Old 08-12-2013, 07:25 AM   #1
blackshark3's Avatar
Default Newbie question: How do I hook up my motor cooling fan for power?
Should I just plug it into a spare receiver slot?
blackshark3 is offline   Reply With Quote
Old 08-12-2013, 07:36 AM   #2
Trader Rating: 27 (100%+)
Yea depends on the fan. Some can run directly off the +/- of your ESC and some have to be plugged in to the Receiver with a receiver plug.
To save space on the receiver, I solder my transponder, glitch buster capacitor, and fan onto one receiver plug. Works perfectly.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 08-21-2013, 12:49 AM   #3
deanpeterson's Avatar
for the cooling fan - My receiver has only 3 ports and all used it seems - don't see any male ends in there - do I have to add some male ends or ??? I bought the rc used and has the fan but I had to add my own receiver.
deanpeterson is offline   Reply With Quote
Old 08-21-2013, 03:10 AM   #4
Bishop's Avatar
The better cooling fans run off direct battery voltage, more power to the fans for better cooling, also you can run into issues running fans off receivers, last weekend I saw two cars have receiver shut down issues from too much current draw through them.
My main cooling fan is actually soldered to the cap board off my ESC, which can be easier to setup that soldering direct to the posts on the ESC.
Bishop is offline   Reply With Quote
Old 08-21-2013, 03:33 AM   #5
Skiddins's Avatar
I've always preferred plugging mine into the receiver (using a 5V fan) as the BEC is maintained, where battery voltage varies each time you apply throttle.
A fan should never pull enough current to shutdown a receiver.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RD Disco
Skiddins is offline   Reply With Quote
SEO by vBSEO 3.5.0
