*NEW* WILDFIRE D06 Touring Car from VBC RACING
#1488
They fit, but you will have trouble getting ride height over 5.5mm. I liked to run 6mm on our outdoor track and couldn't get it with RSD Springs. On Carpet the orange front, blue rear combo is what I am running right now with the Aluminum Chassis.
#1489
Thanks for the info. They are that short its hard to get a a high ride hight??? Im running into the opposite problem with the stock springs running in VTA. I can barely get 5mm hight out of it and thats running the farthest hole out on the arm and no more than middle holenon tower. Ive actually gota berzerk rc custom tower in the way that raises the holes 2mm to try and be able to use all the shock mounting positions.
Have you thought about using D05 shock bodies with the TBB shafts (Ghost set-up) to help get the rear ride hight you want?
#1490
The RSD springs are only 20mm tall just remember that when you are doing setups. I never thought of using the older bodies to get the height. I will look into that. Thanks for the idea.
#1491
How vbc guys have done at worlds?
Have they used some new parts or special setup?
thanks
Ps
there is a costantly updated blog to follow vbc drivers?
thanks
Ps
#1494
#1498
#1499
Just got my new rear shock tower in from Bezerk RC. Raises the mouting holes up 2mm so I can use all the mounting positions on the tower and the arm. Running VTA the only holes on the arm I could use and still get bellow 5.5mm ride hight was the outer most hole. This should help as I have been looking for a way to soften my rear suspension up without going super soft on the spring. Pics will be up as soon as I have it all mounted up tomorrow.
#1500
Hey all,
Anyone have a good setup for a low grip / smooth asphalt track?
Thanks in advanced
Thanks in advanced
