Old 06-11-2014, 09:56 PM   #1171
Agree on set camber with set up wheels or a station is more accurate. Still think a sanity check once tyres are mounted is a good idea.
Originally Posted by xrayaustin View Post
So u say leave everything attached but yet on the pictures u posted back a page ur shocks aren't connected lol. I'm going to leave everything attached when I set it
That was just to get the droop gauge to a spot that could be photographed better
cplus is offline   Reply With Quote
Old 06-11-2014, 11:10 PM   #1172
CraigMBA's Avatar
Trader Rating: 22 (100%+)
If your droop or tweek changes with the sway bar or the shocks attached or detached, something is wrong...
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 06-12-2014, 01:13 AM   #1173
Originally Posted by LAGuy View Post
Those trying the TRF set ups, are you using the HPI silver medium springs?
Originally Posted by CraigMBA View Post
Yes.
Anyone have a source for the HPI silvers? They're a little hard to find! Thanks!
LAGuy is offline   Reply With Quote
Old 06-12-2014, 02:03 AM   #1174
Originally Posted by niznai View Post
Checking camber with tires on can be misleading very easily as rims are not perfectly true or have tiny differences from moulding, etc.
Camber is also a measure of the way suspension is going to work rather than how the tires sit on the car (I guess what I mean here is that camber tells you how the car is going to sit on the tires not the other way around).
Measuring things on a setup station can pinpoint problems not so evident when measuring things on the car ready to race. I quickly check everything after a run, and if the car behaved and there are no obvious issues, I leave it alone. If there are obvious problems during a run, I start checking on the bench, but if I can't see/find anything, it's setup station time.
Yup agreed. I do pretty much the same. I pop the car on the station between race meetings to check everything is aligned. The 418 is very resistant to tweak, but even minor collisons with a board can just move the camber out a little. Not enough to usually bother me between races, but I like to check the car is reset to my set-up before the next race meeting.
I disconnect shocks / roll bars for downstops always have done. I only use set-up wheels to measure tweak. (I just use gauges for cambre) I have the car fully loaded with the race tyres to measure ride height.
Not raced for 2 weeks so feeling a little rusty, hopefully racing tonight though
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-12-2014, 02:21 AM   #1175
Seems the sets (75175) are easier to find than the silvers on their own (6543)
http://www.rcplanet.com/HPI_Spring_S...p/hpi75175.htm
Rather than buy two sets to get a pair of silvers I gave up and bought ride springs.
Happy with them.
Old 06-12-2014, 04:28 AM   #1176
TryHard's Avatar
Happy with them.
If your struggling to find HPI Silvers, try the Schumacher Greens from the Mi5. They are the same as the Silvers, down to wire thickness, coil count, overall diameter, and length.
Trying silvers and greens back to back, no difference on track
Schu Greens
However, silvers/greens vs ride red springs, there is a difference. The Rides are more progressive, so even though the rate is similar, the feel is quite different on track. They have their place (particularly very bumpy or very low traction, IMO)... But 95% of the time on asphalt, silvers are the go.
HiH
Ed
Old 06-12-2014, 05:06 AM   #1177
d16dcoe45's Avatar
Schu Greens
HiH
Ed
Interesting. I have been running Ride Reds for the last 3 weeks on our med-high bite asphalt track. What makes the HPI Silvers better than the more progressive Ride Reds on a higher bite surface? I am wondering if I should give the Silvers a shot again.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-12-2014, 05:12 AM   #1178
TryHard's Avatar
Simply put, more responsive. There is a very good reason the silvers are the most regularly used spring out there...
Old 06-12-2014, 09:04 AM   #1179
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Tower dropped the price back down to $500ish. I've been camping that page for a while now waiting for the drop :-)
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 06-12-2014, 09:36 AM   #1180
Johnn27's Avatar
Trader Rating: 66 (100%+)
Thumbs up discount codes
Don't forget the discount code drops it down to $454!!!!!
Johnn27 is offline   Reply With Quote
Old 06-12-2014, 09:41 AM   #1181
Raman's Avatar
Trader Rating: 49 (100%+)
Thats $429 for Tower club members who receive $75 off. Now that's very tempting
TamiyaUSA has the kit listed as discontinued. So tower is clearly trying to clear their inventory.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 06-12-2014, 10:05 AM   #1182
CL
CL's Avatar
Trader Rating: 32 (100%+)
There must be a 418X coming.
Believe in yourself!
CL is offline   Reply With Quote
Old 06-12-2014, 04:35 PM   #1183
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Has anybody tried jilles "base setup" in 17.5? Was thinking about trying it but I'm not sure if it will be too planted for stock. Anybody that has tried it or someone that can suggest changes to it to make it better for stock would be awesome
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 06-12-2014, 04:58 PM   #1184
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Does anyone know what springs came with the TRF418s that included additional parts? (arm, uprights, springs, swaybars).
I'm looking for the elusive HPI Silvers.. car came with a few extra springs I just don't know how close the included springs are compared to HPI Silvers.
lagcisco is offline   Reply With Quote
Old 06-12-2014, 04:58 PM   #1185
kit has been out of stock all over, and no plans on getting a new batch. The X is definitely over the horizon.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
