HoBao H4E Pro touring car kit
#1039
haven't had that happen w/ mine. Yet my H4 seemed to favor turning to one side vs the other ...I had to take apart my steering turnbuckles and servo arms and go back to the manual and resent everything to stock ...that seemed to fix my issue. I am guessing I had tweaked my car too much and made too many setting adjustments that got it out of whack.
Can you go back to stock, re-check all your settings per the manual and kind of start over (if there is nothing obvious of course or you keep racking your brain over it).
Thinking I may convert my H4 to USGT soon as I'd like to change my 17.5 to something more modern like a TC7 or Xray. ...I have about 3 or 4 seasons on my H4 running 17.5 ...
#1040
#1041
My car is all out of whack, just can't get good grip lately.
We run on asphalt, medium grip.
Last race my tires were really hot, rides 36* on a 86* day ...track was around 105* as it is in full Sun.
Suggestions?
Whatbi need is to see some proven setup sheets that others have used.
....w all that said I did the best I've done last race.... But w/o the grip I want. ...car was just too loose.
Suggestions?
#1043
Thanks 30tooth,
I was only running -1 degree camber up front and 0 in back, ...had switched from the race before. I think I may try increasing my camber a bit to like -2 front and -1 rear.
will try wider track, softer shocks, etc... at my next practice see how that does.
#1045
thanks 30tooth,
well the tires were really hot ...thinking that yeah, they could have been over-heating? I had a lot more grip the week before w/ the same setup. I was running Sorex's ...the week before I was running Rides. So maybe i just need to go back to the previous tires.
Hey, by the way,
seems too good to be true:
http://www.ebay.com/itm/HOBAO-1-10-H...8AAOSw9eVXW-F7
I notice the seller has "0" sales ...so I think i'll pass!!
Hey, by the way,
#1047
You'll probably just get sent the boxes...
#1048
You know what they say, if it's too good to be true...
No problem, need a bit more info. Is the track outdoor or indoor? Did the car felt good with the other tires? Was it consistent?
-Air temp was about 85degree track must have been 110ish
-Grip was medium
-Yes, the car felt much better w/ the previous Rides ...I think I just need to go back to those. Unfortunately at my last race I only had 32's in those rides ...they worked great when it was a bit cooler out. Last race was warmer so went w/ the 36's and w/ Sorex ...which already had about 5 races on them.
I think I was mostly frustrated with my initial post. I did adjust my camber just a degree (not too drastic). I am going to put a fresh set of Rides back on my car (I like those tires for our track). ...unfortunately I wont' be able to get any practice in prior to our next race. (work is killing me)!!
--surprisingly though i ran the best I've run in terms of times. Which makes no sense, because my car didn't feel planted like it had previous race days. (Sorry, I realize this doesn't sound right). ...I think I just want my car to handle a bit better than it is!
#1049
oh, yes the car is consistent. I am thinking it was really my tires. As nothing else changed from the prior race to last race. I keep pretty detailed info on my race vehicles and what each measurement is. I went back and compared everything ...I hadn't changed anything (other than the tires).
#1050
No problem, you know changing tires is one of the greatest change in setup there could be. Maybe the car was too stuck with the Ride tires or the grip balance was not as good as it could be. Fear not, once you change the setup to have less steering and more rear traction the car could be faster yet easy to drive. If the car hasn't enough rear grip entering corners maybe the front is wiping the rear tires with violent steering sensitivity or the front roll center height/camber link length is too low/long.
