Old 10-20-2014, 09:56 AM   #1501
theproffesor's Avatar
Trader Rating: 56 (100%+)
Got a race day in with the new towers. Car ran great. Need to get the long springs to get full use of the new tower though. But it really helped gain some up travel that I needed before. In the pics the forst is the new tower on top of the stock tower. In the second and third pics it shoes how much I had to run the spring up with stock and how far down with the Bezerk tower.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 10-20-2014, 10:13 AM   #1502
Gridworks Racing's Avatar
The towers look great. Bezerk makes good stuff.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 10-20-2014, 10:16 AM   #1503
erchn's Avatar
+1!
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 10-20-2014, 10:22 AM   #1504
They are a bit thick at 4mm, but will never have to worry about breaking!!! They are definately needed to run the 06 in VTA due to the hieght of the tires. I had a set made for my Ghost as well.
Old 10-23-2014, 08:55 PM   #1505
patorz31's Avatar
I just installed the EMR 0 degree hubs on the back of my D06. These things are works of art. EMR i have a suggestion can you make suspension mounts that take the inserts from say AE (or spec R) that would fit the D06/7?
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-24-2014, 11:06 PM   #1506
Texco's Avatar
Hey all,
Anyone having problems with getting the same rear toe angle? left side getting 3 Deg and right 4 Deg, I can't seem to get them both equal? Any tips?
thanks heaps
Texco is offline   Reply With Quote
Old 10-25-2014, 12:13 AM   #1507
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Texco View Post
Hey all,
thanks heaps
What rear blocks are you running and are the smaller ones oriented right?
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 10-25-2014, 04:20 AM   #1508
chasingthepack's Avatar
Hey all,
thanks heaps
bent hinge pin ?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 10-25-2014, 01:49 PM   #1509
I have the same problem with a brand new kit?
008-Racer is offline   Reply With Quote
Old 11-05-2014, 09:54 PM   #1510
Default Raceberry shock towers
Hi, Dose anyone use Raceberry(3mm higher) shock towers for D06?
Someone said it is aimed for vbc shock+ long spring , the other hand
for Yokomo long shock (any other long shock) +long spring.
Is it possible to both with any modify?
Thank you.
accord12 is offline   Reply With Quote
Old 11-05-2014, 10:34 PM   #1511
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Hey all,
thanks heaps
I had this problem with my d06, hinge pin was straight, blocks appeared straight.
It wasn't noticeable in scale spec, so I just rolled with it. Forcing the blocks while tightening did help a bit, from what I remember.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-06-2014, 03:24 AM   #1512
Bar
I have had this on every car I have owned, you just need to pinch it so you can get it as close as possible to the desired toe-in required
Luke Burr
Bar is offline   Reply With Quote
Old 11-06-2014, 11:38 AM   #1513
Team VBC Racing's Avatar
Hey all,
thanks heaps
most likely the problem is in the rear hub. They could be bent a little. Try the EMR Factory aluminum rear hubs it should fix your problem.
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 11-06-2014, 12:00 PM   #1514
patorz31's Avatar
I had the same issue with mine, I came to find out that when I put the bearings in the plastic hub I didn't have them straight in, they both angled a bit and threw the rear toe out (Mold flaw or my own mistake I don't know). I put the EMR hubs on and the bearings fit really snug and flat against the inner lip. My toe is exactly 3 degrees each side on my hudy station.
The plus side is the EMR hubs look awesome.
Old 11-06-2014, 12:02 PM   #1515
patorz31's Avatar
Has anyone ran the Smokem Racing 2mm chassis with Top Deck on a D06?
