Old 06-05-2014, 01:30 AM   #1141
Originally Posted by LAGuy View Post
Those trying the TRF set ups, are you using the HPI silver medium springs?
Ride Red, Purple and Blue in my pit box.
Red is very close to HPI silver, basically identical rate - apparently "feel" slightly different.
cplus is offline   Reply With Quote
Old 06-05-2014, 10:11 AM   #1142
RC MARKET's Avatar
TRF New shock spring
RC MARKET is offline   Reply With Quote
Old 06-07-2014, 09:18 PM   #1143
d16dcoe45's Avatar
Originally Posted by torg View Post
"The tapered face of the piston provides different damper characteristics to regular flat-faced pistons, increasing your setup options."
Different how? does anyone know?
Depending on which way the tapered side faces (up or down) you will have faster compression/slower rebound or slower compression/faster rebound. I haven't seen much TC use with them, seems like more of a drift thing right now.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-08-2014, 11:55 AM   #1144
hanzo3's Avatar
Trader Rating: 55 (100%+)
What other spur gears fit with the 418 (besides Kawada and Panaracer)? Anyone try ARC spurs?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 06-08-2014, 01:11 PM   #1145
Kawada super EX and panaracer fit.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 06-08-2014, 01:45 PM   #1146
rtypec's Avatar
+1 on what Quatmix said.
I've used Panaracer, Kawada, and Spec R spur gears. Panaracer combined with Xenon pinions offer a super smooth mesh. On the other hand, Kawadas are cool because their black and hide dirt
Ran Jilles setup yesterday at the Tamiya track again. Traction was less than that of the Reedy Race, yet was able to match the 13.5 fast lap of 12.6 Very promising. Also, a friend tested the setup as well, but with Xray springs of a *similar rate*...was frustrated and nearly kinked it on purpose to be done for the day. On the last run, he switched to HPI springs, which resulted in a quick, consistent, error free run, with a smile.
rtypec is offline   Reply With Quote
Old 06-08-2014, 01:49 PM   #1147
hanzo3's Avatar
Ok thanks, hope to make it out to tamiya on Saturdays with my 418
Chris TRF419 TA05V2
Old 06-08-2014, 02:04 PM   #1148
Hi guys, the 3hole piston on Jilles setup, what is the hole diameter (0.8mm, 1.1mm?)
Thanks.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is online now   Reply With Quote
Old 06-08-2014, 02:49 PM   #1149
Sounds cool
How did you manage to get the droop setting? Did you measure it to the hingepin?
Old 06-08-2014, 03:20 PM   #1150
rtypec's Avatar
Originally Posted by Qatmix View Post
Sounds cool
I measured to the center of the hingepin which translated to something that was way over 25mm in the front (measured from top of the axle to setup board) and 24.7mm in the rear. Front at 25mm felt best to me.
Old 06-08-2014, 04:02 PM   #1151
CraigMBA's Avatar
Trader Rating: 22 (100%+)
WOW that's frustrated like hide the sharp objects frustrated.
Yes.
(Scott that you?)
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 06-08-2014, 08:37 PM   #1152
Sounds cool
I'll take a photo tonight.
Once I figured out his method, makes complete sense.
Old 06-08-2014, 10:55 PM   #1153
CraigMBA's Avatar
Can I trouble somebody to measure the distance between the chassis and the top of the bulkhead where the ballstud screws in, please?
Old 06-08-2014, 11:22 PM   #1154
Trader Rating: 31 (100%+)
32mm
ittjv is offline   Reply With Quote
Old 06-09-2014, 12:13 AM   #1155
As promised, how I understand Jilles is measuring droop.
"Normal" measurement, under the hub/arm at 5.5mm, using std TRF droop blocks and gauge.
Is equal to circa 9mm measured at the centre of the pin!
So at the rear, 8mm
Is about 4.3-4.4mm
Mind the dirty car! Was too dark and cold to clean at the end of yesterday's meet
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
