Old 05-28-2014, 08:51 AM   #1096
rtypec's Avatar
Default Reedy Race 13.5 Setup
Hi All,
Attached is the setup I used on Saturday, when traction was extremely high. Please note, I included references that specify which ball studs were used. Additionally, this works with either a ball or gear differential, depending on how much you enjoy wrenching and your driving style. I'm lazy and ham-fisted so I used a ball diff
rtypec is offline   Reply With Quote
Old 05-28-2014, 09:28 AM   #1097
Trader Rating: 152 (100%+)
Hey Rod
can you share your Orca VXX setting too?
thnx
S I O is offline   Reply With Quote
Old 05-28-2014, 09:42 AM   #1098
rtypec's Avatar
Originally Posted by S I O View Post
Hey Rod
thnx
ORCA VXX
Keith Yu provided some excellent baseline settings. The following is what I used:
  • Running Mode: Fwd/Brake
  • Battery: Lipo
  • Cut off Voltage: 0.3 (basically off)
  • Over Heat: Off
  • Neutral Range: 6%
  • Blinky Mode
  • Drag Brake: Off
  • Initial Brake: 6%
  • Brake Freq: 1k
  • Punch: Level 10
  • PWM: 8K
R1 Wurks 13.5T
  • Timing: 38
  • Spur: Panaracer 102
  • Pinion: Xenon 46
  • Ratio: 4.10
Old 05-28-2014, 10:35 AM   #1099
niznai's Avatar
Originally Posted by cplus View Post
Ah, so it was 4 tamiyas in the top 10.
Not bad for a "crap" car
Would be curious to see their setups and especially to know whether they used something that doesn't come in the kit.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-28-2014, 11:04 AM   #1100
Trader Rating: 31 (100%+)
Did anyone catch the setup Jilles posted on his facebook page? Pretty straight forward with some different bumpsteer settings, which is what they ran at the last ETS per some pics.
Wouldn't surprise me to see a new lower deck at some point as well.
ittjv is offline   Reply With Quote
Old 05-28-2014, 05:29 PM   #1101
2-Bad's Avatar
Trader Rating: 24 (100%+)
Pretty sure it's a given, they (Marc, Viktor, & Jillies) were running new chassis's and have been for over a month now. Ever since MarcR smile returned I think, lol....
Yokomo * G Force * Sanwa * SMC * ProSpec
2-Bad is offline   Reply With Quote
Old 05-28-2014, 06:30 PM   #1102
so might as well wait for the 418X...
redbones is offline   Reply With Quote
Old 05-28-2014, 06:39 PM   #1103
From what I have seen and heard the chassis is very similar, maybe the chassis is less stiff? Jill's car looks the same as mine other than he is a better driver
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-28-2014, 07:24 PM   #1104
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
Hey Rod. Where do u measure your droop too? The center line of the pin? Or to the bottom of the a-arm ?
Also can you explain how you get to your 24.7mm measurement?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 05-28-2014, 08:10 PM   #1105
2-Bad's Avatar
In my opinion, don't see anything really wrong with the current chassis in Spec racing, so waiting for the 418X is probably only advantageous for Mod class mainly because they are grip limited as opposed to Spec where it's horsepower limited.
I would suggest it would be hard to tell the difference by just looking at them. I do know at TITC this year different members of the team tried Raceberry, Smokem, and Samix chassis's. With so many aftermarket companies producing softer chassis then kit it would be hardly surprising to now see Tamiya produce their own softer version.
Old 05-28-2014, 08:15 PM   #1106
2-Bad's Avatar
I guessing... but with those measurements he probably used the David Jun method of droop (from axle to ground/setup board).
Old 05-28-2014, 08:24 PM   #1107
rtypec's Avatar
That's correct...measured from top of the axle to the setup board. Here's a link that explains this technique:
Method to Measuring and Setting Droop
Old 05-29-2014, 12:51 AM   #1108
I wouldn't. The car is good enough in the right hands to win anywhere.
We are talking about guys chasing the last 1%, the best drivers in the world.
There are plenty of other stuff we would all not be doing as well as they are!
If/when the X comes (it will) it will be deck changes and possibly different suspension blocks at most. Easy upgrades.
I would expect that after the worlds we will either see an X or a Worlds Edition, pending if they win or not!
cplus is offline   Reply With Quote
Old 05-29-2014, 02:21 AM   #1109
Benzaah's Avatar
Trader Rating: 21 (96%+)
Wrong thread sorry.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 05-29-2014, 10:34 AM   #1110
RC MARKET's Avatar
Square Screw set for TRF418
RC MARKET is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
