Old 08-26-2014, 01:02 PM   #1351
patorz31's Avatar
Originally Posted by whityboy View Post
well we tested last week with active toe in and i think it is really a good option to try.
the car was superfast and stable and were able to win the national in the stock 10.5 class. we used a raceberry flex chassis with extra hole's that make it easy to use this. using this makes the car in stock also faster on the strait
Where did you get the raceberry chassis?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 08-26-2014, 01:23 PM   #1352
Gridworks Racing's Avatar
Originally Posted by mcdomdom View Post
Hi guys,
I've a question about the P05 suspension block for the wildfire D06.
Is the P05 block wider or narrower than the P00?
Ansteht question depends on the latest setup sheets i saw.
The most of them drives the car very narrow in the rear, what is the reason for that and what effect did it have?
Thanks for your help and greetings from Germany
Dominik
The P05 narrows the front rear of the car to provide arm sweep.
The narrower rear end provides additional steering at the sacrifice of stability (In our testing).
Our Gridworks Racing team had the highest VBC finish at Reedy in the open modified class (Second) and did so without running a narrower rear end.
Ultimately, the clock should be the determining factor, but these choices are often a matter of preference, track and or driving style and are not a one size fits all solution.
My best recommendation would be to give the narrower a rear end a shot and see for yourself. I ran a narrow rear end for some time and ultimately prefer the wider rear end on more flowing and lower bite layouts.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 08-26-2014, 05:24 PM   #1353
lbckevin's Avatar
Trader Rating: 89 (99%+)
I just picked up a DB06 sedan. I look forward to running it at Tamiya and at Cal Raceway coming up. Any suggestions for 17.5 setup ?
I saw Randy and Team Gridworks setups but they are really different.
Thanks Lemar.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 08-26-2014, 05:53 PM   #1354
Originally Posted by lbckevin View Post
I just picked up a D06 sedan. I look forward to running it at Tamiya and at Cal Raceway coming up. Any suggestions for 17.5 setup ?
Is Team Gridworks , Kyle ?
Kevin, you are back racing onroad racing again? The last time I saw you was as one of the big off road races at SDRC.
We've been running the D06 on asphalt since day one.
Randy's setup was a medium grip setup that needed a few tweaks for the high bite that was experienced at Tamiya during Reedy. Anyway, shoot me a PM. I am expecting to be at Tamiya the day prior to the Lyman race for a little practice.
Old 08-26-2014, 07:53 PM   #1355
snoopyrc's Avatar
Are the blocks and arms and c-hubs the same on the ghost as the D06?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-26-2014, 10:35 PM   #1356
Korey Harbke's Avatar
Yup. All the suspension plastics are the same with the exception of the shock plastics. Suspension mounts are also the same.
-Korey
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-27-2014, 09:41 AM   #1357
JayL's Avatar
Randy's setup is a mod setup, the aggressive asphalt setup is a spec setup
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 08-27-2014, 03:36 PM   #1358
Trader Rating: 16 (100%+)
Has anyone have a good carpet setup yet?
jtsbell is offline   Reply With Quote
Old 08-27-2014, 05:01 PM   #1359
theproffesor's Avatar
Trader Rating: 56 (100%+)
Im working on one, but its for VTA and it uses the Dynamics aluminum chassis. My current set-up is close to what I like, but it leans a bit too but through the turns. I will hopefully have something dialed in this weekend.
If your running 17.5, it should get you in the ballpark. Ill post something when I have it.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-28-2014, 03:11 AM   #1360
would post some pics of mine but have not made enough posts pfff
jon may is offline   Reply With Quote
Old 08-28-2014, 07:21 AM   #1361
whityboy's Avatar
it is a german company contact him at raceberry@web.de
You have to use other belts because the motor is a little bit more to the back. for indoor thake the hard one for outdoor the flex one
VBC support team manager EU
whityboy is offline   Reply With Quote
Old 08-28-2014, 08:00 AM   #1362
Here is my build, went together really good. Quality is top notch for sure. Only thing I noticed, the screw count was a little off. missing some 3x6 flatheads. not a big deal but have heard this was an issue before I got the kit. We have an offroad race this weekend, so this thing will see its maiden voyage next week, excited about it actually.
*NEW* WILDFIRE D06 Touring Car from VBC RACING-20140823_132450.jpg   *NEW* WILDFIRE D06 Touring Car from VBC RACING-20140823_132500.jpg   *NEW* WILDFIRE D06 Touring Car from VBC RACING-20140823_132535.jpg   *NEW* WILDFIRE D06 Touring Car from VBC RACING-20140823_132552.jpg
WEEZY is offline   Reply With Quote
Old 08-28-2014, 08:37 AM   #1363
patorz31's Avatar
Which other belts?
Old 08-28-2014, 08:40 AM   #1364
Trader Rating: 15 (100%+)
Very nice! What aluminum screws did you use?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 08-28-2014, 09:28 AM   #1365
They are the hiro seiko screws, the shims and the lugnuts are the 3 racing ones. Luckily they are all the same color red. Adding the screws made it a completely different look. Just need to make sure I do a clean install for the electronics.
