Like Tree1Likes
Old 06-20-2014, 12:49 PM   #1246
Thats a great price for the 418.
Not much exciting to report here other than I ran the 418 with the new Exzes Z last night, other than the inevitable first couple of races sorting the Dual rate and expo, I managed to top the time sheet again by over a complete lap, and posted a fastest lap time 0.2 sec faster than anyone.
The car is working so well for me in 17.5 carpet, just have a big smile on my face every week racing it.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-20-2014, 01:51 PM   #1247
transplantlife's Avatar
Trader Rating: 43 (98%+)
Oatmix what set-up are you using for carpet.. Thanks
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 06-20-2014, 01:56 PM   #1248
Simmi's Avatar
He`s Setup is the Exzes Z from Sanwa
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 06-20-2014, 03:25 PM   #1249
Yep the extra response time helps.
The set-up is similar to this.
http://www.thercracer.com/2014/04/tr...et-set-up.html
Although I have messed a little with the roll centre (I now use the new C hubs for double cardan)
http://www.thercracer.com/2014/05/ta...orced-hub.html
I will check over the weekend and post the update. The thing is just adding a 0.5mm shim makes a difference that is noticable on the set-up so depending on the track layout I sometimes adjust roll centres by this much (Inner bulkhead shim)
Old 06-20-2014, 05:27 PM   #1250
By new c hub do you mean the 6 degree
Ones or is there new 4 degree ones for
The DCJ ?
Atechbh is offline   Reply With Quote
Old 06-20-2014, 05:52 PM   #1251
2-Bad's Avatar
Trader Rating: 24 (100%+)
The DCJ ?
4 is available as well..... 54580
2-Bad is offline   Reply With Quote
Old 06-20-2014, 06:04 PM   #1252
I'm going to try the 6deg ones tomorrow.
Track is relatively low grip and quite open. 4 full throttle mid-high speed corners, only one hairpin.
cplus is offline   Reply With Quote
Old 06-21-2014, 12:04 AM   #1253
barts71m's Avatar
Trader Rating: 34 (100%+)
Get to try my 418 for first time tomorrow in Sydney here. Looking forward to it. Has anyone tried the Green Schu springs as Ed posted earlier?
barts71m is offline   Reply With Quote
Old 06-21-2014, 01:54 AM   #1254
The DCJ ?
I use the 4 degree ones (they are reviewed in the link) but I swap to the 6 degree ones if I need more mid to exit corner steering. Sometimes I put some anti dive with the 6 degree ones if I lose too much front steering.
Last edited by Qatmix; 06-21-2014 at 03:25 AM. Reason: Dive not squat (it's early)
Old 06-21-2014, 02:10 AM   #1255
Mr. MR4's Avatar
For more mid corner steering a gear diff with 2.5k oil in front will help.
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 06-21-2014, 02:13 AM   #1256
Suspended
I use the 4 degree ones (they are reviewed in the link) but I swap to the 6 degree ones if I need more mid to exit corner steering. Sometimes I put some anti squat with the 6 degree ones if I lose too much front steering.
How do you put anti squat on the front?!
Or is that anti dive you're talking about?
niznai is offline   Reply With Quote
Old 06-21-2014, 03:15 AM   #1257
d16dcoe45's Avatar
Originally Posted by niznai View Post
How do you put anti squat on the front? Or is that anti dive?
anti dive on the front = put 0.50 or 1.0mm shims under front rear block (towards rear of car)
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-21-2014, 03:46 PM   #1258
Raman's Avatar
Trader Rating: 56 (100%+)
Towers price went back up to $750 lol. They can't make up their minds
Raman is offline   Reply With Quote
Old 06-21-2014, 05:42 PM   #1259
I cannot use anything like that in my car as I would loose the bite out of the corner that the spool gives me. Our track is tight and if we have a sweeper leading onto the straight I would have no chance against the guys with 13.5's. the spool helps me keep close and then I can overtake them on the infield as I carry more corner speed.
Btw, I will use less than 0.5mm shims for anti dive sometimes 0.3mm (3x0.1 shims).
Old 06-21-2014, 10:47 PM   #1260
Dusttt's Avatar
Trader Rating: 123 (100%+)
Eff me I was going to pull the trigger on Monday.
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
