Like Tree1Likes
Old 06-29-2014, 12:23 PM   #1276
RC MARKET's Avatar
Originally Posted by 2-Bad View Post
I have used Square RC Titanium and Aluminium screws for over 8 years now. Never had a problem with them.
Yes Square had Best Titanium screw !
or second choice ARROWMAX
RC MARKET is offline   Reply With Quote
Old 06-29-2014, 12:24 PM   #1277
RC MARKET's Avatar
TRF418 Anti-roll bar set
Old 07-01-2014, 02:46 AM   #1278
niznai's Avatar
Any idea what is the shock oil rating in the kit? I seem to have found 900 but that seems a bit too hard to be cst. What does that mean in cst?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-01-2014, 04:10 AM   #1279
The clear is 900 - meant for the diff.
The yellow is 400 - meant for the shocks.
cplus is offline   Reply With Quote
Old 07-01-2014, 08:10 AM   #1280
niznai's Avatar
Mine didn't have any yellow, that is why I was confused.
Team Greasy Weasel
Old 07-01-2014, 11:40 AM   #1281
tamiya oils are all color coded, and that yellow one is supposed to be in the shock part bag, so maybe they screwed up
Not sure if the cst rating is the actual number for the corresponding color, but 400 is a little thin when all the setups use 450-500 with kit pistons.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 07-01-2014, 11:50 AM   #1282
ngo8's Avatar
Send a message via ICQ to ngo8
ngo8 is offline   Reply With Quote
Old 07-01-2014, 04:56 PM   #1283
2-Bad's Avatar
Trader Rating: 24 (100%+)
That's a big assumption... If your reviewing the Team Setups few state what exact piston is used
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 07-01-2014, 05:08 PM   #1284
As said, should be in the shock back. Contact the store you got it from if you really want it.
Most would buy the kit and never use it though. Bit of a token gesture in a pro level kit.
Old 07-01-2014, 06:27 PM   #1285
hmm, at least the ones in petit only state 3 hole. did I miss something?
TLR 22 3.0
Apex RC Proshop
Old 07-01-2014, 06:59 PM   #1286
I actually realised I asked this in the 417 thread, but makes more sense here in terms of helping people I think.
Originally Posted by Fredp1 View Post
I got my TDX shims from http://www.rcfunny.com/goods-1659.html
Be patient as delivery can be a bit slow
Originally Posted by cplus View Post
Thanks. I looked there today but wasn't sure if the site was genuine or not
Edit: just ordered - $4, no shipping fee. Let's see if it turns up!
Got here yesterday. 2 weeks, could be worse!
So a legit, cheap and reliable source. Excellent.
Old 07-01-2014, 08:39 PM   #1287
Further to above, looks like a new Tamiya part is also out now....
http://www.tamiyausa.com/items/radio...shim-set-54589
Old 07-01-2014, 08:42 PM   #1288
2-Bad's Avatar
IMO, yes you did... 3 hole x what size? Tamiya kit is 1.0mm dia. Yok, Xray, TOP, HB use a variety of holes and sizes for kit pistons. Many of the Teams swap out pistons, from 3 x 1.0mm, 3 x 1.6mm, to 6 x 1.0mm depending on the track conditions.
Just trying to point out that one can't assume the posted Team Setup's are 100% accurate. They aren't lying, just missing information...(deliberately or not, who's to know) haha.
Old 07-02-2014, 03:51 AM   #1289
niznai's Avatar
Yeah, I suspect a factory screw up. NO problem, I don't really use Tamiya oils anyway, just wanted to know.
I have noticed most setups use Muchmore oils, which is fine. I use Associated, seems to be the oil local shops stock in a large range and at all times.
I wondered about pistons as well because I also noticed there is no mention in setup sheets, but I am not too worried because I don't really follow anyone's setups.
The kit only comes with one set of pistons anyway, so why worry? You can always tune with oils, especially if you have a good range. Messing about with pistons is for factory team drivers who can afford to have a range ready on hand.
Team Greasy Weasel
Old 07-02-2014, 04:25 AM   #1290
Set-ups are useful, but just as a guide, its strange to think that an exact set-up will work perfectly for all as we have different driving styles, shells, chassis weight balance, tyres, track conditions etc.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
