SERPENT
LEESPEED
rabhobbies.com.au
vbcracing
roche.hk
rcmart
rcmarket
http://www.f-sangyo.co.jp/
midse is offline   Reply With Quote
Old 03-05-2014, 08:29 AM   #829
VBC Racing Shop website is back online!
VBC Wildfire D06 - Airtronics - Hobbywing
Indy R/C; Indianapolis
Craft Beer
FastHound is offline   Reply With Quote
Old 03-10-2014, 09:41 AM   #830
Trader Rating: 15 (100%+)
If anybody is curious, here is my setup sheet from carpet nats in Omaha:
http://chrishillier.com/wp/wp-conten...ch_02_2014.pdf
No huge changes from what I have previously used, mainly just trying to get more grip out of the newer Sweeps. I am far from being good with a sedan, but thought I would post this just in case anybody is curious.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 03-10-2014, 10:02 AM   #831
theproffesor's Avatar
Trader Rating: 45 (100%+)
The sheet is blank
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 03-10-2014, 10:03 AM   #832
Originally Posted by theproffesor View Post
The sheet is blank
Shouldn't be, are you sure you have a working version of Adobe Reader? It might take a couple seconds to load the text I added...
Old 03-10-2014, 10:06 AM   #833
I see everything filled out on the sheet.
On Road: VBC WF D06, A700 Evo, Mi5
Off Road: K1, DEX408
cgroves is offline   Reply With Quote
Old 03-10-2014, 10:10 AM   #834
Tried 2 different programs on my phone and still blank. Oh well ill look at when I get home. Glad to know its just me.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 03-10-2014, 10:15 AM   #835
The sheet is blank
If you are using an iPhone, open the file with Adobe Reader and the settings will be visible.
Old 03-10-2014, 11:03 AM   #836
Im using an android. On another note, is there a differnce in the fan mount for the D05 and the D06. I cant seem to get the R1fan mounted behind the mount. If I do it rest on top of the center hingenpin block . Mounted in front it almost touches the motor.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 03-10-2014, 02:12 PM   #837
I finally got my D06 on the track for the first time yesterday. i ran it on asphalt with so/so traction. i started with kit setup to get a feel for it and it was...ok. it was loose in spots and pushed in spots. then i changed to the aggressive setup that I downloaded from the VBCRacingShop site and the car came alive. it was great. it WAS aggressive but still very driveable. it hugged the sweeper nicely and had smooth rotation. Unfortunately, it was only a practice day and there was no scoring loop active so i couldn't get laptimes to compare with others racers but it was very competitive with the guys i was running with.
the next race isn't for two weeks. that will be my first chance to run it in race conditions. i'll let you know how it goes
DOTMAN is offline   Reply With Quote
Old 03-10-2014, 09:43 PM   #838
You will need to use spacers to push the fan outward so that the fan and mount are more in line with the motor. In addition to this, you may want to file down the two sides of the fan that will screw into the fan mount unless you have longer screws.
If you look very closely at these two photos, you will see how I shaved down the fan, as well as how I pushed the fan outward around the center pulley bearing holder.
I was thinking on Saturday about whether or not you had a chance to run the car and how it worked out for you. I am glad to hear that the setup worked well, I knew it would . We put forth a lot of effort into everything we do and are glad to hear that it is working out for you guys.
Old 03-11-2014, 12:38 AM   #839
Yes...it worked well. thanks for posting it
Old 03-11-2014, 05:01 AM   #840
opsman's Avatar
Mine is coming from Turkish distributor Any setups for large fast asphalt track? I will be running stock 13.5t speedpassion with Hobbywing JustStock ESC.
Any help welcomed please
Serpent Cobra 811E 2.0 - Serpent CobraB 2.0 - Serpent Spyder SRX-2 RM - Serpent Spyder SRX-2 Mid Motor - Xray XB4 - Serpent 411 ERYX - Serpent F110
opsman is offline   Reply With Quote
SEO by vBSEO 3.5.0
