Old 08-06-2014, 11:04 AM   #1306
Gridworks Racing's Avatar
Originally Posted by WagwanBumba View Post
Thought I'd post a picture of my Wildfire D06. Its the Dynamics Edition but not used the aluminium chassis as I'll be running asphalt. I also have the Mi4 battery strap there, so I don't need to use tape.
Spec:
SP Reventon Pro 1.1
SP Reventon MMM V3.0 4.5T
KO Propo RSX one10 Red
Futaba 614FS
WTF 30mm on the ESC and 40mm on the motor.
I'll drop to a 13.5T but picked up the 4.5T for giggles! Excited to get this on the track!
Looks good! What size WTF fan do you have in there? We just started carrying them. The new 34mm and 40mm fans work extremely well.
Be sure to glue the foam pieces in your bumper. They really help to reinforce it so that it lasts longer.
Enjoy your car!
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 08-06-2014, 11:20 AM   #1307
JayL's Avatar
Originally Posted by Texco View Post
Hey guys,
Can someone tell me what the Set Screws do in your Center Pulley step 11? How do you set these up?
Thanks for your time
I've never run those screws, with no issues
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 08-06-2014, 11:23 AM   #1308
Enjoy your car!
I've got the 30mm on the ESC and the 40mm in the rear on the VBC fan mount. I did pick up the 34mm one with the trumpet on it but I believe the 40mm pushes more CFM.
34mm on the ESC would have been a bit of a waste and I didn't want it to interfere with the wiring. If this 34mm fits in the motor fan mount for the Firebolt DM, that's where it's going to live
WagwanBumba is offline   Reply With Quote
Old 08-06-2014, 02:37 PM   #1309
Hey guys,
They hold the layshaft center pulley locating pins tight.
matt prigmore is offline   Reply With Quote
Old 08-06-2014, 05:40 PM   #1310
TryHard's Avatar
Actually the windy pushes more volume than the 40... Runs at a muh higher rpm, and can easily feel how much more air it's pushing out. I would give it a try
Old 08-06-2014, 07:43 PM   #1311
slakr's Avatar
Trader Rating: 27 (100%+)
Was working on chassis swapping tonight, so I weighed them FWIW...
2.25 Carbon Flex Chassis: 72g
2.50 Carbon Standard Chassis: 79g
Dynamics Aluminum Chassis: 112g
JQ THEeCar Black,THECar White~Mugen MBX7TR Eco~TLR 22 3.0,22-4 2.0~XRAY XB2C
AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 08-07-2014, 02:19 PM   #1312
Duran's Avatar
Send a message via MSN to Duran
Hi everbody !
I just got my D06 and looking for a 13.5T stock class / Asphalt / Low-medium track set-up.I couldn't find any in vbc's page so i'm asking to you all
Can DURAN / Istanbul-Turkey
Duran is offline   Reply With Quote
Old 08-07-2014, 02:25 PM   #1313
Originally Posted by Duran View Post
Hi everbody !
Have you tried kit setup? I found it with 100% rebound in the shocks was pretty easy to drive. Start with that and see what it is like, then ask back here for ideas on things to try.
Web Site: http://www.rcracingreviews.net
Sponsors: XFactoryUK | Serpent UK | Modeltune
scoyle is offline   Reply With Quote
Old 08-07-2014, 02:47 PM   #1314
I tested both and the results were very close with the 40mm just barely edging out the windy. We will have both on our site within the next few days.
If I were using the VBC fan mount, I would probably use the 34mm Windy or one of the R1 Wurks fans, but if I was using the Orca fan mount, I would opt for the WTF 40mm.
Old 08-07-2014, 03:58 PM   #1315
Duran's Avatar
Hi Scoyle,
I didn't try the basic set-up yet because some guys at the track says that it's more suitable for carpet.
And i don't have much time to think and to try adjustments and set-ups before the race.All tracks are far away from where i live.Well, i know that track very good but new car means new problems.To avoid that, i asked you all
Old 08-07-2014, 04:00 PM   #1316
Photocycler's Avatar
Trader Rating: 33 (100%+)
Hi Scoyle,
I was told the stock setup is for modified asphalt...the gearing alone suggests mod
Photocycler is offline   Reply With Quote
Old 08-07-2014, 09:32 PM   #1317
How come that way around boss? I would have thought it would be the other way around as it seems like the Windy has more static pressure than the 40mm (so is more likely to push the air around the can) plus the deadzone of the 40mm is huge! It's why I shrouded the 40mm ... so the air flow from the fan hits as much of the motor can as possible.
Old 08-08-2014, 09:11 AM   #1318
Given the size, RPMs, shape and blade pitch (& more) of the Windy, it will of course have greater static pressure, though the 40mm fan pushes more CFMs. From a volumetric perspective, the WTF 40mm has the edge, but from an overall performance standpoint, I believe that the results between the two fans is debatable.
My comment was primarily related to ease of use and aesthetics, not overall performance. The Windy would be easier to install onto the VBC fan mount since its holes match those on the fan mount.
As far as the 40mm WTF, the cost/performance ratio is tough to beat and the blades can cover the vent holes at the top and bottom of most, if not all of the popular brushless motors used in touring cars. Additionally, the fan shroud is included and further enhances the fan's effectiveness, so why not put it to use to reap the maximum benefits?
Old 08-08-2014, 10:13 AM   #1319
Big White's Avatar
Just built the car this week. everything seemed like it went well but it is mssing quite a few scews. I am excitd to get it running for this weekend and see how it does n carpit in vegas in oct.
I also ordered the white ball cups, white diff holders and the white shock parts. When trying to buld the shocks it looks like the white shock parts didnt fit. Has anyone else ran in to the prob?
Big White is offline   Reply With Quote
Old 08-08-2014, 10:41 AM   #1320
I was under the impression that the white shocks parts set was for the Ghost, which has the Wildfire D05 style shocks.
