Old 02-06-2015, 02:06 PM   #871
rcwck's Avatar
Originally Posted by rjf View Post
Im allways bit strugling on high traction tracks. Hows with u guys?
Can you be more specific? Class? Body? Tires? Struggles?
So far my 17.5 car has been the best locally with any type traction.
Crew chief: "It's suppose to work, if not we'll do the complete opposite".
"Team Medicare"
https://www.facebook.com/#!/hobbystopwest
rcwck is offline   Reply With Quote
Old 02-07-2015, 02:21 PM   #872
Broke a rear wishbone last night. Took a huge hit to the front nothing broke, body came off, found clips and put back on track, then just as I set off I took a massive hit to the rear.
2nd gen hub survived but the wishbone was smashed to pieces.
Suprising really as they seem to be the strongest part of the car
hipwell is offline   Reply With Quote
Old 02-08-2015, 04:36 AM   #873
Kydex bumper ive just fabbed. glued it to the original bumper for now but i plan to make another and glue to a full length cut to fit parma bumper as rcwk said to do but for now i will see if this holds up.
Hopefully it will give me confidence to push it harder
Old 02-08-2015, 04:55 AM   #874
how much does it weigh?
Worst87 is offline   Reply With Quote
Old 02-08-2015, 07:08 AM   #875
The bit of kydex weighs naff all, not weighed it but I can't see if effecting handling
Old 02-09-2015, 09:58 AM   #876
rcwck's Avatar
Slicing up note pads for frustration relief? I see you broke your vase. Lol
"Team Medicare"
Old 02-09-2015, 12:28 PM   #877
Lol I've no idea why those bits are sliced up sat in some uncut but sprayed rear spoliers, the envelopes are wedding invitations though lol.
Old 02-10-2015, 12:47 PM   #878
rjf
13.5T class, Ride 30 tires, Hudy or CS HG additive.
I have used Mazda speed 6 and Mazda 6 GX LW/normal bodys.
On modified I dont have any problems, just on stock car it is allways bit understeering or so.
What kind of pistons and oil u guys r running?
rjf is offline   Reply With Quote
Old 02-10-2015, 02:45 PM   #879
25wt associated / 300cst core rc. 3 hole piston. Losi shock bladders.
Old 02-10-2015, 05:34 PM   #880
Emaculant's Avatar
Default Pushing
I had the same problem try standing up the rear shocks. If that doesn't work get the optional rear toe blocks -.5RF and the 2.7RR (If my conjecture is correct that makes your rear toe 2.2). I'm using it now and the understeering stop significantly (on power). My track conditions are carpet low-med bite with no subfloor and the temp changes early cold (about 37-45 degrees) and it warms up around the mains (60-70 degrees) depending on the turn out. I'm in Jersey and it's approx. 10-35 degrees outside daily this time of year.
Emaculant is offline   Reply With Quote
Old 02-10-2015, 07:23 PM   #881
rcwck's Avatar
I'm having understeer issues in 21.5 USGT, mostly on turn in.
Assuming those Ride tires are spec because tires are the most important.
Here's the stuff that I tried: 5=most effect, 1=least effect concerning understeer
softer front and stiffer rear suspension....................5
body style(GX pushes L.W.Speed6 better)................5
moving wing forward (5 to 25mm)..........................5
moving weight forward.........................................5
5-10K rear diff fluid(too loose on power, used 2K).....5
laying down front/ standing up rear shocks...............5
increase steering throws.......................................5
fast servo............................................. .............5
increase rear droop(for turn in)..............................4
reduce front droop(for on power steering)................4
increase front camber(up to 3 degrees)...................3
increase steering ackerman...................................2
shim for increase in front caster(for turn in).............1
remove front anti sway bar....................................1
front diff(300K)........................................ ............1
"Team Medicare"
Old 02-10-2015, 08:07 PM   #882
Emaculant's Avatar
Good stuff. This would have probably saved me money on the toe blocks LOL!
Old 02-17-2015, 05:40 AM   #883
Any news on those 3 hole knuckles?
Old 02-20-2015, 04:11 PM   #884
rcwck's Avatar
You can screw an extension on the steering arm if you wanna give it a try. Report back if you you give it a whirl. It might be interesting.
"Team Medicare"
Old 02-25-2015, 01:33 PM   #885
may give that a try one day.
What shock positions and roll centers do you use for a high grip carpet circuit?
I'm running sorex 32s but sometimes the back end can get a little unstable Whereas my mates t4 15 seems planted constantly.
