Old 10-28-2013, 11:50 AM   #331
Tron's Avatar
Trader Rating: 16 (100%+)
Originally Posted by R Doyel View Post
Thanks for the info.
APS found a glitch in their invoicing system and issued me a credit.
Hmmm....
Brett H - M03, TRF417, RM01x
"Slow Sportsman"
Tron is offline   Reply With Quote
Old 10-28-2013, 11:54 AM   #332
MAD916's Avatar
here is a quick set up from Saturday Night..... still working on
TZ setup
Front:
45wt
White or orange springs
+ .5 toe out
-1.25 camber
+2mm droop
White front sway bar
.05mm roll center shim
Rear:
40wt
Red Spring
-3d rear toe
-2.5 rear camber
+1.5mm droop
No rear bar, or green rear still testing….
0.5mm roll center shim
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 10-28-2013, 02:20 PM   #333
TZ setup
Front:
45wt
+ .5 toe out
-1.25 camber
+2mm droop
Rear:
40wt
Red Spring
-3d rear toe
-2.5 rear camber
+1.5mm droop
Are you running the 3 or 4 hole pistons with this shock setup?
puhrot is offline   Reply With Quote
Old 10-28-2013, 03:18 PM   #334
Potoczak's Avatar
Trader Rating: 107 (100%+)
TZ setup
Front:
45wt
+ .5 toe out
-1.25 camber
+2mm droop
Rear:
40wt
Red Spring
-3d rear toe
-2.5 rear camber
+1.5mm droop
What brand shock oil you running?? Also what about the link shimming, is all that stock?? Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-28-2013, 03:25 PM   #335
MAD916's Avatar
with that setup that was using 3 hole pistons using Associated oil, and no shims under the camber links... both front and rear camber links were 3rd hole from inside, with shocks in the 4th hole up from bottom of shock tower. I am currently working back up from my Vegas setup which was the 4 hole piston and 350CST fluid. that setup seemed to work better on the open Vegas layout rather than through our tight switch backs on our current layout.
I will say all three of the team drivers at our track are experimenting with different setups so everything changes each track day....
Old 10-28-2013, 03:32 PM   #336
Did my first race with the D06, and was able to win. The track had really weird conditions where the sugar water turned to molasses due to the high humidity and rain we encountered mid day. The tires looked like glazed donuts after one run
The beginning of the race, the car oversteered, then felt just right, and understeered by the end. It was a bit hard to drive, but the car handled very well. I have a vid of that race, I'll put it up later.
The base setup I used was VBC racing shop's asphalt setup. I used a 2.5rear toe with 30wt(350cst) AE oil, 3hole. Due to the big bore (about 1mm bigger), you need to use a softer oil than conventional 3 hole setups.
VBC racing shop has a new setup using other options, so I'll wait till he chimes in.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 10-28-2013, 07:32 PM   #337
Default NEW OWNER
What's up All,
I should have my kit in a week or so and I'm doing my reading but are there any build gotchas or anything I should be aware of before I start? Any upgrades folks are doing from the original build? From everything I've read the only thing anyone might do from the original build is an option bumper. Any input is appreciated and I look forward to learning on this forum!!
Kevin
VBC Racing Wildfire D06
VBC Ghost
B4.1 Worlds, Orion R10 Pro/Orion/Orion-Spektrum
Kyosho RT5 Orion R10 Pro/ Viper/Orion
Dave's R/C Racetracks
Leadfinger2011 is offline   Reply With Quote
Old 10-28-2013, 07:39 PM   #338
dpatterson26's Avatar
Originally Posted by Leadfinger2011 View Post
What's up All,
Kevin
My only advice is to read the directions carefully. Pay attention to the dots on the arms. That got me lol. The build is great. I have built lots of X-rays and this was just as good.
eXpress Motorsports•Sweep•Lunsford Racing•ORCA•RC Plus
dpatterson26 is offline   Reply With Quote
Old 10-28-2013, 07:42 PM   #339
Thanks Devon, any input on bodies, what are the TZ boys running for a neutral set-up Mazda?
See you up at TZ
Kevin
VBC Ghost
Old 10-28-2013, 07:43 PM   #340
Team VBC Racing's Avatar
Default D06 Carpet Setup
Here is a good baseline setup for medium bit carpet. Sorry it might be a liitle blurry.
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 10-28-2013, 08:16 PM   #341
Arn0 is offline   Reply With Quote
Old 10-28-2013, 09:23 PM   #342
See you up at TZ
Kevin
Speed 6
Old 10-29-2013, 03:37 PM   #343
Here is the vid from that race. The D06 is the car on pole. The weird conditions made it particularly hard to drive. Don't mind the nut behind the wheel
+ YouTube Video
TLR 22 3.0
Apex RC Proshop
Old 10-29-2013, 04:04 PM   #344
Gridworks Racing's Avatar
+ YouTube Video
Your car looks pretty good, but the track looks somewhat inconsistent. It looks really grippy in some areas and appears to have less grip in others. The car looks a tad sluggish in the last couple of turns nearest the camera, so you may want to switch to a smaller shim on the bulkhead to raise your roll center (1mm) or try moving the front camber link out a notch or two and possibly even the rear by a notch. Your car can definitely go faster through that section.
Good luck!
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 10-29-2013, 04:14 PM   #345
Good luck!
Thanks Yeah, the car's handling kept changing as the sugar started to build up on the tires. Guys that normally don't spin out were doing donuts too. Even the pan cars were coming almost to a complete stop at the turns from the stickiness. But I'll definitely be trying out the changes you mentioned.
TLR 22 3.0
Apex RC Proshop
SEO by vBSEO 3.5.0
