Old 12-29-2013, 01:48 PM   #631
edhchoe's Avatar
Trader Rating: 41 (100%+)
I just installed a Serpent 64p 92t spur on the car and it went on smoothly like the Xray gear. However, the Serpent gear is not perfectly round and there is a tighter spot against the pinion. disappointed in the quality… hopefully the panaracing gears will be better...
edhchoe is offline   Reply With Quote
Old 12-29-2013, 01:49 PM   #632
edhchoe's Avatar
both cars performed great last night.
I race one in blink stock and the other in VTA type class.
Until the 17.5t motor blew up in the main, the car performed to the best of my capabilities.
The 25.5t Novak class is what I focus on the most and it was another fun night with only several minor taps on the pipes.
Old 12-29-2013, 10:54 PM   #633
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Rumor at the camarillo track has it a SoCal local fast guy just switched to the vbc team, can't wait to see him with the d06, he kills it here every time I see him run.
Just waiting on my tax return and I'll be loading up on a new kit and a ton of parts.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 12-30-2013, 05:25 AM   #634
theproffesor's Avatar
Trader Rating: 56 (100%+)
Were does everyone measure the rear droop from. With the rear hubs having that lower loop its makes it different than I'm used too. I measure mine (usually) from the bottom of the hub.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-30-2013, 07:19 AM   #635
Team STPN's Avatar
If I purchase this car what extras do I need for asphalt??
Or point me the suggestions on this thread.....
Team STPN is offline   Reply With Quote
Old 12-30-2013, 08:57 AM   #636
Trader Rating: 15 (100%+)
I use a ruler or calipers to measure to the center of the outer pin (the one that attaches the c-hub/upright to the arm) while the car is sitting on droop blocks.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 12-30-2013, 09:39 AM   #637
Trader Rating: 49 (100%+)
Running similar setups in both cars? I'd like to see your Vta setup if it's much different.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 12-30-2013, 10:00 AM   #638
any news on a UK distributor yet
PurcyP is offline   Reply With Quote
Old 12-30-2013, 10:45 AM   #639
you can start here. Think you only need the sus block shims to do this setup.
https://files.acrobat.com/preview/04...f-7ab360277306
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 12-30-2013, 11:32 AM   #640
Default Shock/Damper Piston Vertical Play
Both my Mi5 and D06 have what has to be intentional vertical play in the piston on the shock shaft. The piston can slide up and down on the shaft a small amount. I have read that some racers shim this play out of both the Mi5 and D06 but it seems to be intentional so I'm questioning whether it should be removed or not? With tolerances being so tightly controlled on the Mi5 and D06 (the D05/Ghost shocks do not have this play) I must assume it was designed this way and not an oversite?
DavidNERODease is offline   Reply With Quote
Old 12-30-2013, 11:35 AM   #641
take it out. My old tamiyas had the same issue. I used a 3x0.2mm shim under the piston to get the play out.
TLR 22 3.0
Apex RC Proshop
Old 12-30-2013, 11:44 AM   #642
edhchoe's Avatar
Everything same except for rear toe. I have e25 block on right now but will try a e15 block. Every little bit helps. Less toe= more speed.
Edit: I forgot about moving the front shock bottoms to the inner hole on the suspension arms to make clearance front the wheels. The car still handles good but there is little more chassis roll now.
I remembered another thing. I have ae 37.5 wt oil in the shocks which is like 475cst.
BTW, I use antennae posts on both cars and they touch the belt. I had to dremel them out.
Old 12-30-2013, 05:37 PM   #643
Trader Rating: 309 (100%+)
Guys is it ok to flip the rear arms? My left rear outside shock hole stripped on my D05, so I flipped the arm over. Building D06 I see you suppose to keep the dots in the rear.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 12-30-2013, 06:53 PM   #644
Ive installed the 6.5 hub with another .1 shim between the hub and pin to give wheel and tire clearance on the front. So far it works good. Although with the 69 Camaro body ride height is very close on lock to lock. The 68 shell has better wheel openings and is not an issue. Other bodies I cant comment on as Ive not run them. Ive got the HPI Firebird on order and should be here this week. So I can give some feedback on its fitment when trimmed and painted.
freebird is offline   Reply With Quote
Old 12-30-2013, 08:16 PM   #645
MAD916's Avatar
STPN: if you buy the kit the only option you may want to start with is a hard foam bumper, and (2) sets ea of the front and rear ride height shims, you may want to run .5mm all the way around, also a fan mount is a great idea. that's pretty much what we have sent the guys out with at our shop.... just waiting for the holidays to finish and we should receive our next order of the stuff, the ice storms back east aren't helping.
Jmoneym: you can flip the arms but you may find the lower shock mounts are in slightly different locations
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
