Old 11-24-2013, 09:53 AM   #451
theproffesor's Avatar
Trader Rating: 45 (100%+)
I did notice that on one of the pins, but that issue was corrected before the pic was taken. I am going to continue the build up of the car and maybe it will become a none issue as the suspension come fully together.
The whole is greater than the sum of its parts.
And thanks for the heads up on the ball cup. Didnt even notice the difference. Ill have to go through the suspension and check all of them to put them in the correct spot.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 11-24-2013, 10:56 AM   #452
I just checked my droop settings too, and it looks like yours. Use the base setup from
http://www.petitrc.com/reglages/vbcr...tBaseSetup.pdf
You still have about 2mm of wiggle room for droop. besides, too much front droop will cause the car to be unstable and do a sudden hook.
As far as the suspension blocks go, I wouldn't worry too much. Just make sure that your arms are not binding in anyway and you should be good.
Just build the car and run it. You won't be disappointed
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 11-24-2013, 11:10 AM   #453
Gridworks Racing's Avatar
I would try to correct that before running the car on the track as something appears to be binding. It could be one of your ball cups, roll center may be different between the two sides, etc. Your best bet would be to eliminate each variable one by one until you are able to locate the issue.
In regard to the Center Suspension Mount, have you tried pressing it straight as you tighten the screw at the bottom of the chassis?
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 11-24-2013, 12:12 PM   #454
How does this car stack up to the t4 14 and awsomatix ? Looking to get a new kit . Always had an xray. But may be time for a change
Huskerfan1212 is offline   Reply With Quote
Old 11-24-2013, 12:20 PM   #455
I have heard comments from a significant number of people who have been instantly faster with the D06 over their previous cars.
What makes the D06 so good is that you don't need to try to find steering to hit an apex as it's just there and the car can generate a high amount of traction, even with the stock 2.5mm chassis.
Old 11-24-2013, 12:27 PM   #456
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
The D06 is every bit as competitive as the A700 and T4 14, for a much better price. I swapped from the A700 and I have been very happy with with my D06, the car has tons of steering and corner speed. Been running the VBC Racing Shop base setup from petit RC along with a few other local guys and we've all had great success with it.
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 11-24-2013, 12:27 PM   #457
How is rear traction? Always fight that with xray . Also part availability? And anything that I would have to get to make adjustments?
Old 11-24-2013, 12:31 PM   #458
You won't have any issues with rear grip, the car is stuck Not sure what class you run? But you may want to get some different toe blocks to change rear toe.
Old 11-24-2013, 12:31 PM   #459
Also our local track has new carpet from iic and has tons of traction so much so that from our old carpet to the new that I have been chasing a new set up and I'm just sick of the xray.
Old 11-24-2013, 12:32 PM   #460
Run stock 17.5 and maybe some point mod
Old 11-24-2013, 12:57 PM   #461
R Doyel's Avatar
such traction
so amaze
wow
R Doyel is offline   Reply With Quote
Old 11-24-2013, 12:58 PM   #462
royvp's Avatar
Send a message via MSN to royvp
well these work on the 06?
Aluminum Damper Retainer for WildFire/FFTwelve/Flash04 A-03-VBC-0086
royvp is offline   Reply With Quote
Old 11-24-2013, 01:06 PM   #463
Originally Posted by R Doyel View Post
such traction
so amaze
wow
? So good rear traction?
Old 11-24-2013, 01:10 PM   #464
R Doyel's Avatar
I was just playin
The car was dialed the first time on the track.
Start with the VBC racing shop asphalt setup.....if you're running asphalt.
Old 11-24-2013, 01:11 PM   #465
Carpet . High grip carpet
SEO by vBSEO 3.5.0
