Old 01-24-2014, 11:27 AM   #736
Samwise's Avatar
Default Front Gear Diff?
Hi all,
Has anyone tried using a front gear diff, specifically on carpet? What was your experience? How does it change the handling of the car?
Thanks!
Sam
Maclan Racing | Seattle RC Racers | Galaxy Hobby | Dark Knight Racing Apparel
www.maclan-racing.com
www.seattlercracers.com
Samwise is offline   Reply With Quote
Old 01-24-2014, 01:53 PM   #737
MAD916's Avatar
Sam a dif up front feels great we have built them with really thick diff lube like 250,000 to 2mil wt. but the lap times don't show an advantage over the spool.... mine is back out and back to the spool which I think a majority of us down here are running
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 01-24-2014, 06:37 PM   #738
Korey Harbke's Avatar
I've found a front diff almost always feels really dialed but the laptimes don't show it. A spool has much better forward drive off the corner, and the car changes less over the run with a spool as well. I still always have a gear diff for the front if the need ever comes up though.
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 01-25-2014, 03:06 PM   #739
edhchoe's Avatar
Trader Rating: 41 (100%+)
On my spool for the VTA car I have the hardened metal outdrives installed.
I have had them for about a month now and the right side out drive shows a significant wear. I guess that's because both racetracks I run on run clockwise.
edhchoe is offline   Reply With Quote
Old 01-27-2014, 07:21 PM   #740
Gridworks Racing's Avatar
PM sent
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 01-27-2014, 07:22 PM   #741
Will any SoCal D06 owners be competing in the open class this weekend of the HPI Challenge series?
Old 01-27-2014, 11:36 PM   #742
Do you have DCJs? Do you usually hit things with the right front? :P
-Mike
Old 01-30-2014, 10:07 AM   #743
I have a VBC Wildfire D06 for sale. It has never been ran. Kit still needs to be completed(shocks need to be built). It comes with plenty of spare parts. Full spring set. Full sway bar set. Ti-nitride shock shafts and inner hinge pins. Tuning shims. Has the aluminum front spool and hard outdrives installed. Just didn't have the time this winter. $450 Canadian for the works.
Check out the link
http://winnipeg.kijiji.ca/c-buy-and-...AdIdZ563049014
E-mail me at sobetski@mts.net if interested.
Jeff
polarismaster is offline   Reply With Quote
Old 01-30-2014, 11:37 AM   #744
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Good luck to you guys at the birds!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-30-2014, 03:39 PM   #745
Has anyone tried inboard toe in on the front of the car? Most setups the use this type of toe have a toe out setting. ( lm looking for a little more steering) I was just curious of the effects this would have.
bama racer is offline   Reply With Quote
Old 01-30-2014, 07:16 PM   #746
edhchoe's Avatar
The stock setup provided too much steering for me that I had to get rid of some.
This is close to what I have now.
If you want more steering you could do any of the following.
Add little more droop to the rear
Add negative camber to front
Give rear wheels less negative camber
Give less toe to rear.
Softer springs in the front
Harder springs in the rear
Stiffer sway bar in the rear
And so on.
I would try one thing at a time.
Old 02-02-2014, 04:22 PM   #747
Potoczak's Avatar
Trader Rating: 107 (100%+)
What's up with the VBC crew at the birds??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 02-03-2014, 08:02 AM   #748
MAD916's Avatar
The birds is over and as usuall everyone is wiped out. There were big hi and low points but the team represented well by Dave Erhlich, Max, JJ Wang, Fred, Phil and Kyle think JJ Dave and Max had some great results. But this race more than any I've been to needs a big does of good luck thrown in to the equation and I know that was lacking for many of the team guys
Old 02-03-2014, 09:15 PM   #749
What Up All!
I know that xRay spurs will fit this car, what other manufacturers spurs will fit and where are you getting them? I'm looking for the mid 90s
Any input is appreciated!!
Kevin
VBC Racing Wildfire D06
VBC Ghost
B4.1 Worlds, Orion R10 Pro/Orion/Orion-Spektrum
Kyosho RT5 Orion R10 Pro/ Viper/Orion
Dave's R/C Racetracks
Leadfinger2011 is offline   Reply With Quote
Old 02-03-2014, 09:34 PM   #750
Questions??
Disappointing to see that VTA TQ Dave Johnson did not run the A Main in either VTA or Stock TC 17.5 with his VBC Cars at the SnowBirds
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
SEO by vBSEO 3.5.0
