Old 10-17-2013, 02:05 PM   #271
Originally Posted by VBC Racing Shop View Post
Yes, the 4 hole pistons are working well for both carpet and asphalt.
When are you going to get the 4 holes back in stock?
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 10-17-2013, 02:20 PM   #272
Gridworks Racing's Avatar
Hi, thanks for the question.
We will have them on Tuesday of next week.
Next week will be busy for us as we are preparing something for the Halloween Classic in Ohio, as well as preparing for a large race on the same weekend here in SoCal.
I am hoping to further refine the setup on my car this Saturday in preparation for the race as well, which will be the following weekend.
If any of you folks are still racing on asphalt and looking for a setup to try, I should have one posted on the site next week.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 10-17-2013, 06:28 PM   #273
Originally Posted by Hyper_Mike View Post
Hi all,
Got to run my D06 for the first time this week and overall I love it. I started out with the kit setup and found that the car was simply too responsive, had too much steering and not enough rear traction, especially from the middle of the corner - out. I ended up adding some droop (a bit in the back and more in the front) and removing the rear anti-roll bar and the car was much better and very easy to drive.
Is this consistent with what others have found with their D06? Is there a better setup change to consider that would calm the car down, add rear traction but allow for more corner speed?
Thanks in advance for any help you could provide!
Cheers,
Mike
one thing you might want to try is the diff height. Something about dogbone plunge, and being higher you have less traction, and low you have more. I noticed that the D06 uses the high setting. It might be an interesting thing to try out.
TLR 22 3.0
Apex RC Proshop
Old 10-17-2013, 08:09 PM   #274
Hi all,
Cheers,
Mike
Try to lower the roll center as well. Personally always like to run it lower which give more traction. But sometime in High traction track may cause traction roll......
www.beamcat.com
beamcat is offline   Reply With Quote
Old 10-17-2013, 09:40 PM   #275
Originally Posted by Max K View Post
This was exactly what I found on my car. This is what I changed:
4 hole pistons
350 cst
Green springs
shocks in middle holes on towers
green rear bar
white front bar
C05 suspension blocks in the rear
.5mm roll center all around
Let me know how this works for you
Max, thanks for confirming what I was experiencing...I don't have a lot of experience with Touring Cars so it's good to hear that it wasn't just me! I currently don't have local access to 4-hole pistons and alternate blocks but I can certainly try the other changes and see where it gets me.
I hadn't heard about diff height before...I assume I just rotate the adjusting cam all the way around so it gives the same tension but at a different position in the bulkhead? I'll definitely try that!
We run on what I'd call Med traction carpet so I'm not expecting traction rolling to be a major problem...I'll have to try lowering the roll center too.
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 10-18-2013, 02:04 PM   #276
JayL's Avatar
I use the R1 Wurks fan which is 30mmx15mm and I filed it down on two sides so that I could thread the screws into the fan mount.
I can get some shots a bit later for you.
If you had used a longer screw you would not have to file down the R1 fan, correct?
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 10-18-2013, 02:14 PM   #277
Correct, but I didn't a screw with more than 15mm of thread.
Old 10-18-2013, 05:48 PM   #278
spunkysandoval's Avatar
Trader Rating: 124 (100%+)
D05 & D06 ready to play
Tekno RC - VBC Racing D06 - Axial Rubicon and Wraith - SC10.2 - Hitec - Speed Passion - Werks - lrhhobbies.com
spunkysandoval is offline   Reply With Quote
Old 10-18-2013, 05:51 PM   #279
Potoczak's Avatar
Trader Rating: 111 (100%+)
To the guys that ran at the IIC or just in general whats a good general starting for droop on high bite carpet??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 10-18-2013, 06:36 PM   #280
That D05 is definitely unique. It will be interesting to see how it handles. Great work!
You'll probably want to start around 6 up front and 2-3 in the rear.
Old 10-18-2013, 06:50 PM   #281
theproffesor's Avatar
Trader Rating: 56 (100%+)
Whats up with the shock towers on the VTA car???
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-18-2013, 07:19 PM   #282
There are none
Old 10-18-2013, 07:30 PM   #283
Is that what you have to do to get this car to work in VTA? This car was at the top of my list when I replace my current cars, but now... having to run that odd of a set-up. I would have never thought to not use shock towers. That seems very unorthidox.
Old 10-18-2013, 11:07 PM   #284
It's not necessary at all and may not even work well. I'm just playing around with it and haven't run it like that yet. I will tomorrow on asphalt.
Old 10-18-2013, 11:24 PM   #285
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
1.5-2mm over ride height
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
