HoBao H4E Pro touring car kit >
Like Tree2Likes
Old 12-31-2014, 10:18 AM
  #811
Originally Posted by hipwell
Was this a straight fit or did it need some cutting to get to fit right?
+1
KOWALSKITEACH is offline
Old 12-31-2014, 07:30 PM
  #812
MultiRacer's Avatar
Pretty much a straight fit. Just had to drill a few holes. The X-Ray foam bumper is slightly thicker but fits and looks good.
John K
MultiRacer is offline
Old 01-01-2015, 04:04 AM
  #813
Emaculant's Avatar
John K
What's the part number?
Emaculant is offline
Old 01-02-2015, 12:11 PM
  #814
Well first practise and bent a front driveshaft and snapped a c hub and knuckle from a Tiny tap..
Although it did withstand 2 massive crashes after that.
hipwell is offline
Old 01-02-2015, 02:41 PM
  #815
I was breaking a bunch of front parts until I got the extra stiff X-Ray foam bumper. Now I have more confidence to push it with less fear of breaking.
John K
You got a part number for this mate I need to get one ordered but want to get the right one. My mates xray t4 bumper looks no bigger than the hobao
hipwell is offline
Old 01-02-2015, 08:51 PM
  #816
edonsohc's Avatar
I don't think the xray bumper is any bigger than the stock bumper. it's just firmer foam.
edonsohc is offline
Old 01-03-2015, 02:39 AM
  #817
OK. Is it this one? http://www.teamxray.com/teamxray/products/proddesc.php?prod_id=1988&kategoria=4227&catName=t uolizghxoj%20%20-%20Foam%20Bumper%20-%20Hard&Xnet_Session=dabab0b501ec90fdf7a69fa810fcf 9e2
I can't seem to find any shops that sell it
hipwell is offline
Old 01-03-2015, 04:02 AM
  #818
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi,
First meeting tomorrow runnng a front diff see how it goes.....
Taffyjnr5 is offline
Old 01-03-2015, 05:22 AM
  #819
rcwck's Avatar
Originally Posted by Taffyjnr5
Hi,
I've been testing with a front diff in the USGT car to improve turn in and tire wear. We always run a sweeper on or off the back straight which is hard on the fronts.
I started with 10k and that seemed to help turn in but I was loosing some punch off the corners. I went to 100k then 300K to gain punch off and still keep the good turn in. I didn't see much difference between 100K and 300K. Lap times were the same. Punch off was lots better. Front tire wear seemed more even with the diff. The spec USGT tires are directional but I see no difference in handling when rotating the front tires.
I also have been experimenting with rear diff fluid. I tried 1K, 2K and 5K. 2K seems to be the best. 5K made the car a bit loose off the corners. 2K has a bit more on power steering than stock 1K.
Bodies now are being tested. I found the Tamiya BRZ Scooby Doo the best so far. It has a huge front splitter. The stock wing has been tested and deemed useless. It has been replaced with a Proto Camaro ZL1 wing and standoff.
Good luck and report back.
rcwck is offline
Old 01-03-2015, 06:13 AM
  #820
edonsohc's Avatar
OK. Is it this one? http://www.teamxray.com/teamxray/pro...a69fa810fcf9e2
http://parmapse.shptron.com/p/ultima...2-t3-etc?pp=15
I think either one will work.
edonsohc is offline
Old 01-03-2015, 07:45 AM
  #821
OK I'll see if they will ship to the UK.
Has anybody got the part numbers for the trf driveshafts which fit? These seem to be made of cheese.
hipwell is offline
Old 01-03-2015, 09:17 AM
  #822
rcwck's Avatar
Default Front bumper
Unfortunately there are no ready made bumpers that offer max durability. Most offer front straight on impact protection. For best protection you have to fab a Kydex and a Parma foam bumper. This combo will do the best for front suspension and drive-train protection on corner impacts.
Below is the best protection possible. A Kydex base that is 190mm(to be legit in Sedan) wide and a formed to body Parma foam bumper glued(E6000) to the Kydex. I also replaced those 4 short screws with 2 long screws and lock nuts to tie it all together.
It takes some time to do this correctly but you be rewarded with less frustration and fewer broken parts.
rcwck is offline
Old 01-03-2015, 04:45 PM
  #823
MultiRacer's Avatar
Hi,
Sorry for the delayed response. Part # is 301223 or XRA301223.
I found mine on Ebay but Amain or TQRC racing has them. They are slightly thicker than the H4 stock one but they do fit. I tried a Kydex type of bumper first and it kept flexing up and still got broke parts.
I just noticed the glueing part from the post above and I did not glue my Kydex type piece to the foam bumper. That would make all of the difference for durability. For now I am satisfied with the Xray hard bumper.
John K
Old 01-03-2015, 09:29 PM
  #824
Taffyjnr5's Avatar
Hi,
Did you test on asphalt or carpet?
Old 01-04-2015, 04:45 AM
  #825
rcwck's Avatar
Hi,
No asphalt racing here in Ohio in the winter months. Prepared asphalt should have similar results with good tires.
rcwck is offline
