Old 12-24-2013, 09:34 AM   #616
edhchoe's Avatar
Trader Rating: 41 (100%+)
How many times will the website allow us to use the $10 off coupon?
Edit.
I tried using it but that coupon is for new customers only.
edhchoe is offline   Reply With Quote
Old 12-24-2013, 10:25 AM   #617
Originally Posted by edhchoe View Post
nope. Not on mine. The spur was too thick and the E clip didn't click in.
Regarding the aluminum inner axles…
Are the fronts 50.5mm and the rears 49mm?
The HPI VTA front rims rub on the steering block. I didn't notice it until the race was over. There was a groove on each side that was almost 1mm deep. I am using 1mm spacers now.
Also, at full lock, the front rims were touching the front shock springs so I moved the bottom shock ends to the inner holes and that fixed the problem.
why don't you just set your endpoints on your radio instead of effectively changing the suspension characteristics of the car. Put the shock back out board and shim and set endpoints.
freebird is offline   Reply With Quote
Old 12-24-2013, 11:43 AM   #618
edhchoe's Avatar
I thought about it also.
1mm spacer probably wouldn't be enough.
And I didn't want to lose the steering angle.
I will find out if it will be better or worse or the same on Saturday.
Old 12-24-2013, 11:44 AM   #619
edhchoe's Avatar
96t spur and 53t pinion won't fit.
52t is the max with 96t spur unless you file the red aluminum piece.
Old 12-24-2013, 12:27 PM   #620
theproffesor's Avatar
Trader Rating: 45 (100%+)
For VTA I had to run 5mm? hexes (they are 1mm wider than stock) and 1mm axle shims. It just clears the knuckle and the shock. Works great and I get full throw.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-24-2013, 06:10 PM   #621
edhchoe's Avatar
With 1 mm spacer I have just enough thread on the axle.
Old 12-24-2013, 06:57 PM   #622
Korey Harbke's Avatar
Hey Ed,
I've found 92T spur is a little easier to deal with form the few times I've run a spec class with my car. Ideally something like a 94T would be the one to get .
I currently use Panaracer spur gears. The ARC and Xray spur gears are alternatives if I can't find a good Panaracer gear.
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 12-24-2013, 07:06 PM   #623
edhchoe's Avatar
I ordered a few panaracer gears from beamcat in HK.
I think I might have ordered a serpent one from amain also.
I think I will be set for a while when I receive those gears.
Thanks.
Old 12-24-2013, 07:12 PM   #624
Thanks.
I'll be sure to bug you if I need some then! bwahaha!
Old 12-25-2013, 09:05 AM   #625
Gridworks Racing's Avatar
Merry Christmas everyone! We have a short message that you can check out, as well as a video from VBC Racing and most of its team drivers.
Check it out:
http://vbcracingshop.com/blog/
Have an awesome Christmas everyone!
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-28-2013, 01:25 PM   #626
royvp's Avatar
Send a message via MSN to royvp
Has anyone put on the Steering Stiffener Bar A-03-VBC-0078?
royvp is offline   Reply With Quote
Old 12-28-2013, 02:00 PM   #627
I have run the stiffner on both cars, helps keep the post from moving
Robert
robert s is offline   Reply With Quote
Old 12-28-2013, 02:27 PM   #628
royvp's Avatar
I take it the bar just mounts on top?
Old 12-28-2013, 02:45 PM   #629
Correct
Old 12-28-2013, 04:12 PM   #630
It helps stiffen the front of the car a tiny bit, resulting in increase initial response into the corner. However, it does take away a little bit of steering in the middle/exit of the corner.
-Korey
SEO by vBSEO 3.5.0
