Old 11-06-2013, 09:34 PM   #376
Is the shorty servo a must on this car? I have 3 high quality spare servos and would really like to avoid buying a shorty to add to it. Any pics with standard size servos on-board? Any input is appreciated!!!
Kevin
VBC Racing Wildfire D06
VBC Ghost
B4.1 Worlds, Orion R10 Pro/Orion/Orion-Spektrum
Kyosho RT5 Orion R10 Pro/ Viper/Orion
Dave's R/C Racetracks
Leadfinger2011 is offline   Reply With Quote
Old 11-06-2013, 10:46 PM   #377
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Kevin
You can definitely run a standard sized servo at the expense of weight and space.
If that's what you have right now, run it and swap it out later if you want.
IIGQ4U is offline   Reply With Quote
Old 11-07-2013, 07:37 AM   #378
I saw the "Ghost" image on the VBC website... it's removed now - VBC you are killing me. I gotta see this chassis before I get a second touring car.
DavidNERODease is offline   Reply With Quote
Old 11-09-2013, 07:04 AM   #379
http://www.redrc.net/2013/11/vbc-rac...ar/#more-73728
duckman996 is offline   Reply With Quote
Old 11-09-2013, 12:14 PM   #380
I want some of those white plastic parts so I can dye them red...
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 11-10-2013, 09:44 PM   #381
Default HOLY CRAP
I haven't driven sedan on carpet since 2006, built one of these up this week took it out today for what I thought was going to be a new build shakedown and it went immediately to a tuning session. The car was so smooth right off the bat, Put one of the local Factory guys set-ups on and was immediately fast. Such a friendly car to drive, felt I knew where the edge was right off the bat. I'm an old X-Ray convert but am not looking back!!!! Way to go VBC!!!!
Kevin
VBC Ghost
Old 11-10-2013, 11:05 PM   #382
Korey Harbke's Avatar
Kevin
We are glad you enjoy the car!!! Feel free to ask us any questions if you have them. I'll see you at the Timezone Grand Prix.
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-12-2013, 07:57 AM   #383
theproffesor's Avatar
Trader Rating: 46 (100%+)
Ive been told there are wider hex hubs available. All I can find are the 0mm offset stock ones. Does anyone have a part number for the wider hexes or what do people run to get the wider offset besides spacers. I have 2mm in there noe and I dont like how little the contact patch is with the wheel. Really would like a wider hex.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 11-13-2013, 01:58 AM   #384
Reese Bobby's Avatar
Getting ready for the Nats here in SA, the last round of the year. Going to be some very close racing up front, glad to have the D06 in my pits. Practice starts tomorrow.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 11-13-2013, 02:04 AM   #385
Hey Prof, not sure I follow personally, are you sure its not camber / camber gain settings which need adjusting? To me the contact patch is determined by how the angle of the wheel is controlled, rather than track width. But that's just me.
VBC Wildfires
Old 11-13-2013, 04:15 AM   #386
Hi there Reese,
The Nats is going to be hectic for sure.
I only recently discovered the VBC chassis and must admit being a big AE fan the D06 does draw my attention.
I would like to come and have a closer look at your chassis this weekend if you do not mind.
I will be at the track on Friday
Charel is offline   Reply With Quote
Old 11-13-2013, 06:05 AM   #387
Not contact patch of the tire to the surface but contact patch of the hex to the inside of the wheel. When spacers are used, less of the hex hub is inside the wheel hex leading to possible stripping of the wheel hex. If there were a wider hex available then less/no spacers would be needed to achieve the desired track width. I am running into this issue with VTA wheels due to the offset of the wheel. I am in need of a wider hex. With the stock hex hub there is plenty of threads remaining on the axle shaft for up to 4mm wider on each side. I do not want to go that wide but I think 2mm would work great.
Tamiya 419x
Tamiya TA07
Tamiya M05
Old 11-13-2013, 08:01 AM   #388
Hi Prof, I see what you mean. XRay and CSO do manufacture offset hexes. You could also possibly try the VBC Dynamics suspension blocks? (Haven't worked out the final track width for myself but maybe this chart helps?)
VBC Wildfires
Old 11-13-2013, 08:22 AM   #389
Trader Rating: 15 (100%+)
Widening at the blocks is different than widening at the hub, and I am guessing he is specifically wanting the latter. If you widen at the blocks you are moving all of the various suspension components (but not the shock towers) so it is a bigger change than just width, if that helps makes sense.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 11-13-2013, 05:46 PM   #390
sashimi999's Avatar
Hi all,
I am guessing I am fairly new to this thread. ^_^
I would like to express How much I like this new kit.
I used to run AE TC6.1. Compare to that, VBC build me a far more better quality car with zero sloppy, tones of steering and corner speed right out of box with default setting.
Even one of Xray guys admire me after having a look at my new gem..LOL
I would like to say thank you to Roche.hk for the fast dispatch service and good communication.
Chat with you guys more here later!
Ah, BTW, I have write a car kit building doco posted on my racing blog (check my signature http://speedyrc.blogspot.com.au),
Welcome to have a look and leave some comments.
Cheers
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
