Old 11-06-2014, 08:43 PM   #1516
DBM
Just received my D06 Dynamics kit today, and am just getting started on assembling it. What a beautifully machined car. Wow.
DBM is offline   Reply With Quote
Old 11-06-2014, 10:38 PM   #1517
patorz31's Avatar
Knew you would like it, wait till you drive it.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 11-07-2014, 12:48 PM   #1518
My dynamics kit should be here any day now. Hope I chose a good car to get back into racing with, after over 20 years.
Hayling is offline   Reply With Quote
Old 11-09-2014, 10:22 AM   #1519
Just finished my build today, really good quality kit. Its a piece of art!
But I have no idea roughly what size pinion to put on with my 5 turn motor, I have never used used 64 pitch before and my track is a medium sized flowing outdoor track with about a 30 metre (100 ft) straight.
Anyone have ideas?
TLR 22-4, HPI RS4 Pro, Sanwa MT-4S
VikingBen is offline   Reply With Quote
Old 11-09-2014, 11:01 AM   #1520
erchn's Avatar
Anyone have ideas?
Assuming the stock 116 spur, you should probably be around 7.6 final or 29-30 pinion.
erchn is offline   Reply With Quote
Old 11-09-2014, 07:31 PM   #1521
Akhor's Avatar
Is there and easy way to remove the snap rings from the drive Axel?
--Blaine--
Losi 8ight-E 2.0, Mugen MBX 7, Mugen MBX 7 Eco
VBC D07, VBC D08
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 11-09-2014, 08:30 PM   #1522
DBM
Drove the car for the first time today. I ran the same amount of laps and similar lap times to my Spec-R R1 Pro Spec. The car was loose/over-rotated mid corner, so I couldn't drive with confidence/drive aggressively. What I did notice ahout the car is that it turns in very well, and is very consistent.
I'll play with droop and shock mount locations on Wednesday practice to see if I can solve the over-rotation in the middle of the corner.After the mains, I found that I had 0.5mm too much rear droop.
I also found that there is a lot of play in the rack due to slop in the 3mm rack bearings. Does anyone have a solution to remedy this problem?
Edit:
As others have noted, I have a bit more rear toe on the RR compared to the LR. Is this indeed a hub/upright problem that can be resolved with aluminum EMR hubs?
Old 11-10-2014, 08:31 AM   #1523
anyone have a good starting setup for small/med indoor carpet (ie tq rc racing)?
thanks!
mupchu is offline   Reply With Quote
Old 11-10-2014, 08:34 AM   #1524
patorz31's Avatar
Korey Harbke has a great carpet starting setup for harder spec tires like the Sweep QTS32. I used it with a 17.5 and it wasn't bad. I made the mistake of leaving the Aliuminum chassis on my car with the Sweeps. At our track the sweeps don't have the traction to require the Aluminum Chassis it made the car twitchy and unpredictible. I ran this setup last Friday night with the Graphite Chassis and it worked very well, way better then the driver.
Old 11-10-2014, 10:05 AM   #1525
Trader Rating: 15 (100%+)
I use a small jeweler's flat-head screwdriver to remove these.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-10-2014, 11:34 AM   #1526
DBM
I suppose I can swap my rear hubs with eachother and see if the side with 3.5 degrees of toe follows the hub. Then I'll know if it is the hub or not.
Old 11-10-2014, 07:14 PM   #1527
does anyone have the parts list required to do the sway bar mod?
thanks!
Old 11-11-2014, 01:16 AM   #1528
Fredp1's Avatar
thanks!
I believe the D07 will have this as standard. When this kit is released, have a look at the manual and they might fit without any mods.
I've got some ARC R10 swaybar connector parts, but haven't installed them as the sway bars need shortening.
I'd recommend to wait for the D07 bits.
Dean(14 years old)- Awesomatix A800, Fanton FR-1 13.5 Motor, Fantom batteries, KO Propo
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Dad(Fred)- VBC Wildfire D06 Dynamics, Hobbywing Stock Spec, R1 Wurks 21.5, KO Propo
Fredp1 is offline   Reply With Quote
Old 11-11-2014, 06:10 AM   #1529
theproffesor's Avatar
Trader Rating: 45 (100%+)
Ive also done mod with ARC parts. Cut the sway bars back 10mm front and rear. Used long ARC ball stud in the front and short in the rear. Used a VBC ball cup in rear. I am wondering if the 07 will have different swaybars? Unless the made the lower bulkheads different with mounting positiond further out, they will have to be.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 11-13-2014, 01:02 PM   #1530
G-rem's Avatar
G-rem is offline   Reply With Quote
SEO by vBSEO 3.5.0
