Like Tree1Likes
Old 05-16-2014, 07:32 AM   #1021
kentech's Avatar
Originally Posted by cplus View Post
Raising funds to get a TB EVO?
Just selling an extra kit.
The TB Evo 6 is already financially secured
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 05-16-2014, 07:58 AM   #1022
Trader Rating: 31 (100%+)
Originally Posted by Juan Aveytia View Post
Hpi pinks-front/hpi silvers rear. Tire choice is important on the track.
I would think that spring combo would only work with Sorex tires and a thin insert. Have you made that work with spec tires before, Juan? I'd be curious to try that setup. Sounds like a ton of corner speed.
Thanks,
Jose
ittjv is offline   Reply With Quote
Old 05-16-2014, 07:59 AM   #1023
Should have used a smiley - wouldn't have thought anything less than a kit on your work bench hours after release!
Looking forward to your review!
cplus is offline   Reply With Quote
Old 05-18-2014, 01:47 PM   #1024
Dusttt's Avatar
Trader Rating: 121 (100%+)
Anyone using the smokem short towers with the VBC bb shocks?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 05-18-2014, 02:23 PM   #1025
b20btec's Avatar
No vbc shocks but I'm using the trf short dampers with ride big bore shorts.
b20btec is offline   Reply With Quote
Old 05-18-2014, 03:59 PM   #1026
Thanks,
Jose
That spring combo has been used for years with RP30's, jaco's & recently sweeps. And yes I drive cars with lots of steering in the spec classes.
Juan Aveytia is offline   Reply With Quote
Old 05-18-2014, 08:03 PM   #1027
I need to fit an 86t spur(or something near that) on my 418. What spur gears fit? The holes on kimbrough and precision don't allow the spur gear holder to go on correctly.
[RC10TC] is offline   Reply With Quote
Old 05-18-2014, 08:11 PM   #1028
Johnn27's Avatar
Trader Rating: 69 (100%+)
Thumbs up Panaracer Spurs
Hey Coach,
You can try and get an 88 in a panaracer / yokomo spur that small, personally i have not gone under a 96.
http://www.fast-webshop.com/tonispor...-Spur-Gear-64P
Johnn27 is offline   Reply With Quote
Old 05-18-2014, 09:14 PM   #1029
Panaracer or Kawada Super EX are a good fit but neither go down that small in 64p
What sort of FDR are you chasing that makes you look at a spur so small?
Old 05-19-2014, 12:20 AM   #1030
niznai's Avatar
Originally Posted by Simmi View Post
Thanks niznai, I meant only the hub carrier from Yokomo. Tamiya has now finally the new one can change as you want (Sides L/R) but not yet available in Germany so I ask for the Yokomo hub carrier.
Don't quote me on this one, but Yokomo used in the past (my car is an SD SSG) imperial size hingepins (inner and outer) whereas Tamiya used metric sizes (3mm inner /2.4mm outer) so I guess there might be a small difference if Yokomo kept its sizing all the way to the current cars, which I suspect it did (manufacturer's rarely change these little details perhaps to preserve their markets for parts). That is why I found it easier to use the whole suspension.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 05-19-2014, 04:15 AM   #1031
Simmi's Avatar
Last Sunday I had a club race at the Erdferkel (www.rc-erdferkel.de) and finished the race in 6 best lap of 15.7 sec. The first 3 went best times around the 15 sec. My own gear ratio was 4.8 with a 104 main gear and 40 pinion.
I'm the only one TRF driver. That's why I ask here what else I can change to get ran the 15.0?
Below is my setup sheet from the race.
The Car drives very well but not fast enough. Hope you can give some tip.
One Option I Change the oel from the gear diff to Muchmore 5000 and a higher main gear.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 05-19-2014, 04:27 AM   #1032
Where do you think you are losing out against the other drivers?
Top speed?
Cornering entry or exit?
Mid corner speed?
Need to work out where you are losing time before changing things.
How big/small/tight is the track? FDR of 4.8 does stand out as a *little* low but I'm comparing to my X20 which likes to run mid 5's.
Old 05-19-2014, 06:48 AM   #1033
Simmi's Avatar
Thanks cplus, my Corner Speed is perfectly, Corner in or Corner out very well and in the mid to.
The Top Speed is critical because I lose 1,5 mph (german km).
Team Yokomo YZ2 CA
Old 05-19-2014, 07:41 AM   #1034
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
4.8 seems pretty high for a 13.5 motor. I would jump down to a 4.5 and start going down from there. I wouldn't go down to agressive as I don't know what the muchmore motors are like. I know when I was running a Reedy Sonic V2 13.5 I was down around 4.1 with about 30 to 35 degrees of timing. The car definitely kept pace with all the 13.5s and had the same fast lap times as others on an extremely tight technical track.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 05-19-2014, 08:39 AM   #1035
b20btec's Avatar
That small of a size he would need rw spur gears. They come in white and fits the trf418
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
