Old 12-30-2013, 09:33 PM   #646
Gridworks Racing's Avatar
Originally Posted by Team STPN View Post
If I purchase this car what extras do I need for asphalt??
Or point me the suggestions on this thread.....
I would recommend anti-roll bars, suspension mount shims and an e25 toe block at a minimum.
The hard front bumper is a good option, but in my honest opinion, at 20 grams, it is a bit on the heavy side, especially for spec racing.
We will be uploading a new asphalt setup that is more aggressive than our previous asphalt setup when we open up after the new year. If immediate turn-in suits your driving style, be sure to check out this new medium bite asphalt setup.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-30-2013, 10:56 PM   #647
Originally Posted by jmoneym View Post
Guys is it ok to flip the rear arms? My left rear outside shock hole stripped on my D05, so I flipped the arm over. Building D06 I see you suppose to keep the dots in the rear.
You can but it will change the angle of the shock.
You'll have holes 2 and 4 available instead of the standard 1 and 3 on the suspension arm.
You'll need to flip both arms otherwise you'll end up with different geometry left to right.
Lycan is offline   Reply With Quote
Old 12-31-2013, 12:50 PM   #648
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
The steering and corner speed with this setup is nuts! I think you guys will like it.
Hope everyone has a good and safe New Years!
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 12-31-2013, 12:57 PM   #649
edhchoe's Avatar
Trader Rating: 41 (100%+)
The bottom of chassis are so shiny and clean... I will be sad when they get all scratched up in summer asphalt.
edhchoe is offline   Reply With Quote
Old 12-31-2013, 01:54 PM   #650
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
use the chassis plastic protector..work for me
OVA is offline   Reply With Quote
Old 12-31-2013, 02:49 PM   #651
corallyman's Avatar
Trader Rating: 97 (100%+)
Drop some CA glue in the hole, it should hold for awhile. Worth a try.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 01-01-2014, 04:42 PM   #652
theproffesor's Avatar
Trader Rating: 46 (100%+)
Ok I have a QC issue that is really annoying me. I purchased my car used, rebuilt the diff, and noticed thst one screw wouldnt tighten down. I attributed this to prior owner, so I purchased a new diff housing, habd the same issue. At this point I didnt knownif it was an enlarged screw hole or a scew thst was just a tic too small, so I purchased a new diff kit (the whole thing, outdrives and all) I just built it and have the same issue. Has annyone else notice tbis on the DO5, O6, or Ghost. I am about to buy a new diff case, but at this rate I coukd almost get a new car kit. I really like the quality and look of the rest of the car, but this diff is killing me. Please help with any suggestions.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-01-2014, 05:09 PM   #653
edhchoe's Avatar
Both of my D06 cars have diffs that do not leak. None of the screw holes had any problems either.
Mail me a a set of internals, screws, and a new housing from vbc racing shop. I will build it for you.
Old 01-01-2014, 05:22 PM   #654
I know how to build a diff. Ive done it on 1/8 off road, and a couple spc r diffs in my tcx's. Its an issue with the screw hole. I out very litle pressure tightening the screws. The other 3 actually get VERY tight. I will order the forth case and if it does the same thing I dont know where to go from there. Do any other companies diffs fit this car?
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 01-01-2014, 05:28 PM   #655
edhchoe's Avatar
I will try xray t4 diff on d06 tonight and let you know. Stuck at work until 7pm PST.
Edit: iirc the bearing sizes are the same. 15x10.
Old 01-01-2014, 05:33 PM   #656
c-lyon's Avatar
My first attempt leaked, and in case it's the same thing, I didn't notice that on the right diff half, there's a small square bit sticking up, and this has to match with the space on the left half. Once I figured that out , no problem.
c-lyon is offline   Reply With Quote
Old 01-01-2014, 05:43 PM   #657
Thanks for the info, but I realized the case was keyed before my first build. The leak that the issue causees is small, but I would have to rebiuld it every 3-4 runs to not see any performance issues
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 01-01-2014, 05:45 PM   #658
edhchoe's Avatar
I don't rebuild my diffs unless I see a problem such as leaking. My son's xray t4 is about 9 months old and still has the original fill in it with zero leak. LOL
Old 01-01-2014, 07:15 PM   #659
Ive had the same issue with my Ghost. It leaked before I even put it on the track. Ran it any way to get things set took it apart at the track and didn't put as much diff oil in as I did when I built it the first time. I m sue I was pressurizing from a tad too much oil and leaking out through one of the screws. didn't see anywhere else that was a sign of leakage.
freebird is offline   Reply With Quote
Old 01-01-2014, 09:35 PM   #660
edhchoe's Avatar
xray diff is too wide. it won't work.
Xray diff = 19.0 mm
D06 diff = 18.0 mm
