*NEW* WILDFIRE D06 Touring Car from VBC RACING
#512
Since I'm only only one running one in Seattle.
Er, actually, John Tsang did pretty well with his last time out. I think I'm closing in on a setup, too. I think I'm going to run it in stock on Wednesday at H30 to work on it a bit more in preparation for the Can/Am challenge on Saturday.
Dave's VBC looked really good last Saturday at the Gym, though. He could carry more speed into the corner than I could, and had more drive out. It looked like it didn't rotate very hard in the middle of the corner, though. The handling kind of looked like a mod version of my scale spec car.
-Mike
I've just looked at the VBC forum a lot for a few months and there seems to be a lot of positive feedback from racers on the build and parts quality, especially for the price. Granted, an Xray is very well made (and pretty much indestructible), but I'd need over $100 in tuning parts on top of the higher kit cost
Seriously though, I've been happy with my Xray T3'12, but I think I'm ready to try another brand for a while, it's part of the fun of the hobby I was also looking at the Yokomo BD7 2014 edition, but it's almost as expensive as the Awesomatix, also out of my price range I'm pretty sure. The limited edition black version of the Yokomo from Europe is about $620 I think, plus the cost of tuning and spare parts.
All are good cars I don't think I could go wrong. In the right hands, all of these machines are champs.
#513
So with this kit do I need to get option parts for like rear toe and such?
#515
Edit was needed.
#516
The recommended setup for rear toe is -3° ~ -3.5° and the kit comes with the correct parts to achieve that. However my measurement shows -4°. I have not run my car yet but I might have to buy a part to correct that. I will get it remeasured using someone else's setup tools just in case it is my tools (yeah racing) that is not accurate.
The only option parts I needed to buy are the roll center shim sets for front and rear. The kit comes with 1mm shims but recommended shims to use are 0.5mm.
And I still need to buy stiffer front springs (white) per recommended setup.
All together they are about $25 worth of option parts.
#517
Ed I think you'll want to stay with orange front red rears... 45wt front 35wt rear.. been back and fourth with white front springs car is faster at TZ with orange fronts . also transition quicker with front and rear sway bars installed. went a while with rear bar disconnected but even with moderate grip the rear bar helped.
also the hard front bumper $5.00 is a good idea as far as option parts
#518
I agree with Mark.
My modified setup from Timezone is actually a little closer to what I would run as a base setup. Check the setup sheet out:
http://cdn.shopify.com/s/files/1/016...300913.pdf?791
I would change the following though:
-Run the kit chassis
-Run 0.5mm under all the suspension mounts (take the antidive out I have in the setup sheet)
-Run position #4 on the rear shock tower instead of #3
-Use 2000wt oil to start in the rear diff
-Yes, run 3.5 deg rear toe in stock (C05/E30 blocks in the rear) I know it sounds crazy, but our car seems to like it. I had better transient response, turn in, rotation around the middle of the corner, and forward bite. Whenever I got my car working really well on 3 deg, I went to 3.5 just to see... and it was faster on 3.5 deg regardless of what class I was running.
This makes for a very neutral and easy to drive car.
-Korey
-Korey
#519
I would also suggest getting the optional swaybars as well.
The kit springs actually work really well on carpet, but sometimes having some Green springs (softer) is handy as well. Initially I used white springs a lot up front in stock, but now I've settled on either red/green or orange/red depending on the amount of traction the track surface has.
#520
For those of you still on the fence about VBC Racing and or the D06, here is some interesting news:
ATSUSHI HARA CHOOSES THE VBC RACING WILDFIRE D06… AGAIN
#521
Interesting indeed, wonder why he chose the wildfire d06 again instead of trying something entirely new.
still, even though hara isnt going to sign with anyone its nice to see that he has good interest in the d06 to warrant multiple uses.
#522
Hope Hara does well
#523
i prefer the look to the VBC over all the touring car designs that are out there at the moment to be honest.
i agree, hope hara does well! sure he will though haha
#524
#525
