Old 12-23-2013, 04:07 AM   #601
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Josh-n-ya View Post
...and also you can get ARC spur gears from shopviper.com and A-main. Lots to choose from!
Will this fit with no problems?
I bought a CRC spur and it was too thick.
Thanks.
edhchoe is offline   Reply With Quote
Old 12-23-2013, 08:52 AM   #602
spammy's Avatar
Thanks.
Xray spurs fit perfect
___________
Leighton Lederer
A&W~RC Plus~VBC~Expressmotorsports
spammy is offline   Reply With Quote
Old 12-23-2013, 10:23 AM   #603
edhchoe's Avatar
I have xray spurs on currently and they work but the offset bothers me.
Old 12-23-2013, 03:30 PM   #604
Potoczak's Avatar
Trader Rating: 107 (100%+)
I run xray spurs also, they fit great.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-23-2013, 03:33 PM   #605
edhchoe's Avatar
Because of the offset one belt is much closer to the gear than the other. I wouldn't call that perfect.
I will have to order panaracer spurs from hk.
Old 12-23-2013, 04:54 PM   #606
Amain has the yokomo panaracer in 96T. Is that too big?
-Mike
Old 12-23-2013, 05:12 PM   #607
-Mike
that's what I use. it will cover 17.5 and 13.5 blinky ratios.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-23-2013, 06:13 PM   #608
edhchoe's Avatar
Yep. 96t is what I use on 17.5. I use 92t for VTA.
I had to file the motor mount post to fit 53 and 54t pinion.
Old 12-23-2013, 07:16 PM   #609
Someone on the T4'14 thread said Serpent spurs fit in the Xray. So if Xray and VBC are compatible, this may work:
http://www.amainhobbies.com/product_...-Spur-Gear-92T
But I have definitely NOT tried it. So it's probably a bit of a gamble.
-Mike
Old 12-23-2013, 07:34 PM   #610
The crc spurs will work as long as they for 3/32nd balls
bama racer is offline   Reply With Quote
Old 12-23-2013, 10:59 PM   #611
Gridworks Racing's Avatar
I can't get enough of Utah powder.
Anyway, Serpent spur gears fit perfectly with 0 offset, but we will be carrying 96t spur gears as well as other items after the new year.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-23-2013, 11:51 PM   #612
edhchoe's Avatar
nope. Not on mine. The spur was too thick and the E clip didn't click in.
Regarding the aluminum inner axles…
Are the fronts 50.5mm and the rears 49mm?
The HPI VTA front rims rub on the steering block. I didn't notice it until the race was over. There was a groove on each side that was almost 1mm deep. I am using 1mm spacers now.
Also, at full lock, the front rims were touching the front shock springs so I moved the bottom shock ends to the inner holes and that fixed the problem.
Old 12-24-2013, 08:37 AM   #613
No, the fronts and rears are 50.5mm in stock form.
Old 12-24-2013, 08:39 AM   #614
Double post, disregard.
Old 12-24-2013, 09:23 AM   #615
theproffesor's Avatar
Trader Rating: 45 (100%+)
Well I think I figured out my leaky diff issue, I bough new diff halves and rebuikd the diff. Its super smootb now, but it still has a slight leak. This time I think it because one of the screw holes in the large half was just a tick to big and wont allow the screw to tighten. Its a bit of a pain. $10 wasted and now I will have to order another one just to make sure that is the issue. Its only a very slight leak so I am pretty sure thats it.
Merry Christmas everyone
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
SEO by vBSEO 3.5.0
