Old 09-25-2014, 05:55 AM   #1426
Any good USVTA setup sheets around for the D06 on ultra-high grip carpet? Lou's, the Gate, Cleveland style traction.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 09-26-2014, 04:24 AM   #1427
ATLASCOPCO's Avatar
Is there any talk of a new kit coming out at all
ATLASCOPCO is offline   Reply With Quote
Old 09-26-2014, 05:01 AM   #1428
kentech's Avatar
D07 (?) Prototype apparently?
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 09-26-2014, 06:33 AM   #1429
TB03Racer09's Avatar
That motor mount and toe blocks Seriously, since all touring cars kind of look the same nowadays, why can't manufactures at least do what vbc has done and make there parts look stylish
TB03Racer09 is offline   Reply With Quote
Old 09-26-2014, 06:37 AM   #1430
theproffesor's Avatar
Trader Rating: 56 (100%+)
The new motor mount and hinge pin blocks look awesome!!! Now they just need to add vertical ball studs for the sway bar mounts and it looks like a new chassis for me.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-26-2014, 06:58 AM   #1431
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
And don't forget the floating steering rack!!!
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 09-26-2014, 08:06 AM   #1432
That rack looks pretty cool. It seems that this car might be looking better for outdoor with the way it looks like they are trying to put some flex in the chassis. Also are those different rear towers? It look like an extra hole right near the bulkhead attachment screws.
Old 09-26-2014, 08:21 AM   #1433
Old 09-26-2014, 09:33 AM   #1434
tommy911t's Avatar
Trader Rating: 50 (100%+)
Found a good photo of the rack on Facebook:
Northwest Racing Calendar
My Bicycle Sales and Service Shop in PDX: Tuite Bicycle Repair
RC Blog:OnTheTone
tommy911t is online now   Reply With Quote
Old 09-26-2014, 02:12 PM   #1435
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Gridworks Racing View Post
Agreed, I run both the .5 GSF and TSX. These bodies are definitely not as durable as the .7 and .8mm and will flex at speed if foam bumper extensions aren't used. The upside however is that they are extremely lightweight and are a simple and inexpensive way to shed a significant amount of weight while reducing CG.
The difference between a .5mm Blitz and a Lightweight (.7mm) body is ∼25 grams.
Yup, removing up all that weight up high, and placing more ballast down low on the chassis, you can really feel the difference thru the chicanes. The transitions are quicker.
But this is coming from just an average driver, take it for what its worth.
Dan is offline   Reply With Quote
Old 09-26-2014, 03:35 PM   #1436
ATLASCOPCO's Avatar
the reason i ask is that im toying with haveing a go with this chassis and didnt want to buy a car when a new one is coming out
thanks for the reply
XRAY T4 2014
HOBBYWING V3.1
HOBBYWING MOTORS
Old 09-26-2014, 03:45 PM   #1437
So would this new car be the D06.1 or the D7? What determines a new car vs an update? I would say new car in this case since it looks like a new chassis has to be used, and the center bulkheads are different. We cant see the other side of the car, maybe a floating layshaft? Sure looks like the other center bulkhead is missing.
Associated changed so much on the 6.2 it should have been the 7. Every T4 update is so signifigant its cheaper to buy a new car than update an existing one. So we should be on to the T7 now as well. But I
guess when you have a car as good as the VBC you dont have to change that much that often.
Old 09-26-2014, 03:48 PM   #1438
I just bought a Dynamics a month ago and love it. Even if a new chassis comes out, the 06 is awesome. If you get the Dynamics 06, the only tuning parts youll need to buy are shock and diff oils. It comes with all swaybars and shock springs, and the two/three most common toe blocks. It even comes with DCJ's and the carbon and aluminum chassis. You cant beat that.
Old 09-26-2014, 04:50 PM   #1439
Gridworks Racing's Avatar
Agreed, it is a good value.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 09-27-2014, 01:50 AM   #1440
ATLASCOPCO's Avatar
Thanks for that guys
I hope you can see my point though I would be very gutted if I had a d06 for a month and a new model comes out 😪
