Old 04-26-2014, 06:13 PM   #916
b20btec's Avatar
Originally Posted by c2tcardin View Post
Very nice! Did you use the 2 hole or 3 hole Pistons? I have a set I haven't built yet and I also run on a low grip carpet track. What shock oil did you use?
Thanks, here's what I used for med grip carpet. I have plenty of larger springs that's why I opt for larger retainers. Since those short shocks use smaller diameter spring.
3 hole piston
42272 HL cylinder
42192 large spring retainer lower
42167 large spring retainer upper
388cst ae all around
b20btec is offline   Reply With Quote
Old 04-26-2014, 06:24 PM   #917
I also have a spare set of the large diameter retainers and plan on using them on mine as well. I'll start with the 3 hole then try the 2 later to see if the feel is different.
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 04-27-2014, 05:59 AM   #918
d16dcoe45's Avatar
Default 418 ballstud height vs 417?
Hey guys,
After snapping TWO Raceberry Hard 417 chassis (one carpet, one asphalt) I've converted my mixed 417/418 to a full 418. I am using the old style ballstuds and was wondering if someone knows the height difference between the standard Tamiya ballstud compared to the 418 ballstud with the "built in" spacers? I had assumed it was a 2mm height difference but not having 418 ballstuds on hand I am mot so sure!
It makes it hard to figure out how much spacer height to use when comparing 418 setups that are using 417 (old) ballstuds vs the taller 418 ballstuds.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 04-27-2014, 06:13 AM   #919
d16dcoe45's Avatar
Originally Posted by b20btec View Post
Just installed a bezerk chassis, short shocks, and smokem towers. Anticipating better performance on carpet.
Looks great! I was running Raceberry short 417 towers and the 57.5mm short TRF shocks. I found that standard length springs would require the droop screws to set ride height a NO NO!! So instead of using M05 springs I used Xray 4S springs which are 20mm--same length as Mini springs. The Xray springs are large diameter and work awesome. On high grip carpet the linear 2.6 front and linear 2.5 rear gave the best balance. On asphalt the 2.5-2.8 progressive and 2.3-2.6 progressive would be where I'd start.
Jay Lestingi
Old 04-27-2014, 07:11 AM   #920
b20btec's Avatar
Thanks, I agree that's why I'm using large retainers to utilize my larger springs. I wanted to avoid the standard springs all together. I didn't realize raceberry had short towers, I should've checked tonisport.
Old 04-27-2014, 07:36 AM   #921
sosidge's Avatar
Hey guys,
It's 1mm higher for the 418 ballstuds, where they are used.
Old 04-27-2014, 11:55 AM   #922
d16dcoe45's Avatar
u da man!! thank u :-)
Jay Lestingi
Old 04-27-2014, 12:13 PM   #923
Selling my 418. Only ran the car three weekends. Bought a different brand (more local support) comes with a huge spare parts lot and tuning options. 550 plus shipping. Text 480650zero879
NickGroves is offline   Reply With Quote
Old 04-27-2014, 06:57 PM   #924
b20btec's Avatar
Sad to hear you're letting go a great car. I understand the local support thingy although I don't fully agree with it. Good luck on your sale.
Old 04-27-2014, 11:00 PM   #925
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by niznai View Post
On the other hand it is amazing how Tamiya went to the length it did in some areas to give the kit a top notch standard and totally screwed up elementary (and functionally important) details like these. For a kit at this price point I think they could have replaced two of the shock support plate screws with locating dowels
Agree the locating lugs are a nicer solution, but I think it was a conscious choice to go with the 4 screw setup - the Japanese TRF drivers cars are often pictured without the lower 2 screws which adds a lot more flex (and potentially tweak if you crash)
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 04-28-2014, 03:20 PM   #926
Any know if there is a pin height difference b/t 19804784 (1A/1XA used on 418) and 54172 (used on 417V5 and TA05II)?
Obsidian is offline   Reply With Quote
Old 04-28-2014, 09:35 PM   #927
I run the same shock / tower combo and I love it ! Give a lot of steering !
my setup for the moment
Front:
droop : 5.5mm
spring : yoko pink
oïl : AE 45
ride height : 5.5mm
shock position : 5
sway bar : 1.6mm
sus block : 1D - 1D split ( no shim )
Wheel shim 1mm
width : 194.5 mm
Rear:
droop : 4.5mm
spring : yoko blue
oïl : AE 37.5
ride height : 5.5mm
shock position : 3
sway bar : 1.2mm
sus block : 1X split - 1F ( 0.5mm Under block f/r )
Wheel shim 1mm
width 192mm
Xray T4 2017
Awesomatix A700 L2
Yokomo BD7 2015 Spice FWD
VBC FF17 FWD
Quinny45 is offline   Reply With Quote
Old 04-28-2014, 09:42 PM   #928
Trader Rating: 24 (100%+)
Who make/sells an aluminum chassis for the 418?
JoeyE is offline   Reply With Quote
Old 04-29-2014, 05:13 AM   #929
http://www.redrc.net/2014/03/trr-trf...m-lower-decks/
Xray T4 2017
Awesomatix A700 L2
VBC FF17 FWD
Old 04-29-2014, 06:51 AM   #930
I emailed that company. They said $130 shipped to USA. I'll pass for that price.
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
