Old 07-26-2014, 05:34 PM   #1441
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Originally Posted by Akita View Post
Hi , I am considering to rebuilt my car for next season .
Which brands do you prefer for ball bearings and screws ?
Boca bearings.. screws are kind of moot point. I run hiro seiko. Good combination of titanium and alloy and they look nice. But there are better screws out there
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 07-26-2014, 07:49 PM   #1442
JimmyMac's Avatar
Originally Posted by xrayaustin View Post
I've been running the stock one with pretty good succuess. I have just put the entire Samix conversion on my car and am taking both chassis with me to nationals when I leave tuesday. My personal opinion is that stiff makes the car have more steering under normal curcumstance. But just like anything else too much of something can cause an adverse affect. And that's what I feel happened with tamiya chassis. It's stiff as ply wood sideways and soft front to back. To me they got their weave backwards. The samix chassis is stiffer front to rear but softer side to side. But not to soft to where it feels floppy.
I have good expectations at Nats this week with the softer chassis in 17.5. Will report and say how it goes
Yeah definitely let us know. I thought Superior was going to carry them unless if they sold out locally. I wanted to try one, but could never find it on their website. I never tried the stock chassis. I was gonna save it for carpet season so that I would not scuff it up. I've been running the Smokem V14 chassis. Much softer than stock. Yesterday practicing for a big race up here next weekend, I put in all the top deck screws to really stiffen up the Smokem chassis and found that it helped rotate the car a lot better. So I was sure the stock chassis would be more so. Maybe I should have picked up the Samix chassis.
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Old 07-27-2014, 01:46 AM   #1443
acutts's Avatar
Will a TRF417 DIFF fit my 418?
Thnks
acutts is offline   Reply With Quote
Old 07-27-2014, 02:06 AM   #1444
Thnks
Yep, I use my old 417 ones with my 418
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-27-2014, 02:26 AM   #1445
Put me down for another on the 42238 & 42231 pairing. Works brilliant.
I'm using tamiya ti/al screws but about to try some hiro seiki titanium to see if they are any harder. The tamiya ti ones are very soft.
Bearings I'm about to change to avid. See how they go.
cplus is offline   Reply With Quote
Old 07-28-2014, 01:54 PM   #1446
acutts's Avatar
Another build question. When putting the shocks together is there a correct/ Optimum shock length?
Old 07-28-2014, 02:03 PM   #1447
sosidge's Avatar
Just build them normally.
sosidge is online now   Reply With Quote
Old 07-28-2014, 02:57 PM   #1448
xrayaustin's Avatar
61.5 seems to be about perfect. But besides that make sure u replace the kit oring with either the Tamiya blue or much more blue orings. Much smoother and more free. Ulll thank me later lol
Old 07-28-2014, 05:49 PM   #1449
how can I understand the upper arm spacer in the new setups? (for example, Jilles ETS Setup Luxembourg, 0 mm in the setupsheet) .. I find it somewhat confusing, with the new 54580 cub carrier (you use this too?) go to the setups from the orginal? ...So if I drive the new, inferior to 0.7 mm.
how much you lay under the most?
DPRacing is offline   Reply With Quote
Old 07-28-2014, 06:33 PM   #1450
The new hub carrier is 0.7mm shorter in height. So to be equal to the kit settings you need to add 0.7mm on top, then add spacers.
Not sure which hub carrier Jilles is using. I do know that he uses the old style ball studs everywhere though.
Old 07-28-2014, 07:49 PM   #1451
Dan
Dan's Avatar
Trader Rating: 43 (100%+)
http://www.thercracer.com/2014/05/ta...orced-hub.html
Just curious if durability is any better with the 54580 hubs versus stock? Or is it about the same?
Just broke a c-hub yesterday in the main. Aside from that, the car was great first time out with Rod Canare's 13.5 Reedy setup.
Dan is offline   Reply With Quote
Old 07-28-2014, 08:02 PM   #1452
niznai's Avatar
What hub did break, the kit version?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-28-2014, 10:50 PM   #1453
Dan
Dan's Avatar
Yeah, kit hubs.
Old 07-28-2014, 11:59 PM   #1454
acutts's Avatar
Thanks .... do you have a part no. for the tamiya item?
Old 07-29-2014, 12:12 AM   #1455
JimmyMac's Avatar
I'm not sure how durable they are. I ditched the kit chubs for the new style ones when I built the car. I have launched my car off the track at full speed on my infamous sweeper. It bent the "supposedly" stronger suspension block (what a joke) and almost pulled the screw through my Smokem chassis. Rear arms seem to be tough though. Which reminds me, I need to check and see if the suspension pin bent. Come carpet season I think I'll see just how tough the new chubs are. Hehe
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
