Old 12-15-2014, 01:38 PM   #1561
DBM
Thanks for the info, Korey! I'll have to give the new V3 parts a try, and keep the v2 parts as spares. Good to hear about the new parts being made to tighter tolerances. The slop in my v2 c-hubs in the lower pin bore is pretty bad. I've always loved the machining on the vbc cars, but have often thought that some of the plastic parts left a bit to be desired.
The outer border of my local track is made from 2x4's up against concrete walls. They are very unforgiving. After breaking 1 kit c-hub, I swapped in the v2 parts and they have taken a few good hits and have survived.
Hopefully the new rear hubs are better than the d06 kit parts. Out of the box, my d06 had 4 degrees toe on one side and 3 degrees on the other. I typically prefer 2.5 degrees rear toe, so I bought 0.5 degree EMR rear uprights and run c10 split blocks with the E30 rr mount. Rear toe is still not 2.5 (it is closer to 3 degrees), but at least it is the same on each side now. I might buy a e25 rear mount to try to lessen the rear toe a tad (or maybe just machine a part on my manual mini mill for testing first).
DBM is online now   Reply With Quote
Old 12-15-2014, 02:51 PM   #1562
Yes, I also found inconsistent rear toe on my D06's as well. My D07 is spot on.
69rotang is offline   Reply With Quote
Old 12-15-2014, 03:47 PM   #1563
Korey Harbke's Avatar
They should be better. It's an entirely new mold. I've noticed its a little bit how I tighten up the suspension blocks, and sometimes variance in the plastic parts. Mine seemed pretty close (but I have not measured it).
Its a common problem on a lot of cars surprisingly. It's general rooted to how the plastic cools and when the part is ejected from the mold.
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is online now   Reply With Quote
Old 12-17-2014, 10:44 AM   #1564
Trader Rating: 15 (100%+)
I am looking to sell one of my D06 kits. Lots of spares and extra parts for an awesome price. Link below:
FS: VBC Wildfire D06 - w/extras
I am also looking to sell a pair of EMR Factory 0.5 degree rear uprights. Link below:
FS: EMR Factory Rear Uprights for D06/D07 - 0.5 Deg
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-18-2014, 12:32 PM   #1565
Has anyone raced the new D07 and have any feedback
RandR is offline   Reply With Quote
Old 12-18-2014, 05:07 PM   #1566
DBM
Tidied up the wiring a bit in my d06. Tucked the motor wires, rerouted the esc lead and switch lead out the side of the esc case. Transponder wiring goes under the servo and between the lower bulkheads.
Old 12-18-2014, 05:10 PM   #1567
ViperZ's Avatar
Looks great Dennis! Awesome job!
Who races a Mazda Sedan...? Honestly...? :D
ViperZ is offline   Reply With Quote
Old 12-18-2014, 05:46 PM   #1568
DBM
Thanks, Bing! Your immaculate wiring jobs on your cars is my inspiration. I don't think I will ever be able to achieve the same level of tidiness as you, but I can try.
Old 12-18-2014, 09:03 PM   #1569
CamLS's Avatar
+1
Bing gives us some serious inspiration with his tidy wiring jobs! His crazy good photos help too
CamLS is offline   Reply With Quote
Old 12-19-2014, 08:51 AM   #1570
ViperZ's Avatar
Thanks Dennis! Your cars are looking pretty amazing themselves, so I would say you've done it
Originally Posted by CamLS View Post
+1
Thanks Cam! You guys are an inspiration too, with your great driving skills, tuning help and general assistance in help me become more consistent and faster . See you all on the track!
Old 12-19-2014, 07:38 PM   #1571
Akhor's Avatar
Doesn't the transponder wire pinch under the floating servo mount? Doesn't look like there is enough space there...
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is online now   Reply With Quote
Old 12-19-2014, 11:19 PM   #1572
DBM
I milled my aluminum chassis 0.75mm under the lipo and electronics, so there is adequate clearance now.
Old 12-20-2014, 07:42 AM   #1573
ViperZ's Avatar
^^^ Problem beautifully solved
Old 12-24-2014, 09:45 AM   #1574
NItrox416's Avatar
somebody tried the smokem d06 chassis with yokomo motor mount?
Do you know precisely what have changed with new upperdeck in the position of bulkheads?
Thanks for help
NItrox416 is offline   Reply With Quote
Old 12-24-2014, 09:59 AM   #1575
patorz31's Avatar
The truth I didn't notice any change with the chassis kit. I think you need the Smokem top deck to run their motor mount and maybe the Yokomo one. I am running the stock deck on the smokem chassis with the stock motor mount. My Yokomo mount is somewhere between Hong kong and Edmonton Ab Canada. When it arrives I will post up some pics of how it all works.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
SEO by vBSEO 3.5.0
